7e, Nightly 18th jan, +1x3way +all
- HappyHarry
so find attached a build of tonights code for the 7e with the 1 x 3way switch patch, also with telemetry, permanent timer and the layout editor all enabled
if anyone is interested i can also attach the patch required to make this build that includes the makefile and target-defs changes as well as the switch patch, let me know if you want it.
//Updated build to 6ba8eab january 18th 2014
- blackmoon
If so I'm interested in your files (and a link to the VM).
If it's windows, not much I don't want to install the cross compiler environment (I'm lazy)
- HappyHarry
- HappyHarry
- Daryoon
- HappyHarry
plus i only decided to try the 7e and deviation due to your posts on rcg, and i used your page for instructions on fitting the nrf module, so it's only fair i help save you some time
- blackmoon
- dianjing
my 7e doesn't need any telem option
i also wait for 2*3 way fireware.
thank you
- HappyHarry
also as you have already been informed i am not capable of the code changes required to add the 2 x 3way switch changes to deviation, there is another member who is working on it in his own free time and if/when it becomes available i will make a build and upload it, but that doesn't have a fixed time frame, and may never happen at all, so like myself and others you will just have to wait and see what happens in the future
either that or i'm sure pb will accept working patches
- dc59
(my 2x 3way switch modified with Galee's version,can it work?)
- jamiedg
I need the 3-way switch to try on my DJI Naza Lite. Will report back when I get all the parts and stuff sorted.
Update: Success
can confirm this is working fine on my TBS Discovery with DJI Naza Lite.
FMode 0 -77 Normal
Fmode 1 +5 Attitude
FMode 2 +90 GPS
AIL DR1 +45 FailSafe
Will give more info on Naza post.
Since I stated on this we now have the 2x3way switch mod
- blackmoon
Thanks Harry.
- HappyHarry
- dianjing
- Daryoon
HappyHarry wrote: Thanks to a heads up by domcars0 about the changes in the latest gcc-arm-none compiler (this thread here>> deviationtx.com/forum/7-development/2547...-and-devo7e-features ) we can now build for the 7e with all options enabled
I just downloaded the zip available in the first post. I don't see a dfu file to flash. Could you double check and tell me I am crazy?
Thanks you.
-Daryoon
- domcars0
- Daryoon
But you're right. It's in the zip file and extracted fine the second time around.
- HappyHarry
- Daryoon
deviationtx.com/forum/7-development/1594...dule?start=120#18641
Is the switch patches somehow added to the main repo?
- kreidler
No. May be later on. This post is regarding switching between TX modules.Daryoon wrote: Could you make any sense of what PB means by switches here?
Builds
- 7e, Nightly 18th jan, +1x3way +all
