7e, Nightly 18th jan, +all
05 Jan 2014 20:34 - 19 Jan 2014 19:53 #18018 by HappyHarry
7e, Nightly 18th jan, +all was created by HappyHarry
Thanks to a heads up by domcars0 about the changes in the latest gcc-arm-none compiler (this thread here>> deviationtx.com/forum/7-development/2547...-and-devo7e-features ) we can now build for the 7e with all options enabled B)
so find attached a build of tonights code for the 7e, with telemetry, permanent timer and the layout editor all enabled 8)
if anyone is interested i can also attach the patch required to make this build that includes the makefile and target-defs changes, let me know if you want it.
//updated to latest code on january 18th >> 6ba8eab
Last edit: 19 Jan 2014 19:53 by HappyHarry.
18 Jan 2014 21:19 - 19 Jan 2014 19:55 #18647 by HappyHarry
Replied by HappyHarry on topic 7e, 4.0.1, +telem +layout ed +perm timer
updated the build in the op to the latest code on january 18th >> 6ba8eab
also this post will now track the code and be updated weekly, the 4.0.1 version can now be found in this post here >> www.deviationtx.com/forum/builds/2637-7e...layout-ed-perm-timer
Last edit: 19 Jan 2014 19:55 by HappyHarry.
21 Jan 2014 09:28 #18823 by dianjing
Replied by dianjing on topic 7e, Nightly 18th jan, +all
did it run in 1*3way and 1*2way sw?
21 Jan 2014 09:31 #18824 by dianjing
thank HappyHarry for your software.
do you test the distance of 7e? i have tested it only about 200meter.
use 150mw.
does it normally??
21 Jan 2014 09:43 - 21 Jan 2014 10:58 #18826 by HappyHarry
Replied by HappyHarry on topic 7e, Nightly 18th jan, +all
no problem, this is just the stock deviation with all options available, it doesn't have any of the switch patches, but with pb's latest work those patches will no longer be required.
I have not range tested past 200m as I currently only use my 7e for flying heli's up to 250 size, and I don't need more distance for those, but with the range mod and 150mw I'd expect more than 200m line of sight. which module are you testing that only gets 200m?
Last edit: 21 Jan 2014 10:58 by HappyHarry.
22 Jan 2014 10:18 #18911 by dianjing
devo receive rx601, test 200meter
22 Jan 2014 13:39 #18915 by HappyHarry
isn't the 601 a 'parkflyer' rx as in short range only?
also how did you do the range mod? did you remove the diode and replace it with a piece of wire? or did you use another method?
22 Jan 2014 22:49 #18951 by HappyHarry
due to phracturedblue's great work, from tonights nightly build onwards these builds will be no longer needed so they wont be updated.
please see this thread for all future updates >>
www.deviationtx.com/forum/builds/2661-7e...weekly-updates#18950
Time to create page: 0.686 seconds
