7e +telem +layout ed +perm timer, weekly updates
02 Feb 2014 18:49 #19715 by SeByDocKy
Replied by SeByDocKy on topic 7e +telem +layout ed +perm timer, weekly updates
I just installed the last Nightly Build and I observed the same problem ...
Of course I updated correctly hardware.ini according to my former tx.ini....
02 Feb 2014 19:07 #19719 by HappyHarry
Replied by HappyHarry on topic 7e +telem +layout ed +perm timer, weekly updates
your TX shouldn't be making noise no matter what output power you set in the menu so I wouldn't worry about that.
also as I mentioned the last build included changes in the protocol channel mapping, in that the TX changes the channels to match the protocol automatically, could this be the issue you are having? if not can you explain in more detail what is actually hapening/going wrong.
I will be updating the build in the next hour or so, so perhaps wait for that and see if there is still the same issues.
02 Feb 2014 19:09 #19720 by SeByDocKy
HappyHarry wrote: your TX shouldn't be making noise no matter what output power you set in the menu so I wouldn't worry about that.
Does it means that all former models have to be updated ?
02 Feb 2014 19:36 #19723 by HappyHarry
i think it will only affect new models, unless you scroll through the protocols in a current model.
what exactly is happening with your quad? also what type of quad and protocol?
02 Feb 2014 19:36 #19724 by PhracturedBlue
Replied by PhracturedBlue on topic 7e +telem +layout ed +perm timer, weekly updates
a) no you shouldnt' need to update existing models.
b) did you update your hardware.ini file with your modules?
02 Feb 2014 19:39 - 02 Feb 2014 19:55 #19725 by SeByDocKy
PhracturedBlue wrote: a) no you shouldnt' need to update existing models.
Yes of course ....
For example, now for my V2x2, it seems the scale have changed and there is a small trim introduced turning left .....
EDIT :
Problem solved !!!!!!
Need a recalibration .... and works perfectly :) sorry for false alert ...
(anyway good to know that with last changed with channel remappping, a recalibration can be necessery)
Last edit: 02 Feb 2014 19:55 by SeByDocKy.
02 Feb 2014 19:54 - 02 Feb 2014 19:55 #19730 by HappyHarry
have you re-calibrated your TX, and also your quad's flight board? do you have a motor on the way out? as I don't think trims or dual rates/travel adjust will be effected in this way
Last edit: 02 Feb 2014 19:55 by HappyHarry.
02 Feb 2014 19:56 #19731 by SeByDocKy
HappyHarry wrote: have you re-calibrated your TX, and also your quad's flight board? do you have a motor on the way out? as I don't think trims or dual rates/travel adjust will be effected in this way
Yes ... it was the trick to do ;)...
02 Feb 2014 20:04 #19734 by HappyHarry
it's a good idea to recalibrate your tx every time after flashing the firmware ;)
02 Feb 2014 20:39 - 02 Feb 2014 20:42 #19738 by HappyHarry
ok it's update time :) the new build is in the first post and is built up to commit c8a2363 added this week is more configuration items for the auto channel mapping, in that other areas are also auto updated, and also added is sbsntp's small gui for the 7e and 10, see here for info >> www.deviationtx.com/forum/7-development/...-ui-updated-1st-post and here for configuration options >> www.deviationtx.com/forum/custom-skins/2...devo-7e-10-reference
as always report here or on bitbucket if you find a bug :)
Last edit: 02 Feb 2014 20:42 by HappyHarry.
09 Feb 2014 23:01 #20041 by HappyHarry
Update time again, new build is in the OP, there are very little changes this week, just changes on when the bind dialogue for the WK* protocols is shown, and also enabling channel re-ordering on the mixer page. i have also attached a build of the emulator (linux version) in the OP after some requests for it by PM.
as always if you find an issue post here or post a bug on bitbucket :)
09 Feb 2014 23:21 - 09 Feb 2014 23:23 #20042 by blackmoon
Replied by blackmoon on topic 7e +telem +layout ed +perm timer, weekly updates
Do the wk protos work again ?
Because I filed a ticket about it.
Edit: It's based on latest nightly, I have it on my devo7e and wk2401 doesn't work.
Last edit: 09 Feb 2014 23:23 by blackmoon.
09 Feb 2014 23:47 #20044 by HappyHarry
no they don't, but these are the only commits since last week, and before last week the wk* protocol binding screens weren't working properly either.
I've posted before that my builds are based on the nightlies, and in particular what the latest code is in pb's bitbucket at the time I build. the only difference is that I enable the layout editor and the permanent timer
10 Feb 2014 06:47 - 10 Feb 2014 06:48 #20052 by Shanman3us
Replied by Shanman3us on topic 7e +telem +layout ed +perm timer, weekly updates
HappyHarry wrote: ok it's update time :) the new build is in the first post and is built up to commit c8a2363 added this week is more configuration items for the auto channel mapping, in that other areas are also auto updated, and also added is sbsntp's small gui for the 7e and 10, see here for info >> www.deviationtx.com/forum/7-development/...-ui-updated-1st-post and here for configuration options >> www.deviationtx.com/forum/custom-skins/2...devo-7e-10-reference
HappyHarry wrote: i have also attached a build of the emulator (linux version) in the OP after some requests for it by PM.
Thanks for including the linux emu file on the OP now. I like toying with the emulator. It helped me find out that I had a trim control on my 7e that wasn't working porperly. If I didn't have the emulator I might not have known for some time. As it turns out there was a wire broken on the Throttle trim Up and many model.ini's don't use that particular trim as originally intended.
I also really like working with the layouts screen on the emulator instead of killing my Tx battery :blink:
Shanman3us
Last edit: 10 Feb 2014 06:48 by Shanman3us.
10 Feb 2014 20:16 #20091 by HappyHarry
Build in the OP updated, as the binding problems with the WK* protocols was fixed in an update today :)
new build is ac641d3
11 Feb 2014 03:22 #20112 by dianjing
sometimes the trim will move automatic.
can you help me to solve this problem.
11 Feb 2014 03:24 #20113 by dianjing
i use it with gale fireware it did not happen.
i think the diode is ok.
maybe the fireware has some bug.
11 Feb 2014 03:27 #20114 by dianjing
the 7e works well when i use gale's fireware .
i think the diodes is good .
11 Feb 2014 11:57 #20124 by HappyHarry
when exactly does the trim move? as I and others are not experiencing this issue, so please explain exactly what you are doing and how your model.ini is set up, and what position your switches are in when the trim moves itself. otherwise we can't try to reproduce the issue.
16 Feb 2014 22:28 - 16 Feb 2014 22:29 #20408 by HappyHarry
Ok guys update time again, this week only one commit was made, this added a new protocol for the syma X4 and X6 multirotors and also some changes to the existing yd717 protocol, but as this brings the current build size to
ROM: 0x08003000 - 0x0801fff4 = 115.99kB
RAM: 0x20000000 - 0x20002464 = 9.10kB
unfortunately this may be the last build possible with all the functions enabled as 116kB is the limit for the 7e.
latest build is in the OP and as usual post any bugs or problems here or on bitbucket
Last edit: 16 Feb 2014 22:29 by HappyHarry.
Time to create page: 0.371 seconds
