4.0.1 for 7e with 1 3way patch (updated 4/1/14)
02 Jan 2014 15:01 - 04 Jan 2014 15:00 #17736 by HappyHarry
here is my deviation4 build for the 7e including the 1 3way switch patch, i have also disabled telemetry and enable the main screen layout editor
Last edit: 04 Jan 2014 15:00 by HappyHarry. Reason: updated to 4.0.1
02 Jan 2014 15:19 #17740 by PhracturedBlue
Replied by PhracturedBlue on topic 4.0 for 7e with 1 3way patch and extra toggle icon
Please do not add icons to toggle0, toggle1 or toggle2.
All additional icons should be added to toggle3 only.
The reason for this is that the icon ordering of 0,1,2 is consistent across all transmitter variants, whereas toggle3 is free for all.
You can change the images for toggle0/1/2, but you should not change their meanings nor add/remove icons from them.
02 Jan 2014 15:24 - 02 Jan 2014 15:25 #17741 by HappyHarry
no worries pb, i didn't realise that. i only added the extra icons to 0 because the fmode and t/h icons i use are from 0 and i wanted my D0 and D1 icons the same size, the D0 and D1 icons that were added to 3 are smaller than those in 0.
Last edit: 02 Jan 2014 15:25 by HappyHarry.
02 Jan 2014 15:42 #17742 by PhracturedBlue
all icons are the same physical size. I'm happy to use the larger ones in toggle3 if that makes sense.
The way the toggles are designed is that toggle0 is has all of the '0' level icons, toggle1 has all the '1' levels, and toggle2 has all the '2' levels (for 3 ways switches.
all icons are in the same order, so if you string them together and add 10 to any icon you get the next icon up. so If you choose 'F0' then the 10th icon after F0 will be F1 and the 10th icon after that will be F2.
So what you probably wanted to do is to replace the D/R icons in toggle0, toggle1, and toggle2.
with a setup like this, if you share an ini file between radios, the icons will align. Of course practically, it is pretty hard to share a devo7e model with anyone else, so it probably doesn't matter much.
02 Jan 2014 17:31 #17754 by HappyHarry
ahh i understand now, thanks for the info and it makes perfect sense why you do it that way. from now on i will only add icons to 3 if i do any more builds.
or if you could add the larger icons to 3 in the official repo that would be appreciated? i will make the modified 3 bmp and post it to the bb repo
02 Jan 2014 19:12 #17765 by Daryoon
Thank you HappyHarry. I'll use yours and not have to compile my own. :)
04 Jan 2014 15:06 #17924 by HappyHarry
Replied by HappyHarry on topic 4.0.1 for 7e with 1 3way patch (updated 4/1/14)
i've updated the build to 4.0.1 and i've included my full patch file that includes the changes to the target defs file to disable telemetry and enable the layout editor, both are in the op
Time to create page: 0.039 seconds
