Deviation v5.0.0 build with latest protocols
27 Feb 2019 06:21 #73037
Replied by vlad_vy on topic Deviation v5.0.0 build with latest protocols
See Transmitter settings -> Touch screen -> Calibrate
- Birdman
27 Feb 2019 07:36 #73038
by Birdman
Replied by Birdman on topic Deviation v5.0.0 build with latest protocols
Managed to get in and calibrate, seems good now, fingers crossed.
- Birdman
28 Feb 2019 00:28 #73052
by Birdman
vlad, please see my post in "General Discussions" maybe you can help.
- wind10071
28 Feb 2019 17:18 #73069
by wind10071
Replied by wind10071 on topic Deviation v5.0.0 build with latest protocols
- bd-flyer
01 Mar 2019 03:06 #73074
by bd-flyer
Replied by bd-flyer on topic Deviation v5.0.0 build with latest protocols
I could not bind with the bayang protocol using any nightly builds uploaded currently.
01 Mar 2019 04:16 - 05 Mar 2019 04:17 #73075
"Deviation v5.0.0 build with latest protocols" (based on v5.0.0 release core)
* Adjust post-transmit timing to eliminate wait loop (bugs3 protocol), from hexfet
* Fix protocol init when exit "Scanner" page with scanner=OFF
(1.03.2019)
Files deleted, see below...
(1.03.2019)
Last edit: 05 Mar 2019 04:17 by vlad_vy.
01 Mar 2019 04:18 - 05 Mar 2019 04:18 #73076
I can't attach more than 10 files, and so XMS builds attached with separate message
(1.03.2019)
(1.03.2019)
Last edit: 05 Mar 2019 04:18 by vlad_vy.
- wind10071
01 Mar 2019 04:24 #73078
by wind10071
- wind10071
01 Mar 2019 04:27 #73079
by wind10071
Need help!
How does DevOTX choose to build?
- joeclone
02 Mar 2019 03:10 #73111
by joeclone
Replied by joeclone on topic Deviation v5.0.0 build with latest protocols
Is PXX protocol in the latest build? Tried flashing but can't find it in the model selection.
02 Mar 2019 07:19 #73114
V5.0.0 build doesn't include serial protocols, since v5.0.0 core hasn't support for them. You need to use nightly builds.
- Birdman
02 Mar 2019 23:34 #73131
by Birdman
"* Enable scrollbar touch on bar instead of just arrows, from PhracturedBlue"
what is this? I don't see this change?
03 Mar 2019 09:45 #73137
Now for scrolling you can touch scrollbar, above or below pointer. Earlier you can use only up and down arrows.
05 Mar 2019 04:22 - 14 May 2019 05:39 #73210
* Add protocol for Eachine E016H, from goebish* Add Silverware's analog aux channel feature to Bayang protocol, from brianquad(05.03.2019)
Channel mapping:
Channel 5: flip
Channel 6: headless
Channel 7: RTH
Channel 8: emergency stopThis change to the Bayang protocol adds an option to steal two presently unused (by the Silverware firmware, which targets several Bayang quads) in the protocol to send two more "analog" (non-binary) channels of data to the Rx. With corresponding changes on the Rx firmware, those new aux channels can be used to do more interesting things than the other binary aux channels. Some users have really liked PID tuning with the extra channels.
More information on the Silverware additions here:
https://www.rcgroups.com/forums/showthread.php?3121896-Analog-Aux-Channels-for-Silverware
The main NFE Silverware fork now has this feature available:
https://github.com/NotFastEnuf/NFE_SilverwareFiles deleted, see below...
Last edit: 14 May 2019 05:39 by vlad_vy.
05 Mar 2019 04:25 - 14 May 2019 05:40 #73211
(05.03.2019)
(05.03.2019)
Last edit: 14 May 2019 05:40 by vlad_vy.
05 Mar 2019 04:27 - 14 May 2019 05:41 #73212
Fresh emulator builds
(05.03.2019)
(05.03.2019)
Last edit: 14 May 2019 05:41 by vlad_vy.
- clips
09 Mar 2019 15:03 #73279
by clips
Replied by clips on topic Deviation v5.0.0 build with latest protocols
hai i can,t binding my eachine eo10 after upgrade latest firmware for my T8SG plus, anyone can help me please
11 Mar 2019 05:34 - 14 May 2019 05:45 #73300
* Fix devof12e-XMS toggle icons
(11.03.2019)
File deleted, see below...
(11.03.2019)
Last edit: 14 May 2019 05:45 by vlad_vy.
- Toolbox1211
12 Mar 2019 13:59 - 12 Mar 2019 14:06 #73314
by Toolbox1211
Replied by Toolbox1211 on topic Deviation v5.0.0 build with latest protocols
This is great news.
Tested and toggle icons work great. Usb mode can go also go to the main menu and i can acces the datalog setup menu but havent tested that yet.
New issues have come up tho.
The dfplayer is not activating now.
The voice option is not in the menus.
The vibrator is working as tho voice was off it even buzzes on shutdown and never did before so the goodbye message for the dfplayer should work now too
Last edit: 12 Mar 2019 14:06 by Toolbox1211.
12 Mar 2019 14:55 - 12 Mar 2019 14:56 #73315
v5.0.0 release build has not support for voice. It was added later with nightly builds.
Last edit: 12 Mar 2019 14:56 by vlad_vy.
Time to create page: 0.238 seconds
Builds
- Deviation v5.0.0 build with latest protocols
