Waiting for safe state before starting Tx
16 Aug 2012 04:42 #1116
Waiting for safe state before starting Tx was created by PhracturedBlue
I've been thinking about how to implement the 'safe' state capability before switching models or starting the Tx.
My Devo7 requires throttle to be all the way down and the THold and FMode switches to be Up to turn on
ER9X requires throttle down and all switches up (or press a button to bypass)
Any thoughts on the requirements for Deviation?
Remember that there is no guarantee that switches are mapped to the same function as their label says.
I'm leaning towards the ER9X solution. Require throttle down and all switches up, or press a button to skip.
16 Aug 2012 04:48 #1119
Replied by PhracturedBlue on topic Waiting for safe state before starting Tx
We could actually make this configurable from tx.ini. That would be pretty easy.
We could also make a config page somewhere that lets you select the relevant input states to enable startup. That kinda feels like overkill to me though.
16 Aug 2012 04:51 #1120
Replied by FDR on topic Waiting for safe state before starting Tx
As I've already wrote somewhere I would allow the throttle hold to be switched on, but since there is no dedicated throttle hold switch nor a dedicated function for it, I would rather watched the throttle channel output instead...
16 Aug 2012 05:11 - 16 Aug 2012 05:11 #1121
Are there any models where they are dangerous to switch on with the throttle output at 0?
I mean there are are vehicles without throttle (gliders) but they aren't exactly dangerous unless they are already in the sky.
If not, it seems like checking the throttle output is a simple solution.
I guess the only risk would be some case where the output mapping isn't known (or varies). The V911 uses AETR (whereas I believe the Flysky Tx is usually setup for EATR), but Thr is still 3, so it would still be ok.
Last edit: 16 Aug 2012 05:11 by PhracturedBlue.
16 Aug 2012 07:56 #1122
The more problematic ones are with more than one throttle channel: twin (or more) engine planes, tanks, ships...
I wouldn't call it simple!PhracturedBlue wrote: If not, it seems like checking the throttle output is a simple solution.
16 Aug 2012 13:30 #1123
I think I'll implement it as fully configurable (without a GUI control for now) defaulting to the RX 'THR' channel.
So...'safe' could very well be dependent on the model being loaded.FDR wrote:
- MatCat
26 Nov 2012 23:06 #3264
by MatCat
Replied by MatCat on topic Waiting for safe state before starting Tx
Most ESC's when they see a HIGH throttle assume programming state as well. What ever is available a bypass shoud be available as well for that very reason.
27 Nov 2012 00:29 #3266
This was implemented long ago. it should meet your needsMatCat wrote: Most ESC's when they see a HIGH throttle assume programming state as well. What ever is available a bypass shoud be available as well for that very reason.
- MatCat
27 Nov 2012 01:37 #3267
by MatCat
What I get for not looking at post dates
Time to create page: 0.308 seconds
- Waiting for safe state before starting Tx
