7e, Nightly 18th jan, +1x3way +all
05 Jan 2014 20:23 - 19 Jan 2014 17:37 #18016 by HappyHarry
7e, Nightly 18th jan, +1x3way +all was created by HappyHarry
Thanks to a heads up by domcars0 about the changes in the latest gcc-arm-none compiler (this thread here>> deviationtx.com/forum/7-development/2547...-and-devo7e-features ) we can now build for the 7e with all options enabled B)
so find attached a build of tonights code for the 7e with the 1 x 3way switch patch, also with telemetry, permanent timer and the layout editor all enabled 8)
if anyone is interested i can also attach the patch required to make this build that includes the makefile and target-defs changes as well as the switch patch, let me know if you want it.
//Updated build to 6ba8eab january 18th 2014
Last edit: 19 Jan 2014 17:37 by HappyHarry.
05 Jan 2014 22:38 #18024 by blackmoon
Replied by blackmoon on topic 7e, 4.0.1, +1x3way +telem +layout ed +perm timer
Did you use a VM, or linux box to build this ?
If so I'm interested in your files (and a link to the VM).
If it's windows, not much I don't want to install the cross compiler environment (I'm lazy) :p
05 Jan 2014 22:51 #18026 by HappyHarry
Replied by HappyHarry on topic 7e, 4.0.1, +1x3way +telem +layout ed +perm timer
i used a permanent overlay enabled liveusb of xububtu 12.04lts, but you could easily setup a vm with the same release, i did it this way as my laptop is slow when using a vm with a full xwindows install, (and for some reason i couldn't get summon-arm to work on fedora which i have installed on the laptop as one of the quad boot options) you could also use xubuntu13.10 and make it work
05 Jan 2014 23:06 - 05 Jan 2014 23:14 #18027 by HappyHarry
here is the patch, be aware that this patch also includes the changes needed in the makefile's, the target-defs file and the 1x3way patch. all you need to do is have one of the newer versions (4-8-2013q3 or 4.8.2013q4) of the gcc-arm-embedded compiler installed then patch the deviation source using this file, and build it :)
Last edit: 05 Jan 2014 23:14 by HappyHarry.
05 Jan 2014 23:09 #18028 by Daryoon
Thanks for the builds HappyHarry. It saves me from staying up to date, patching and building. Since my setup is the same as yours. I'll just use the build you make. :)
05 Jan 2014 23:20 #18029 by HappyHarry
no problems daryoon :), i was building them for myself (3way) and a freind (2way) anyway, so it's hardly any bother to upload and share them for others
plus i only decided to try the 7e and deviation due to your posts on rcg, and i used your page for instructions on fitting the nrf module, so it's only fair i help save you some time :)
06 Jan 2014 09:05 #18056 by blackmoon
Thank you Harry.
06 Jan 2014 09:28 - 06 Jan 2014 10:49 #18058 by dianjing
thank you for your new fireware.
my 7e doesn't need any telem option
i also wait for 2*3 way fireware.
thank you
Last edit: 06 Jan 2014 10:49 by dianjing.
06 Jan 2014 20:38 #18100 by HappyHarry
if you don't need telemetry then then don't install this build, use one of my earlier builds without telemetry instead ;)
also as you have already been informed i am not capable of the code changes required to add the 2 x 3way switch changes to deviation, there is another member who is working on it in his own free time and if/when it becomes available i will make a build and upload it, but that doesn't have a fixed time frame, and may never happen at all, so like myself and others you will just have to wait and see what happens in the future
either that or i'm sure pb will accept working patches ;)
08 Jan 2014 00:28 #18170 by dc59
I also need 2x3way switch for Devo7e , Thanks ~~~ :woohoo:
(my 2x 3way switch modified with Galee's version,can it work?)
13 Jan 2014 07:27 - 28 Jan 2014 22:03 #18460 by jamiedg
Many thanks for this 7e build B)
I need the 3-way switch to try on my DJI Naza Lite. Will report back when I get all the parts and stuff sorted.
Update: Success :)
can confirm this is working fine on my TBS Discovery with DJI Naza Lite.
FMode 0 -77 Normal
Fmode 1 +5 Attitude
FMode 2 +90 GPS
AIL DR1 +45 FailSafe
Will give more info on Naza post.
Since I stated on this we now have the 2x3way switch mod B)
Last edit: 28 Jan 2014 22:03 by jamiedg. Reason: Update:
13 Jan 2014 07:58 #18462 by blackmoon
Finally did the 3-way mod and nrf2401 to my devo7E, and installed your build, works like a charm.
Thanks Harry.
14 Jan 2014 21:07 #18508 by HappyHarry
no probs, glad it was of some use :)
16 Jan 2014 12:05 #18561 by dianjing
thank you
18 Jan 2014 18:28 - 18 Jan 2014 18:29 #18642 by Daryoon
HappyHarry wrote: Thanks to a heads up by domcars0 about the changes in the latest gcc-arm-none compiler (this thread here>> deviationtx.com/forum/7-development/2547...-and-devo7e-features ) we can now build for the 7e with all options enabled B)
I just downloaded the zip available in the first post. I don't see a dfu file to flash. Could you double check and tell me I am crazy?
Thanks you.
-Daryoon
Last edit: 18 Jan 2014 18:29 by Daryoon.
18 Jan 2014 18:54 #18643 by domcars0
I think that deviation-devo7e-v4.0.1-dec2d0b.dfu is a dfu file ... or am I crazy? ;)
18 Jan 2014 20:27 #18644 by Daryoon
Ooops, sorry. Must have been an interruption in my extraction process the first time around. I didn't get the dfu file, hence the question.
But you're right. It's in the zip file and extracted fine the second time around. :oops:
18 Jan 2014 21:12 #18645 by HappyHarry
no worries, just a quick note i just updated the build to the latest code >> 6ba8eab, zip is in the first post :)
19 Jan 2014 00:29 #18650 by Daryoon
Could you make any sense of what PB means by switches here?
deviationtx.com/forum/7-development/1594...dule?start=120#18641
Is the switch patches somehow added to the main repo?
19 Jan 2014 14:50 #18682 by kreidler
Daryoon wrote: Could you make any sense of what PB means by switches here?
No. May be later on. This post is regarding switching between TX modules.
Time to create page: 0.425 seconds
