Deviation v5.0.0 build with latest protocols
- aMax
02 Dec 2016 14:19 #56447
by aMax
I understand your feelings, but wintertime is not the ideal season for excessive testing outdoors. So you may not get much responce
for the main protocols beside the toys...
Anyways, I am glad you did some changes that where requested for a long time.
Keep going.
Replied by aMax on topic Deviation v5.0.0 build with latest protocols
vlad_vy wrote: ...........................cut............
P.S. If it all has any sense. From the begining I do it for myself only. And up to now I have illusion that I do it for myself only, since I have almost zero responce from users.
Keep going.
- MacGyverek
02 Dec 2016 14:24 #56448
by MacGyverek
Replied by MacGyverek on topic Deviation v5.0.0 build with latest protocols
I using your build with dsmx fixes and all working good, without any issue. But if some version working good, then I don't make a updates for new version (like for Frsky protocol and toys protocol). Question: What is changed in version "Fixed touch on XY graphs"?? This changes its for DEVO8S ??
02 Dec 2016 14:33 #56450
Replied by vlad_vy on topic Deviation v5.0.0 build with latest protocols
"Fixed touch on XY graphs" - if you touch XY graph by stylus, it call XY graph properties. It worked at v4.01, but somewhere on the way to v5.0.0 this function stop to work. It's for Devo6, Devo8 and Devo12.
- victzh
02 Dec 2016 15:41 - 02 Dec 2016 15:45 #56454
by victzh
Replied by victzh on topic Deviation v5.0.0 build with latest protocols
Vlad,
if you take a look at what changed since v5.0.0 in the BRANCH_5.0, the modifications are really minimal:
github.com/DeviationTX/deviation/compare/v5.0.0...BRANCH_5.0
PhracturedBlue fixed 5 bugs, added back one box. Me and goebish fixed protocols, this is already covered in your code.
We can make another branch, but I think it's OK to base it on BRANCH_5.0 - these fixes are in the 5.0 release anyways.
Last edit: 02 Dec 2016 15:45 by victzh. Reason: Change commit into tag for clarity
02 Dec 2016 16:45 #56457
I will look to BRANCH_5.0 once again. Last time it was about two months ago.
02 Dec 2016 18:00 #56459
Tested locally with BRANCH_5.0. Do not fit to Devo7e, overflowed by 28 bytes. That's why I revert some code back to v5.0.0.
- aMax
02 Dec 2016 18:09 - 02 Dec 2016 18:11 #56460
by aMax
FrskyD8....short question, has the scaling for the rssi value on the telemetry display been recalculated?
With version 2016-11-02 I have little less, now 121 to prior 115 at two meter distance.
Last edit: 02 Dec 2016 18:11 by aMax.
02 Dec 2016 18:46 #56462
You need ask hexfet at Protocol Development.
02 Dec 2016 19:00 #56463
Replied by hexfet on topic Deviation v5.0.0 build with latest protocols
No change. It's just the raw RSSI byte received in the telemetry packet, same as it has been.
03 Dec 2016 06:42 - 15 Dec 2016 10:43 #56479
Fixed alignment of stick calibration text on 320x240 screen
PhracturedBlue
(03.12.2016) Firmware DFU file only, you can get other components from official v5.0.0 release.
www.deviationtx.com/downloads-new/category/398-deviation-5-0-0
Files deleted, see below...
PhracturedBlue
Last edit: 15 Dec 2016 10:43 by vlad_vy.
03 Dec 2016 14:58 - 05 Dec 2016 10:08 #56482
Now source code for "Deviation v5.0.0 build with latest protocols" can be found at main repository -> BRANCH_5.0
github.com/DeviationTX/deviation/tree/BRANCH_5.0
Last edit: 05 Dec 2016 10:08 by vlad_vy.
- SuperFLY
04 Dec 2016 23:35 #56528
by SuperFLY
Replied by SuperFLY on topic Deviation v5.0.0 build with latest protocols
Guys I do not see the 5.0 DFU file in the download?
05 Dec 2016 04:22 #56529
I think that only "main" branch compiled for Nightly builds. I don't see any compilation listing for "BRANCH_5.0".
- victzh
05 Dec 2016 17:21 #56554
by victzh
Actually, Travis CI builds every pull request and push to the main repository, BRANCH_5.0 including. It discards artifacts afterwards, but we can think of uploading them somewhere instead.
14 Dec 2016 09:13 #56808
It's impossible to use Fix telemetry items loading for CFlie and AFHDS 2A protocols for v5.0.0 build, it doesn't fit to Devo7e.
travis-ci.org/DeviationTX/deviation/builds/182605292
- victzh
14 Dec 2016 16:21 #56820
by victzh
Isn't this TELEMETRY_SetTypeByProtocol redundant? Every protocol with telemetry sets telemetry type from initialization method to correct value through TELEMETRY_SetType. Why do we need this centralized call at all?
14 Dec 2016 17:04 - 14 Dec 2016 17:16 #56822
I think it used at time model setup, protocol selection do not initialize protocol, so we need call TELEMETRY_SetTypeByProtocol() for changing telemetry screen, telemetry config screen and telemetry variables for main screen boxes.
By the way, victzh, can you review warning at master branch:
github.com/DeviationTX/deviation/commit/...cf35176d317aff9e793e
target/common/stm32/spi_flash.c: In function 'CS_LO':
target/common/stm32/spi_flash.c:72:9: warning: implicit declaration of function 'SPISwitch_UseFlashModule' [-Wimplicit-function-declaration]
SPISwitch_UseFlashModule();
target/common/stm32/spi_flash.c: In function 'SPIFlash_Init':
target/common/stm32/spi_flash.c:107:9: warning: implicit declaration of function 'SPISwitch_Init' [-Wimplicit-function-declaration]
SPISwitch_Init();github.com/DeviationTX/deviation/commit/...cf35176d317aff9e793e
Last edit: 14 Dec 2016 17:16 by vlad_vy.
15 Dec 2016 10:47 - 16 Dec 2016 08:43 #56834
Changed counters type to u32 or s32 for compacting binary ("config" folder only).
After that I can fit Fix telemetry items loading for CFlie and AFHDS 2A protocols to Devo7e.
(15.12.2016) Firmware DFU file only, you can get other components from official v5.0.0 release.
Last edit: 16 Dec 2016 08:43 by vlad_vy.
- victzh
15 Dec 2016 17:17 #56854
by victzh
Vlad, I'm preparing large pull request with my SPI switch code, it handles this warning (as some others, already handled by your recent fixes - you was first
- victzh
15 Dec 2016 18:47 #56864
by victzh
We really need to test dropping out the call to TELEMETRY_SetTypeByProtocol, it should work for everything except FrSky - they for some reason do not set the type themselves.
Other protocols set the type soon enough after you selected them so this short period of incorrect telemetry type should not affect other pages.
Unfortunately, I have no telemetry capable receiver myself.
Time to create page: 0.277 seconds
Builds
- Deviation v5.0.0 build with latest protocols
