Nightly build, Devo 7e, back up model files.
16 Dec 2013 16:47 - 16 Dec 2013 16:50 #16718 by SilbernerSurfer
Nightly build, Devo 7e, back up model files. was created by SilbernerSurfer
can somebody explain to me how to back up the model files please.
I had the nightly build and had updated to the latest nightly build.
1. Formatting USB
2. Update firmware using dfuse
3. Copy "protocol" from the new nightly build to USB
4. Copy the content of "filesystem" to USB. (layout, models, modelico, media, template, datalog.bin, errors and TX.ini)
5. Open TX.ini with notepad and enable the modules
Devo 7e works fine at this moment.
6. Copying the saved "models" from the old nightly build from my computer to the USB "models"
Devo 7e shows now "bad/protocol missing"
If i try to open the TX.ini i get only a blank window.
What is wrong?
Thanks in advance.
Uwe
Last edit: 16 Dec 2013 16:50 by SilbernerSurfer.
17 Dec 2013 04:10 #16729 by yidc
Normally updating firmware doesn't require formatting USB :ohmy:
btw, I don't quite get what you mean by "If i try to open the TX.ini i get only a blank window."
What do you use to open it?
And for "bad/protocol missing", try copying the whole protocol folder into USB again, and you must use the protocol from the same nightly build version.
17 Dec 2013 16:46 - 17 Dec 2013 16:48 #16746 by SilbernerSurfer
Replied by SilbernerSurfer on topic Nightly build, Devo 7e, back up model files.
yidc wrote: Normally updating firmware doesn't require formatting USB :ohmy:
I am always using Notepad++ and Win 8.1. Blank window means the Notepad window is white, nothing else. No letters, no words or signs. Like an empty white sheet of paper. Only for the case after i have copied the saved model files to the USB.
I have used the protocol from the updated Nightly build
Last edit: 17 Dec 2013 16:48 by SilbernerSurfer.
17 Dec 2013 17:42 #16751 by yidc
In that case, I recommend you to re-format the USB again and also copy all files from deviation-fs-devo7e-v3.0.0-[latest nightly build].zip into USB too
Then you should be able to edit tx.ini in Notepad++ without problems ;)
also do you have any tx.ini backup? what if you copy your backup file into USB? Can you open it to edit too?
17 Dec 2013 17:47 #16753 by SilbernerSurfer
yidc wrote: In that case, I recommend you to re-format the USB again and also copy all files from deviation-fs-devo7e-v3.0.0-[latest nightly build].zip into USB too
As described anything goes well from point 1 to 5. Iam able to edit Tx.ini.
But after point 6, after copied the saved model files from my computer to the USB the problem starts. I have only saved the Model files. No backup from tx.ini or protocol.
18 Dec 2013 02:27 #16764 by yidc
By point 6, you mean: Copying the saved "models" from the old nightly build from my computer to the USB "models"???
This doesn't make sense, copying models file won't corrupt tx.ini :dry:
or you can try copying model[n].ini fies one by one instead of the whole "models" folder?
can you also make a screen capture of the content in 7e USB?
18 Dec 2013 03:41 #16765 by SadSack
Replied by SadSack on topic Nightly build, Devo 7e, back up model files.
SilbernerSurfer wrote: Hi,
1. Formatting USB
3. Copy whole "protocol Folder" from the new nightly build to to root of USB
4. Copy the content of "filesystem/devo7e/ copy to root" to USB. (layout, models, modelico, media, template, datalog.bin, errors and TX.ini)
Devo 7e shows now "bad/protocol missing" << perhaps your over writing your protocol folder with old one.
If i try to open the TX.ini i get only a blank window. <<sounds like its blank all ready.
What is wrong?
Thanks in advance.
Uwe
Time to create page: 0.284 seconds
