Deviation v5.0.0 build with latest protocols
- Toolbox1211
12 Mar 2019 23:43 - 12 Mar 2019 23:45 #73325
by Toolbox1211
Replied by Toolbox1211 on topic Deviation v5.0.0 build with latest protocols
Will the fixed also be in the nightlys? I Just installed the dfplayer and i would miss it lol
Last edit: 12 Mar 2019 23:45 by Toolbox1211.
13 Mar 2019 04:31 #73329
Replied by vlad_vy on topic Deviation v5.0.0 build with latest protocols
It will be fixed in the nightly build, pull request placed 5 days ago.
- clips
16 Mar 2019 11:26 - 16 Mar 2019 11:28 #73388
by clips
Replied by clips on topic Deviation v5.0.0 build with latest protocols
why T8SG V2 plus can't bind E010?...I try to update the lastest firm and LCD blank?...whats wrong with T8SG V2?...and I back to default firm LCD Normal, what the protocol E010 in T8SG V plis anyone can help me please
Last edit: 16 Mar 2019 11:28 by clips.
- OrbitalGolem
04 Apr 2019 03:05 - 04 Apr 2019 03:07 #73678
by OrbitalGolem
Replied by OrbitalGolem on topic Deviation v5.0.0 build with latest protocols
Quick question about the OrangeRx option in DSMX. On one of my Orange receivers, an R110X, I notice that the LED flickers rapidly when the OrangeRx setting is disabled and the model is bound. There's no flicker if the setting is enabled. I don't think it flickered with Deviation 3.0. Is this expected behavior?
Also, is HighSpeed (11 ms) supported on this Orange receiver?
Also, is the OrangeRx option needed for LemonRx receivers?
Many thanks in advance.
Last edit: 04 Apr 2019 03:07 by OrbitalGolem.
04 Apr 2019 05:06 - 04 Apr 2019 05:07 #73681
OrangeRX protocol option correct the error at PN codes table that exist at most third party DSM receivers. You not always will meet with this error, it depends from transmitter ID, Fixed ID and RF channel. If you see that receiver LED flickers rapidly with DSMX protocol (or you can't bind with DSM2 protocol), you definitely meet with that error and you need to use "OrangeRX" protocol option.
About HighSpeed (11 ms) and Orange receiver I don't know, but most original Spectrum >7 channels receivers support HighSpeed (11 ms).
Last edit: 04 Apr 2019 05:07 by vlad_vy.
- 52dgj
12 Apr 2019 08:04 #73832
by 52dgj
Replied by 52dgj on topic Deviation v5.0.0 build with latest protocols
12 Apr 2019 08:41 #73833
Why not? You need to build custom "devo12-lib.dfu" from devo12 emulator filesystem "media" folder.
www.deviationtx.com/forum/custom-skins/2...-lib-dfu-for-themers
I'm not sure that it will work for nightly builds.
- 52dgj
12 Apr 2019 10:44 #73849
by 52dgj
12 Apr 2019 11:27 - 12 Apr 2019 11:28 #73852
I think that something missing at library builder. Try to place "scripts" folder inside "MkDevo12Lib.exe" folder. And place "library.zip" file (do not unzip it) inside "scripts" folder. I can't send such big *.zip file to forum.
Last edit: 12 Apr 2019 11:28 by vlad_vy.
- 52dgj
12 Apr 2019 16:03 #73856
by 52dgj
Thank you very much, I have successfully built the LIB file.
- Martin109
17 Apr 2019 16:14 #73959
by Martin109
Replied by Martin109 on topic Deviation v5 builds on Devo 12S only black screen
I installed the DFplayer mini in my DEVO12S. In order to put this into operation then I wanted to install one of the current Nightly builds.
Can also install easily.
But no matter which nightly build I try it, it's always the same problem that always only turns black screen when you turn it on.
After that, the transmitter can not be switched off.
What am I doing wrong?
If I install the 5.0 final firmware everything goes again. But that's not with the DFplayer.
Regards Martin
Regards Martin
18 Apr 2019 03:48 #73980
Replied by vlad_vy on topic Deviation v5 builds on Devo 12S only black screen
Nightly build have massive changes now and that introduced some bugs. You need wait some time until these bugs will be fixed.
- OrbitalGolem
18 Apr 2019 13:18 - 26 Apr 2019 03:22 #73992
by OrbitalGolem
Thanks again Vlad for all of your efforts to keep this particular branch of Deviation stable, in light of the instability of the nightly build. For folks like me who prefer the older GUI with the latest protocol changes, your builds have been extremely useful. My update from 3.0 to your latest build above didn't have a single issue and all of my models have stayed in the air.
Last edit: 26 Apr 2019 03:22 by vlad_vy.
14 May 2019 05:49 - 23 Aug 2019 04:39 #74306
"Deviation v5.0.0 build with latest protocols" (based on v5.0.0 release core)
* [Bugs3Mini] Fix flips, from goebish
* Protocol for TDR Phoenix Mini, from goebish
* E016H protocol, add calibration flag, from goebish
* Protocol bugs3mini dynamically driven trims, from goebish
* Add Bugs 3H format option, from goebish
* Add DHD D4 and H8S 3D formats, from goebish
(14.05.2019)
Files deleted, see below...
Fix flip channel* Protocol for TDR Phoenix Mini, from goebish
* Attempt adding arm channel for TDR Phoenix micro quad
* Fix bitrate
* Add arm flag
* Set high rate
* Set high rate (was medium)* E016H protocol, add calibration flag, from goebish
Add calibration flag for E016H format.
Works same as stock controller, set both sticks to external bottom corners to start accelerometer calibration.* Protocol bugs3mini dynamically driven trims, from goebish
Add some rocket fuel to the Bugs3Mini
https://www.deviationtx.com/forum/protocol-development/7850-bugs-3-mini?start=200#73889* Add Bugs 3H format option, from goebish
Add Bugs 3H format option to Bugs3Mini protocol
Channel 10: Altitude hold* Add DHD D4 and H8S 3D formats, from goebish
Add DHD D4 and H8S 3D format options to Bayang protocol(14.05.2019)
Last edit: 23 Aug 2019 04:39 by vlad_vy.
14 May 2019 05:51 - 23 Aug 2019 04:40 #74307
I can't attach more than 10 files, and so XMS builds attached with separate message
(14.05.2019)
(14.05.2019)
Last edit: 23 Aug 2019 04:40 by vlad_vy.
14 May 2019 05:53 - 23 Aug 2019 04:40 #74308
Fresh emulator builds
(14.05.2019)
(14.05.2019)
- SirDomsen
23 May 2019 11:12 #74381
by SirDomsen
Replied by SirDomsen on topic Deviation v5.0.0 build with latest protocols
Thanks Vlad_vy for posting your custom version. I can't seem to get the nightlies to work on my 12e, see also here .
Your version works like a charm! One minor question: Once telemetry low voltage alert is triggered (on Bayang telemetry protocol), the screen changes to telemetry display. That's a bit annoying because I for sure have low voltage alerts on full throttle. Could this be avoided? Am I doing something wrong or is there a setting I have overlooked?
Cheers
Domsen
Cheers
Domsen
23 May 2019 13:09 #74382
I don't know why it happened, it may be by design. I always have telemetry voltage box on Main screen and low voltage alert never change screen to telemetry screen.
- old4570
31 Jul 2019 13:39 #74814
by old4570
Replied by old4570 on topic Deviation v5.0.0 build with latest protocols
So what file does what ? ( How do you tell them apart ? )
- Gerry
- Bbrad
31 Jul 2019 23:44 #74817
by Gerry
FFS (Forever Fixing Stuff)
Replied by Gerry on topic Deviation v5.0.0 build with latest protocols
hover your mouse over the file names to see full file names.
Time to create page: 0.474 seconds
Builds
- Deviation v5.0.0 build with latest protocols
