Devo12 with improved touch screen
29 Aug 2013 04:47 #13368
Somewhere above:
I agree the calibration method can be optimized. Two single points are obviously not enough.
It's interesting that the MAV version works good for you while for vlad the first version is better... I confess both versions read three coordinates and calculate the average while the MAV version additionally does this internal 7-times oversampling. I simply have forgotten to revert the SPITouch_GetCoords() function to the original code...
In conclusion I think the MAV does not really improve things. But it should not be worse than the other.
Replied by rbe2012 on topic Devo12 with improved touch screen
Yep, but to explore if the touch screen behaves irregular in some area I might need more points. Especially if in the right corners (as vlad stated) the values do not fit.Pattaya01 wrote: Why not like most devices: all 4 corners and the center..
Somewhere above:
You are also right here but we are completely lost if the values read differ with the time. We can not force a recalibration from time to time.If the calibration uses the same routine, logically there may be deviations in the points during calibration as well. So it might be necessary to use another routine for calibration to have a higher accuracy for the points touched during calibration.
- Pattaya01
29 Aug 2013 05:48 - 29 Aug 2013 05:48 #13371
by Pattaya01
Replied by Pattaya01 on topic Devo12 with improved touch screen
I think you are on the right track. If you need more testing, let me know, I'm more than willing to help.
Last edit: 29 Aug 2013 05:48 by Pattaya01.
- Hexperience
30 Aug 2013 20:07 #13400
by Hexperience
Replied by Hexperience on topic Devo12 with improved touch screen
I'm running the patch on my Devo12... so far so good. Feels better.
- Freezywilly
15 Nov 2013 16:56 #15602
by Freezywilly
Replied by Freezywilly on topic Devo12 with improved touch screen
Got a question about transmitter calibration.
While the touchscreen calibration seems to work the calibration for sticks does not.
The origional documentation does not cover this well and (I assume ) the latest documentation is still incomplete. When I enter the stick calibration mode I have a blank screen and movement of any stick has no effect. Is there a how-to available?
Could someone that is using the 12s comment on their use of the stick calibration? Do I have a bad load or is the beta still got some holes to be filled?
15 Nov 2013 17:19 - 15 Nov 2013 17:21 #15603
Replied by vlad_vy on topic Devo12 with improved touch screen
Last edit: 15 Nov 2013 17:21 by vlad_vy.
16 Nov 2013 07:04 #15604
Vlad is right - something does not work with your installation. I have tested it with some of the betas and esp. just now with beta-11 and it works.
If you want to do it:
- select calibrate
- there should appear a message telling you to center all sticks and knobs (and sliders, on Devo12 2 sticks, 2 knobs and 4 sliders) and press "ENT"
- when you have done this there appears a second message telling you to move all sticks, knobs and sliders to both ends (min and max positions) and press ENT again
- a third screen tells you only that the calibration has been done. You have to press ENT again to exit
We are reworking the documentation actually and will make sure that it is contained.
- select calibrate
- Freezywilly
16 Nov 2013 16:34 #15621
by Freezywilly
Well Murphy was around. After fixing everything all seems ok now.
Time to create page: 0.209 seconds
Builds
- Devo12 with improved touch screen
