Nightly build, Devo 7e, model icons.
- SilbernerSurfer
24 Dec 2013 14:30 #16972
by SilbernerSurfer
Nightly build, Devo 7e, model icons. was created by SilbernerSurfer
i have updated to the latest Nightly build today.
Everything works. I have loaded two model.ini files to the USB.
They are working too.
Only problem is, i cant see the model icons on the right side of the main page.
Menue says default. I can choose the icons heli or plane in the model menue.
But when i press enter the TX goes off.
Uwe
Uwe
24 Dec 2013 14:39 #16974
Replied by PhracturedBlue on topic Nightly build, Devo 7e, model icons.
By 'goes off' do you mean it reboots?
If so, please follow the instructions for reporting a bug, and include your error file (if it is non-empty)
- SilbernerSurfer
24 Dec 2013 15:03 #16975
by SilbernerSurfer
Replied by SilbernerSurfer on topic Nightly build, Devo 7e, model icons.
No reboot. It switches off. Empty screen, no light.
So i have to switch off and on again.
- SilbernerSurfer
24 Dec 2013 16:14 #16979
by SilbernerSurfer
I have created a bug report at bitbucket.
I was only able to attach one file.
I copy and pastet the errors.txt into the bug report.
The two added model.ini' are above in my first post.
Hope this is enough information.
If there is mor info needed send me a mail.
- kreidler
24 Dec 2013 17:19 #16983
by kreidler
Replied by kreidler on topic Nightly build, Devo 7e, model icons.
Model2.ini comes from an older build. There is no icon named 'Default'. Please change the icon by hand, switch off and on and all should be ok.
For a Devo10 I can see from the beginning an heli icon on model3.ini but as mentioned in bitbucket a crash should not happen.
- SilbernerSurfer
24 Dec 2013 21:56 #16987
by SilbernerSurfer
"Default" was my second attempt! First i tried it with "HELI.bmp" with the same result.
I cant change the icons by hand. As you can read in my description above. TX goes off when i am trying it.
- robca
25 Dec 2013 07:58 #16994
by robca
I think that the suggestion was to edit the INI file on your computer, replacing the icon string. If you have an old INI file, your Devo 7e might get confused. Fix the INI file on the computer until it's right, then it should work on the Devo 7e.
You can cut and past from another INI file taken directly from your Devo 7e in USB mode, to make sure that there are no typos and the file is properly terminated. If you are using Windows, the built-in Notepad app has problems properly editing INI files, I recommend using Notepad++ (free)
Replied by robca on topic Nightly build, Devo 7e, model icons.
SilbernerSurfer wrote: I cant change the icons by hand. As you can read in my description above. TX goes off when i am trying it.
Time to create page: 0.157 seconds
Builds
- Nightly build, Devo 7e, model icons.
