Deviation v5.0.0 build with latest protocols
12 Feb 2019 05:16 - 01 Mar 2019 04:13 #72862
Replied by vlad_vy on topic Deviation v5.0.0 build with latest protocols
"Deviation v5.0.0 build with latest protocols" (based on v5.0.0 release core)
* Enable scrollbar touch on bar instead of just arrows, from PhracturedBlue
* Fix t8sg for changed flash memory chip
* Fix t8sg_v2 for changed flash memory chip
* Fix t8sg_v2_plus for changed flash memory chip
* Add Devo protocol QR-X350 GPS telemetry format
* Add LOLI protocol, from goebish
(12.02.2019)
Files deleted, see below...
(12.02.2019)
Last edit: 01 Mar 2019 04:13 by vlad_vy.
12 Feb 2019 05:17 - 01 Mar 2019 04:13 #72863
I can't attach more than 10 files, and so XMS builds attached with separate message
(12.02.2019)
(12.02.2019)
12 Feb 2019 05:21 - 05 Mar 2019 04:18 #72864
Fresh emulator builds
(12.02.2019)
(12.02.2019)
Last edit: 05 Mar 2019 04:18 by vlad_vy.
- Fernandez
12 Feb 2019 10:33 #72867
by Fernandez
Replied by Fernandez on topic Deviation v5.0.0 build with latest protocols
Were stand V5 . 0 .0 for ?
Why not generate V5 .1. 12? etc.
I never really understand our version numbering, same for nightlies.
- Sero
- RC-addicted
25 Feb 2019 17:30 #73010
by Sero
Replied by Sero on topic Deviation v5.0.0 build with latest protocols
Is there any possibility to obtain older versions?
I have just realized, that the newer versions don't work with my hardware ID to use two TX without rebinding, and I can't be bothered to rebind over 150 models because of a different ID....
25 Feb 2019 17:50 - 25 Feb 2019 17:53 #73011
The last change with parsing Tx ID was 3 Jan 2018. Short time ago I used my second transmitter without rebind.
committed on 3 Jan 2018
Parse txid from the hardware.ini as u32
Corrects #336, but anyone who used a txid larger then 0x7fffffff will need to rebind all the receivers.
Last edit: 25 Feb 2019 17:53 by vlad_vy.
- Sero
- RC-addicted
25 Feb 2019 17:58 #73012
by Sero
Exactly what my problem is.
So, where might I find a working firmware for my beloved 6s?
25 Feb 2019 18:04 - 25 Feb 2019 18:11 #73013
I can build for you firmware with old style Tx ID. What is your two transmitters, both Devo 6s? You need firmware v5.0.0 or nightly builds?
Last edit: 25 Feb 2019 18:11 by vlad_vy.
- Sero
- RC-addicted
25 Feb 2019 18:12 #73014
by Sero
That would be great!
I prefer the old style menus, and both are 6s.
25 Feb 2019 18:17 #73015
See above, I attached v5.0.0 "devo6" firmware.
- Sero
- RC-addicted
25 Feb 2019 18:25 - 25 Feb 2019 18:40 #73016
by Sero
It works again, BIIIG thumbs up, vlad_vy, and many thanks!
Last edit: 25 Feb 2019 18:40 by Sero.
- Moeder
26 Feb 2019 06:29 #73020
by Moeder
Replied by Moeder on topic Deviation v5.0.0 build with latest protocols
@vlad_vy please check your PM
- Moeder
26 Feb 2019 07:53 #73021
by Moeder
You should also be able to use all current nightly or vlad_vy builds by setting
txid=7fffffff
in your hardware.ini
txid=7fffffff
- Sero
- RC-addicted
26 Feb 2019 08:26 #73022
by Sero
I could, but it would mean, that I have to rebind (DSMX and DSM2) all my stuff, and we are talking about more than 150 here.
- Moeder
26 Feb 2019 09:00 #73023
by Moeder
No, txid 7fffffff is most likely what is already used internally.
- Sero
- RC-addicted
26 Feb 2019 11:55 #73025
by Sero
I'll give it a try after work.
- Sero
- RC-addicted
26 Feb 2019 17:11 #73030
by Sero
You're right, it works.
In that case it should be better documented, the info regarding that change is misleading...
- Birdman
27 Feb 2019 05:08 #73034
by Birdman
Replied by Birdman on topic Deviation v5.0.0 build with latest protocols
tried to upgrade new 12s using file from this page and when installing lib.dfu i'm getting error message saying
"unable to find data for that device/target from the file"
please help
please help
- Birdman
27 Feb 2019 05:44 - 27 Feb 2019 06:01 #73035
by Birdman
sorted
my bad, forgetting to click "library" tab
Last edit: 27 Feb 2019 06:01 by Birdman.
- Birdman
27 Feb 2019 06:17 #73036
by Birdman
mmmmmmmmmmm
Firmware has upgraded but I seem to have touch screen issues.
Anyone????
Anyone????
Time to create page: 0.317 seconds
Builds
- Deviation v5.0.0 build with latest protocols
