Deviation v5.0.0 build with latest protocols
12 Oct 2016 19:03 - 13 Oct 2016 16:05 #54860 by vlad_vy
Replied by vlad_vy on topic Deviation v5.0.0 build with latest protocols
Fixed "white background in the boxes on the main screen flashes bands of dark color each time digits change value".
Firmware DFU file only, you can get other components from official v5.0.0 release.
Files deleted, see below
Last edit: 13 Oct 2016 16:05 by vlad_vy.
13 Oct 2016 16:07 - 15 Oct 2016 06:24 #54890 by vlad_vy
Adding a user option to disable Auto-Acknowledge on the YD717 protocol - Auto Ack was causing lag and issues with the 4-in-1 module and the SymaX4 Protocol.
NathanBarguss
(13.10.2016) Firmware DFU file only, you can get other components from official v5.0.0 release.
Last edit: 15 Oct 2016 06:24 by vlad_vy.
14 Oct 2016 20:18 - 14 Oct 2016 20:19 #54927 by kaligola
Replied by kaligola on topic Deviation v5.0.0 build with latest protocols
i have just a toy , hubsan x4 old model clone that binds with this YD717 protocol but acts weird, laggy and sometimes makes radio stuck.
are this dfu files and protocol folder intended to use with 5.0.0 and not nightly builds rigth? im little newbie forgive stupid questions
regarding dsmx few posts back, i use but no with telemetry so cannot give this kind of feedback, sure it works with dsmx-dsm2 satellite receivers, even the cheap sold at bangood
Last edit: 14 Oct 2016 20:19 by kaligola.
14 Oct 2016 20:27 - 14 Oct 2016 20:28 #54928 by aMax
What did vlad_vy post?
" Firmware DFU file only, you can get other components from official v5.0.0 release. "
Last edit: 14 Oct 2016 20:28 by aMax.
14 Oct 2016 21:06 #54932 by HappyHarry
Replied by HappyHarry on topic Deviation v5.0.0 build with latest protocols
he posted the only dfu/firmware, you need to download a stock 5.0.0 release for your tx model and grab the file system contents to use with it
15 Oct 2016 05:47 - 15 Oct 2016 05:53 #54946 by vlad_vy
The protocol code mostly independent from main code so it can work with any release, except protocols with telemetry. So, changes at v5.0.0 are related to protocols with telemetry.
Can you say if your hubsan x4 old model clone that binds with this YD717 protocol work fine with nightly build? And, what transmitter do you use? Devo7e?
Last edit: 15 Oct 2016 05:53 by vlad_vy.
15 Oct 2016 06:26 - 15 Oct 2016 10:39 #54947 by vlad_vy
Fixes for Frsky S.Port and Hub telemetry (#47)
* Fix minimum cell value calculation
* Remove scale multiplier for RPM and report raw value. Need to add ability for multiplier for displayed value.
* Remove multiplier for fuel telemetry value. Documentation says should be percentage number 0-100.
* Fix GPS scaling for altitude and speed values. Fix GPS time display where hours and minute values were swapped.
* Add define for 7e build
* Remove scaling from RPM and report raw sensor value
* Fix interpretation of telemetry value for CELL voltages
* Improve minimum cell algorithm for hub telemetry
hexfet
(15.10.2016) Firmware DFU file only, you can get other components from official v5.0.0 release.
www.deviationtx.com/downloads-new/category/398-deviation-5-0-0
Last edit: 15 Oct 2016 10:39 by vlad_vy.
15 Oct 2016 06:45 - 15 Oct 2016 08:29 #54948 by kaligola
this model
www.deviationtx.com/forum/model-requests...3-mini-spider-himoto
it binds but laggy and is unflyble. must try this dfu
have devo 7e with a7105 pa and Nrf24l01
update, choosing use A.ACK:no is ok for me
now must configure model, should make reverse thr channel and range, but at least im on the way with binding correct without lag
thanks
auto ack once binded must be set to no.
Last edit: 15 Oct 2016 08:29 by kaligola.
15 Oct 2016 09:04 - 15 Oct 2016 09:06 #54954 by Thomas.Heiss
Replied by Thomas.Heiss on topic Deviation v5.0.0 build with latest protocols
vlad_vy wrote: Thomas,
Devo10 build without Flight Log filtering (05.10.2016):
File deleted
You are way too fast Vlad :-)
I just have the zip of version 04.10.16 8:40 without new channel code which went into 05.10.16.
For in-flight glider tests I am still on version 07.10.16 which included first FlightLog filtering (which does not filter total of >510 FrameLosses per se).
Will do some 100uw ground tests with FlightLog version 12.10.16.
I fear the new code might even not be able to display ~1500 FrameLosses (total 1:1 from RX) anymore - need to test with 100uw. Should not happen in-flight 100mw anyways...
Probably just my lack of basic understand how the (new) received F (RX) and previous received/displayed F are related together...I believe I somehow understood the 1st filtering implementation...
Thomas
Last edit: 15 Oct 2016 09:06 by Thomas.Heiss.
15 Oct 2016 09:14 - 15 Oct 2016 09:24 #54955 by vlad_vy
Current received Frame Losses and previous Frame Losses used for unrestricted growth of Frame Losses. But, at real flight unlikely that it can be higher than 300. Moreover, any Hold state will subtract 45 from real Frame Losses.
So, last implementation of Flight Log filtering use next fixed thresholds:
15 - for Hold
255 - for base Rx Fades (it can't be higher)
510 - for Frame Loss
Last edit: 15 Oct 2016 09:24 by vlad_vy.
15 Oct 2016 10:38 - 18 Oct 2016 05:38 #54959 by vlad_vy
After some additional testing I revert back to first version DSM2/X protocol telemetry "Flight Log" filtering, with minor corrections.
P.S. I can't fit "Flight Log" filtering to devo7e build, so it cut out from code for Devo7e. Sorry...
Last edit: 18 Oct 2016 05:38 by vlad_vy.
15 Oct 2016 10:45 #54961 by bianchifan
Replied by bianchifan on topic Deviation v5.0.0 build with latest protocols
vlad_vy wrote: OK, see below, "devo7e-256" added to other builds.
Thank you very much!
But sadly it shows the same issue as with other compilations:
Missing Modules: CY... :(
16 Oct 2016 18:31 - 16 Oct 2016 18:42 #55016 by Thomas.Heiss
Thomas.Heiss wrote: III) New in-flight firmware test - 4 lipos (about 15-40 minutes per flight) - with Vlad's test build zip/dfu version dated 10/07/2016 with
- telemetry frozen fix "CYRF_06_RX_CFG, 0x48": www.deviationtx.com/forum/protocol-devel...rrors?start=20#54584
- new mentioned 7CH re-write DSMx protocol code
- including FlightLog filtering code from #54690 www.deviationtx.com/forum/builds/6407-de.../54562?quote=1#54690
with
- Devo10
- Spektrum AR6210 (6CH setting)
- Spektrum TM1000 (works fine - not corrupt)
- 100mw output power
- EPO glider (explicitly tried to fly higher + more far away - as far as I could see the 2,2m wing glider)
with
- 0 Holds
- <10 FrameLosses: checked 4 times (4 lipos) and it showed ~8F max., so far below 20F, quite good!
Telemetry monitor in this build is again rocking stable so far for me - just like release V5.0.0 + V4.01-nightly-build-fcd0669.
Checked the monitor multiple times "live" during flight, checked monitor FlightLog values after landing on each flight of the four.
Not freezed / fields black/inverted any time!!
TX transmit code rocking stable as in every Deviation version (no deadlocks, no holds, no >40F) before. Always full steering control at any time.
Had another 6-7 flight times on version 10/07/2016, which FlightLog filtering is very much comparable to latest filtering code version 15.10.2016.
Maybe another ~2-4 single flights more than that.
Glider flight time per lipo not below 15-20 minutes.
So at least ~10-11 (12-15) successful DSMx flights in total.
Works superb!
Last edit: 16 Oct 2016 18:42 by Thomas.Heiss.
17 Oct 2016 11:44 #55045 by Leo Li
vlad_vy wrote: After some additional testing I revert back to first version DSM2/X protocol telemetry "Flight Log" filtering, with minor corrections.
Thank you for your great work, can you also make a build for devo7e-256 ?
17 Oct 2016 13:07 - 18 Oct 2016 05:38 #55049 by vlad_vy
v5.0.0 devo7e-256 remains behind from nightly builds. It's has not "Flight Log" filtering. Moreover, I sent pull request for new version of DSM2/X protocol to main repository.
github.com/DeviationTX/deviation/pull/52
File deleted, see below
17 Oct 2016 14:14 #55051 by Leo Li
Thank you
18 Oct 2016 05:41 - 25 Oct 2016 04:35 #55082 by vlad_vy
Added DSM2/X protocol option "F.Log filter", by default "Flight Log" filtering is disabled.
P.S. I can't fit "Flight Log" filtering to devo7e build, so it cut out from code for Devo7e (Devo7e-256). Sorry...
(18.10.2016) Firmware DFU file only, you can get other components from official v5.0.0 release.
Last edit: 25 Oct 2016 04:35 by vlad_vy.
25 Oct 2016 04:37 - 26 Oct 2016 15:35 #55365 by vlad_vy
Added JXD-506 format option to V202 protocol
goebish
(25.10.2016) Firmware DFU file only, you can get other components from official v5.0.0 release.
Last edit: 26 Oct 2016 15:35 by vlad_vy.
26 Oct 2016 08:12 - 26 Oct 2016 08:12 #55395 by vlad_vy
Can anybody to test Nine Eagles "j6pro" protocol? I would like to fix error and to do some code clean up, but I can't test it.
Last edit: 26 Oct 2016 08:12 by vlad_vy.
26 Oct 2016 15:39 - 29 Oct 2016 10:18 #55405 by vlad_vy
Added protocol for JJRC H26WH (MJXq protocol option)
Added protocol for Turnigy / Flysky AFHDS 2A receivers
goebish
(26.10.2016) Firmware DFU file only, you can get other components from official v5.0.0 release.
Last edit: 29 Oct 2016 10:18 by vlad_vy.
Time to create page: 0.337 seconds
