Deviation v5.0.0 build with latest protocols
29 Oct 2016 10:21 - 03 Nov 2016 15:14 #55501 by vlad_vy
Replied by vlad_vy on topic Deviation v5.0.0 build with latest protocols
DSM2/X protocol telemetry updated. Fixed all errors that I can find. Now "Telemetry config" page work fine for all telemetry sensors.
(29.10.2016) Firmware DFU file only, you can get other components from official v5.0.0 release.
www.deviationtx.com/downloads-new/category/398-deviation-5-0-0
Files deleted, see below
Last edit: 03 Nov 2016 15:14 by vlad_vy.
29 Oct 2016 21:06 #55507 by SeByDocKy
Replied by SeByDocKy on topic Deviation v5.0.0 build with latest protocols
vlad_vy wrote: Can anybody to test Nine Eagles "j6pro" protocol? I would like to fix error and to do some code clean up, but I can't test it.
I have maybe an old plane with this protocol .... I will try to test ...
30 Oct 2016 03:13 - 03 Nov 2016 15:13 #55511 by vlad_vy
The build with changed Nine Eagles J6Pro protocol.
Last edit: 03 Nov 2016 15:13 by vlad_vy.
30 Oct 2016 18:06 #55529 by jesmail
Replied by jesmail on topic Deviation v5.0.0 build with latest protocols
Thanks for putting the date in the file name, it helps!!!
30 Oct 2016 19:12 #55531 by SeByDocKy
vlad_vy wrote: The build with changed Nine Eagles J6Pro protocol.
Attachment not found
Ok tested with my D7E and the NE Yak54 ... and works fine :)
31 Oct 2016 05:13 #55538 by vlad_vy
OK, thank you for testing.
By the way, date of the build you can find at ''USB" page along with version "v5.0.0+protocols(29.10.2016)".
31 Oct 2016 11:55 - 31 Oct 2016 11:56 #55551 by Thomas.Heiss
Replied by Thomas.Heiss on topic Deviation v5.0.0 build with latest protocols
vlad_vy wrote: DSM2/X protocol telemetry updated. Fixed all errors that I can find. Now "Telemetry config" page work fine for all telemetry sensors.
What errors Vlad? Did you find anything more protocol code related (for normal flying)?
I understand like you wrote it that it's only some (not so important errors) about sensors and telemetry config page??
Last edit: 31 Oct 2016 11:56 by Thomas.Heiss.
31 Oct 2016 12:44 #55555 by aMax
I am wondering if there can be a cloned version of DSM2/X for the 7e with telemetry = OFF by default.
Since I only have receivers without telemetry function and the limitation on the 7e does not give us the
option menu, I really would appreciate that.
31 Oct 2016 13:17 - 31 Oct 2016 13:31 #55557 by vlad_vy
DSM2/X has telemetry OFF by default. Do you try to press ENT button on selected protocol name (DSM2 or DSMX)? You will get the protocol options. At least I can do it with Devo7e emulator.
Thomas,
DSM telemetry update related to correct functioning "Telemetry config" page and displaying correct values, nothing more. Try to setup RPM alarm for previous version and for telemetry updated version. And many other sensors also had values and alarm setup problems.
Last edit: 31 Oct 2016 13:31 by vlad_vy.
31 Oct 2016 14:12 - 31 Oct 2016 14:17 #55559 by aMax
No, this ENT button works on DEVO , FRSKY , FLYSKY etc, not on DSM2/X and this was for quite one and half year.
Indigo`s build was the last one working for this option. For this reason I was asking several times on the forum but did not get any answer on it.
If this could be managed per model.ini, this would be a solution, but it does not work this way.
Last edit: 31 Oct 2016 14:17 by aMax.
31 Oct 2016 14:50 #55560 by vlad_vy
I look at DSM2/X code, it's impossible to enable protocol options (and other protocol features) because of Devo7e memory limitations. It will not fit to Devo7e memory.
31 Oct 2016 15:49 - 31 Oct 2016 15:50 #55562 by aMax
vlad_vy wrote: I look at DSM2/X code, it's impossible to enable protocol options (and other protocol features) because of Devo7e memory limitations. It will not fit to Devo7e memory.
Well, I know.
That´s why I was asking for clone version with telemetry OFF. I Like to get rid of the voltage fluctuation on this protocol and,
... maybe, get a more usable version for my receivers.
In the beginning of 2015 I used this protocol on my first quad and even with fpv I had no problems within 300m.
But then Indigo left and after a more recent version of the nightly I got dropouts even at closer range
This time I noticed someone(PB?)had set the telemetry fix to ON. Switched to FRSKY and stored my DSM stuff on the shelf.
Now I would like to reactivate this for some airplanes.
Last edit: 31 Oct 2016 15:50 by aMax.
31 Oct 2016 16:29 - 31 Oct 2016 16:31 #55564 by vlad_vy
What is voltage fluctuation? At the main screen voltage display? I have the same voltage fluctuations with telemetry enabled and with telemetry disabled (with output power > 30mW). I think my NiMH batteries are too old.
What is dropouts? If it is total lost of control with telemetry enabled, in that case it should be fixed with my builds and with latest nightly builds.
Last edit: 31 Oct 2016 16:31 by vlad_vy.
31 Oct 2016 18:34 #55566 by aMax
vlad_vy wrote: What is voltage fluctuation? At the main screen voltage display? I have the same voltage fluctuations with telemetry enabled and with telemetry disabled (with output power > 30mW). I think my NiMH batteries are too old.
Seems that the telemetry is not completely disabled,...the T212 is still switching: :dry:
No, my cells (2400 mAh) are quite new, three months old and if you take some time, here is the topic on RCGroups from 2015/02...
www.rcgroups.com/forums/showthread.php?t=1918045&page=186
The dropouts were just a short time of no connection, so that the FC went into failsafe and leveled the quad. This happend sometimes 2 or 3 times on some flights at a distance of 80 to 100m. You can see and hear this on the videos.
But let me stop bothering you, good luck with the protocols. Maybe I flash a very old version for testing my planes.
01 Nov 2016 10:11 - 01 Nov 2016 10:12 #55582 by Thomas.Heiss
When I click in "telemetry config" the ">" and "<=" symbols I hear the beep sound and feel the vibration.
Why is it not possible that when a user clicks on the symbols a popup window appears which allows you to select:
- vibration only / sound muted (for flight pack voltage alarm)
- select different sounds
I do not like editing ini files directly.
Is it really that complicated to support this type of configuration within the GUI? I do not care about 7E. Devo10 is fine.
Last edit: 01 Nov 2016 10:12 by Thomas.Heiss.
02 Nov 2016 05:56 - 02 Nov 2016 08:28 #55606 by vlad_vy
By the way, voltage fluctuations at high output power have place with CYRF based protocols "DSM2/X" and "J6Pro", but not with "Devo" protocol. It's not related to PA/LNA switching (with telemetry disabled), since at all CYRF based protocols with telemetry disabled (and J6Pro protocol has not telemetry support) at protocol cycle there is not any command to switch PA/LNA.
Data Rates:
DSM2/X = 125-kbps (64-chip 8DR), Tx period 11ms or 22ms
J6Pro = 125-kbps (64-chip 8DR), Tx period 24ms
Devo = 250-kbps (32-chip 8DR), Tx period 2.4ms
It looks like "Devo" protocol transmit data much faster, therefore you do not see voltage fluctuations.
Last edit: 02 Nov 2016 08:28 by vlad_vy.
03 Nov 2016 10:58 #55636 by vlad_vy
It seems I can fit to Devo7e fully functional DSM2/X protocol, with the exception of "High Speed" mode and "Flight Log" filtering. But it require testing, too many changes, so it will be released a little later...
03 Nov 2016 15:12 - 06 Nov 2016 06:34 #55640 by vlad_vy
OK, at least on the bench new version of DSM2/X protocol work fine. Now Devo7e users can use protocol options: Telemetry = OFF/ON, OrangeRx = NO/YES.
(03.11.2016) Firmware DFU file only, you can get other components from official v5.0.0 release.
Last edit: 06 Nov 2016 06:34 by vlad_vy.
03 Nov 2016 18:01 #55647 by aMax
vlad_vy wrote: OK, at least on the bench new version of DSM2/X protocol work fine. Now Devo7e users can use protocol options: Telemetry = OFF/ON, OrangeRx = NO/YES.
Well done! Thanks a lot.
Now I will do some range testing, at least on ground ...(weather not suitable for flying)
06 Nov 2016 06:39 - 09 Nov 2016 04:52 #55734 by vlad_vy
Implementation of telemetry support for the cflie protocol.
theseankelly
(06.11.2016) Firmware DFU file only, you can get other components from official v5.0.0 release.
Last edit: 09 Nov 2016 04:52 by vlad_vy.
Time to create page: 0.429 seconds
