Nightlies from team deviationTx
07 Jan 2015 23:52 #27563
Nightlies from team deviationTx was created by mwm
I've started nightly builds from the team deviationTx repository. So far, the changes are minor, but I'm hoping more developers will at least issue pull requests.
You can download them from GDrive .
24 Jan 2015 03:40 #27956
Replied by mwm on topic Nightlies from team deviationTx
I've moved those off a VM to a real machine that can send mail. I'd now like to make the log results available either to the public or to the developers - at least if they fail. Bitbucket doesn't support mail to team members, which would be the easy way.
Anyone have suggestions about where to put these things? I can host a mail list if anyone is interested. Or arrange to post them to my blog. Not clear that keeping them permanently is such a good idea, but it's possible. Any other suggestions?
- dado099
09 Mar 2015 09:36 #29482
by dado099
Hi, repository is empty from some days ago, is it normal ?
Replied by dado099 on topic Nightlies from team deviationTx
mwm wrote: You can download them from GDrive .
- Indigo
- Cereal_Killer
10 Mar 2015 15:53 - 10 Mar 2015 15:55 #29526
by Cereal_Killer
Replied by Cereal_Killer on topic Nightlies from team deviationTx
EDIT: SOLVED! Only the newest 2 are available.
Thanks for all the work!
While they're listed there none are available to d/l. I was looking to update to the newest nightly for me 7E (I also tried the 10 version and got the same error)
Indigo wrote: The nightly builds from deviationTx are now available here:
Nightly builds
Message
Error while downloading file File not found on server
Last edit: 10 Mar 2015 15:55 by Cereal_Killer.
10 Mar 2015 17:53 #29528
Replied by PhracturedBlue on topic Nightlies from team deviationTx
Please link a specific file that didn't work for you. Each file I've tried to download has worked fine.
- d3relict
20 Dec 2015 15:59 #41056
by d3relict
Replied by d3relict on topic Nightlies from team deviationTx
hi,
i don't know where to report this, but all recent nightlies fail on devo 12, after entering usb mode, there is no way to turn it off, just powering off the thx. also, the calibration panels are displayed as simple text on the top-left corner of the display instead of a popup panel.
- aperseghin
07 Feb 2016 21:55 #42745
by aperseghin
Replied by aperseghin on topic Nightlies from team deviationTx
I had a similar issue with them also,
I used dfuse to reflash the DSU file from the nightly and then copied the filesystem over, then copied over my saved model / icon/whatever data and all worked fine
- aperseghin
08 Feb 2016 17:14 #42783
by aperseghin
deviationtx.com/forum/7-development/5370...0d-usb-wont-turn-off
My initial fix is not a fix. it only worked because I reflashed the 4.0.1
this issue has been reported for many users across the range of transmitters
- Maxner
10 Feb 2017 07:55 #59022
by Maxner
Replied by Maxner on topic mistakes channel AIL and ELE on Devo7e
Hello, I have read
here
of the problem, which I can understand also on my Devo7e. Is the bug fixed in the current Nightly Builds version?
Thank you for your feedback
- Fernandez
22 Feb 2017 22:51 #59489
by Fernandez
Replied by Fernandez on topic Nightlies from team deviationTx
How can we get back into some older nightlies, I want to experiment test with old Frsky X version, some builds starting from around end of November, but I do not know were to find or download them.
23 Feb 2017 02:37 #59495
We don't archive the nightly builds beyond the three in downloads. You need to either build them yourself or have someone build them and upload them. For what this sounds like - tracking down when a bug appeared - your are liable to need several builds, so building them yourself will be a lot quicker. The official method is to use the docker images.
- Thomas.Heiss
23 Feb 2017 10:56 #59511
by Thomas.Heiss
You are thread hijacking!
Heli? No, not that I would know, as there are multiple places in the C code + multiple templates for different use cases.
Neither in the C code nor in the 5.0 + nightly heli templates.
Use one of my provided heli templates - my plan was to update a newer FBL only template (without Virt1-Virt3), but I have to do some further testing.
You should not use the nightlies anyways, use Vlad's 5.0 stable test build (with latest protocols).
I was testing DSMx, which works fine.
Please use a heli thread to discuss further your needs and problems (e.g CCPM120).
Replied by Thomas.Heiss on topic mistakes channel AIL and ELE on Devo7e
Maxner wrote: Hello, I have read here of the problem, which I can understand also on my Devo7e. Is the bug fixed in the current Nightly Builds version?
Time to create page: 0.111 seconds
Builds
- Nightlies from team deviationTx
