Ultimate Devo F12E (devof12e-XMS) builds
19 Mar 2017 03:56 #60356 by M8A4X
Replied by M8A4X on topic Ultimate Devo F12E (devof12e-4MB) builds
@vlad: Loaded it up to the F12E and all works perfect!
Tested it with PAL and NTSC, runcam and eachine cam attached to an eachine VTX and I even got the ImmersionRC VTX
running again (broken solder joint / lifted trace) and this one works as well! :)
@rdowzall: Congratulations, nice to hear that it now works for you! ;)
I second your opinion about the F12E, it is for sure a very nice and well built radio and the integrated FPV system is great.
19 Mar 2017 09:53 - 19 Mar 2017 17:14 #60358 by vlad_vy
Replied by vlad_vy on topic Ultimate Devo F12E (devof12e-4MB) builds
* Minor corrections for Multi-standard TV support. Now it should be perfect.
DevoF12E and DevoF12E-4MB, with fixes, based on Nightly Builds:
Files deleted, see below...
Last edit: 19 Mar 2017 17:14 by vlad_vy.
19 Mar 2017 17:15 - 20 Mar 2017 04:14 #60371 by vlad_vy
* More safe TW8816 index page processing.
I think the work with TV standards is finished.
Last edit: 20 Mar 2017 04:14 by vlad_vy.
19 Mar 2017 18:39 #60374 by rdowzall
Replied by rdowzall on topic Ultimate Devo F12E (devof12e-4MB) builds
Now I am up and running the F12e 4mb, have been playing with programing and am seeking some advice. In the "Model Setup" on the bottom of the screen "Mixer GUI" command, you can only select "Standard" in heli mode. Not available in plane or multi mode, can only choose "Advanced" for those, is there a reason I am missing for this? Also trying to combine all elev, rud, ail, DR on one switch (just the way I like to fly) instead of the three seperate switches. Would this be accomplished by setting up a virtual channel in the "mixer" commands? Any advice would be great, having so much fun with the "new" transmitter it really is fantastic!!!!
19 Mar 2017 18:50 - 19 Mar 2017 18:51 #60377 by vlad_vy
"Standard" Mixer GUI implemented for heli only, for all Devo transmitters.
Last edit: 19 Mar 2017 18:51 by vlad_vy.
19 Mar 2017 18:58 #60378 by rdowzall
Thnaks so much Vlad, I am converting to Devo TX from Spektrum TX, I still have a bit of a learning curve!!!!
19 Mar 2017 20:44 #60382 by rdowzall
After a bit of reading and experimenting figured out my Duel Rate question....getting the hang of it. Flew my little 250 quad today with the F12e....was great!
20 Mar 2017 04:13 - 25 Mar 2017 08:38 #60391 by vlad_vy
* Fixed select "PAL 60" video standard.
Last edit: 25 Mar 2017 08:38 by vlad_vy.
20 Mar 2017 23:50 #60460 by rdowzall
Does anyone know about binding with the fixed ID? Seem to remember that could be turned on and off. Does it automatically assign a fixed ID when binding? Also am having a hard time finding where to set wing type/tail type/ail servo flap set-up in plane model? For example setting up a v-tail or wing with 2 servos for flapperons? In my case this could be my transferring from Spektrum to the new Devo. Thanks fro any help!!!
21 Mar 2017 04:16 #60466 by vlad_vy
By default Fixed ID = 123456, if it cleared it will be disabled. You can use any different Fixed ID for different models to prevent mistaken binding.
Deviation has not any predefined mixes for models, except heli. You have to create specific mixes by self.
22 Mar 2017 11:11 #60506 by RudyMeister
Replied by RudyMeister on topic Ultimate Devo F12E (devof12e-4MB) builds
Keep up the good work vlad_vy!
I'm looking for almost 2 years for porting my Devo F12E to Deviation,
but with the memorychip-mod and some well working software I might go over to this.
By the way: I'm flying a Scout X4 and a OXY3 Qube, anyone tried a heli on F12E Deviation?
22 Mar 2017 14:36 #60526 by Artus
Replied by Artus on topic Ultimate Devo F12E (devof12e-4MB) builds
Yes - he did an excellent job :) i have testet yesterday the "normal" version - and i am happy i am able to use this. I dont extract the memory chip by myself - i send the other Mainboard to a person how is able to do this. So i have to wait for using the Ulitmate Verison.
But the normal version is excellent working - the most hints and issues are cleaned now. Video scaling is now proper working and i thanky a lot Vlady !!
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
22 Mar 2017 14:49 #60531 by Moeder
Replied by Moeder on topic Ultimate Devo F12E (devof12e-4MB) builds
Vlad_vy, could you upload the U-F12E build to your github repo? I would like to take a look and see if we can just implement the flash chip detection to the general F12E build so we won't need separate builds for U and non-U F12E
22 Mar 2017 15:56 #60536 by vlad_vy
It has not any very specific and takes all from devof12e target. Only two file are different: target_defs.h and Makefile.inc.
#ifndef _DEVO_F12E_4MB_TARGET_H_
#define _DEVO_F12E_4MB_TARGET_H_
#include "../common/devo/common_devo.h"
#define TXID 0xEC
#define VECTOR_TABLE_LOCATION 0x4000
#define SPIFLASH_SECTOR_OFFSET 54
#define SPIFLASH_SECTORS 1024
#define LCD_WIDTH 66
#define LCD_HEIGHT 26
#define CHAR_WIDTH 12
#define CHAR_HEIGHT 18
#define HAS_STANDARD_GUI    1
#define HAS_ADVANCED_GUI    1
#define HAS_PERMANENT_TIMER 1
#define HAS_TELEMETRY       1
#define HAS_EXTENDED_TELEMETRY 1
#define HAS_TOUCH           0
#define HAS_RTC             0
#define HAS_VIBRATINGMOTOR  1
#define HAS_DATALOG         1
#define HAS_SCANNER         0
#define HAS_LAYOUT_EDITOR   0
#define HAS_EXTRA_SWITCHES  0
#define HAS_EXTRA_BUTTONS   0
#define HAS_MULTIMOD_SUPPORT 1
#define HAS_MAPPED_GFX      1
#define USE_PBM_IMAGE       1
#define HAS_CHAR_ICONS      1
#define HAS_VIDEO           32
#define HAS_EXTRA_SCREEN_TUNING 1
#ifdef BUILDTYPE_DEV
   #define DEBUG_WINDOW_SIZE 200
#else
   #define DEBUG_WINDOW_SIZE 0
#endif
#define MIN_BRIGHTNESS 0
#define DEFAULT_BATTERY_ALARM 9600
#define DEFAULT_BATTERY_CRITICAL 3900
#define MAX_BATTERY_ALARM 12000
#define MIN_BATTERY_ALARM 3300
#define MAX_POWER_ALARM 60
#define NUM_OUT_CHANNELS 12
#define NUM_VIRT_CHANNELS 10
#define NUM_TRIMS 10
#define NUM_TOGGLES 5
#define MAX_POINTS 13
#define NUM_MIXERS ((NUM_OUT_CHANNELS + NUM_VIRT_CHANNELS) * 4)
#define INP_HAS_CALIBRATION 8
/* Compute voltage from y = 3.261x + 507 */
#define VOLTAGE_NUMERATOR 326
#define VOLTAGE_OFFSET    507
#endif //_DEVO_F12E_4MB_TARGET_H_
FILESYSTEMS := common text text_gfx
SCREENSIZE  := text
DFU_ARGS    := -c 12 -b 0x08004000
LANGUAGE   := devo10
include $(SDIR)/target/common/devo/Makefile.inc
ifndef BUILD_TARGET
SRC_C   += $(SDIR)/target/devof12e/backlight.c \
           $(SDIR)/target/devof12e/channels.c \
           $(SDIR)/target/devof12e/crc.c \
           $(SDIR)/target/devof12e/lcd.c \
           $(SDIR)/target/devof12e/mapped_gfx.c \
           $(SDIR)/target/devof12e/tw8816.c \
           $(SDIR)/target/devof12e/tw8816_map.c \
           $(SDIR)/target/devof12e/tx_buttons.c
else
$(TARGET).fs_wrapper: $(LAST_MODEL)
	rm -f filesystem/$(FILESYSTEM)/language/lang.cn
	rm -f filesystem/$(FILESYSTEM)/language/lang.ru
	rm -f filesystem/$(FILESYSTEM)/language/lang.tw
endif
22 Mar 2017 16:17 #60539 by Moeder
Ok thanks! I will try to make a universal flash code for f12e, I'll post a dfu for you to try out here as soon as it's finished
22 Mar 2017 16:44 #60542 by FDR
Actually it would be useful for all the other TX types, which have limited SPI flash size, but most of them also have limited code space as well...
22 Mar 2017 19:42 #60562 by Moeder
Which are that? F4? F7? F12E? F7 uses same MCU as 7e if I'm correct, so it might be a close call to make it fit...
22 Mar 2017 20:20 #60566 by FDR
Yep, they are the candidates...
23 Mar 2017 12:43 #60603 by Moeder
Ok, first shot at f12e flash detection. Attached is a zip with dfu file only, use filesystem from vlad_vy latest post. Please be aware this build may corrupt your filesystem, so PLEASE BACKUP ALL FILES!
23 Mar 2017 13:09 #60606 by DIGGIDY
Replied by DIGGIDY on topic Ultimate Devo F12E (devof12e-4MB) builds
@Moeder
Is this for the 4MB build or the standard unmodified F12E?
Time to create page: 1.318 seconds
