Ultimate Devo F12E (devof12e-XMS) builds
11 Oct 2017 15:29 - 11 Oct 2017 15:30 #64961 by Wene001
Replied by Wene001 on topic Ultimate Devo F12E (devof12e-XMS) builds
vlad_vy wrote: About devoF7 trims: devoF4 video chip has very limited char set, so this is done as possible.
i understand the different char set...
what i mean is that the Trim-Curser behaves different in the one and the other direction.
i have to click 20 times to go the cursor 1 position left.
i have to click1 time to go the cursor 1 position right
(tested with F7 and also F7 simulator)
F12 simulator left and right trim is the same
Last edit: 11 Oct 2017 15:30 by Wene001.
11 Oct 2017 15:58 #64962 by vlad_vy
Replied by vlad_vy on topic Ultimate Devo F12E (devof12e-XMS) builds
Yes, I see. Trim value changes correctly but cursor position changes incorrectly. I will look into it.
11 Oct 2017 16:06 #64963 by kmewes
Replied by kmewes on topic Ultimate Devo F12E (devof12e-XMS) builds
I think there is a coarse and a fine adjustment. If you do single click it takes about 20 clicks between the markers but if you hold the trim button it rapidly goes from mark to mark. It was intended that way, as I assume. If it gives sufficient feedback for some that depends. I prefer to do sub-trim for my helis, but for wings it might be different, I don't know since I don't have any :-)
Cheers
12 Oct 2017 07:25 #64977 by vlad_vy
With trim cursor it's the problem of integer division rounding. It can't be fixed ideally, but now it will looks more naturally. (x / y) changed to (x + y / 2) / y.
12 Oct 2017 12:26 - 12 Oct 2017 12:47 #64987 by Wene001
vlad_vy wrote: Yes, I see. Trim value changes correctly but cursor position changes incorrectly. I will look into it.
THX
i would prefer, if the cursor moves at the first click...otherwise it would be hard to know in which direction the trimming is for the vertical trims (ele,thr)
About Cursor in the menue:
Ive looked into the most menue points.
There should be enouph space to have it this way
 menu1
>menu2
 menu3
instead of
menu1
>menu2
menu3
This would be much better for readability
What do you think?
Is this hard to implement?
I think it would be also a good idea to center the menu headlines for better readability
Sorry for my bad english
Greetz from Austria
Werner
Last edit: 12 Oct 2017 12:47 by Wene001.
30 Oct 2017 17:35 #65366 by Artus
Replied by Artus on topic Ultimate Devo F12E Video channels
Hello vlad_vy :)
I hope this question is not clarified else ..
My question is: is there anywhere a sheet with video channel belongs to which frequency ?
In the moment i have some trouble with a MATEK VTX and the HGLRC F4 V5Pro (onboard VTX). I have found this
www.aziermann.de/Tank/FPV%20Frequenz%20%C3%9Cbersicht.xlsx
According to this sheet - i swichted the my VTX to 5765Mhz (description) - but at channel 19 on my F12E - nothing - i have an acceptable picture on channel 6.
Thanks for your help
-Richard-
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
30 Oct 2017 17:45 - 31 Oct 2017 04:32 #65367 by vlad_vy
Replied by vlad_vy on topic Ultimate Devo F12E Video channels
I can't help. I also think there is an error with video channels.
Last edit: 31 Oct 2017 04:32 by vlad_vy.
31 Oct 2017 12:48 - 31 Oct 2017 12:49 #65378 by vlad_vy
Actually Devo F12E has 24 video channels, last 8 channels repeated. Original Walkera video channels table also has 8 channels repeated.
0 = 5865 (A - ch1)
1 = 5845 (A - ch2)
2 = 5825 (A - ch3)
3 = 5805 (A - ch4)
4 = 5785 (A - ch5)
5 = 5765 (A - ch6)
6 = 5745 (A - ch7)
7 = 5725 (A - ch8)
8 = 5733 (B - ch1)
9 = 5752 (B - ch2)
10 = 5771 (B - ch3)
11 = 5790 (B - ch4)
12 = 5809 (B - ch5)
13 = 5828 (B - ch6)
14 = 5847 (B - ch7)
15 = 5866 (B - ch8)
16 = 5945 (E - ch8)
17 = 5925 (E - ch7)
18 = 5905 (E - ch6)
19 = 5885 (E - ch5)
20 = 5645 (E - ch4)
21 = 5665 (E - ch3)
22 = 5685 (E - ch2)
23 = 5705 (E - ch1)
24 = 5945 (E - ch8)
25 = 5925 (E - ch7)
26 = 5905 (E - ch6)
27 = 5885 (E - ch5)
28 = 5645 (E - ch4)
29 = 5665 (E - ch3)
30 = 5685 (E - ch2)
31 = 5705 (E - ch1)
Last edit: 31 Oct 2017 12:49 by vlad_vy.
31 Oct 2017 15:59 #65381 by Artus
Thank you a lot for your fast information.
The reason why i ask - my Matek VTX makes a terrible picture on my both F12E with a PAL-Cam (i have tested several cams) - independent of firmware (Deviation - or Walkera). I have no problem with another monitor (i have a 7 Zoll with diversitiy also - picture is ok) - and i have no problem with another VTX and F12E. For example the HGLRC F4 V5Pro Board is sending a fine picture to the F12E.
On Fatshark cam - i can switch to NTSC - and then the picture is ok. Is the reciever of the F12E so "poor" ?
31 Oct 2017 16:02 #65382 by Artus
Replied by Artus on topic Changing Font Color
Hello vlad_vy,
Is it possible to change the font color - to make a visual difference which information is by OSD and which is the radio?
Long time ago if have made some test - but i was not successfull..
Thank you a lot for all your efforts :)
31 Oct 2017 16:29 - 31 Oct 2017 16:31 #65383 by vlad_vy
Replied by vlad_vy on topic Changing Font Color
void LCD_PrintCharXY(unsigned int x, unsigned int y, u32 c)
    c = TW8816_map_char(c);
    if (x >= LCD_WIDTH)
        x = LCD_WIDTH-1;
    u32 pos = ((y >> 1)*(LCD_WIDTH>>1)) + (x>>1);
    //printf("%02x(%c): %d, %d, %d\n", c, c, x, y, pos);
    TW8816_DisplayCharacter(pos, c, 7);
I think '7' is the white color, 0111 -> FFh (111,111,11), page 17 of TW8816 datasheet.
Last edit: 31 Oct 2017 16:31 by vlad_vy.
26 Nov 2017 00:56 - 26 Nov 2017 00:58 #66167 by dc59
Replied by dc59 on topic Devo F7
Hi vlad_vy,
I got a used F7 last week and would like to mod. it to XMS version. 2 stupid questions.
1, If I want to back to Walkera FW , is it just change SPI flash to original UPCT25VF512A?
2, What's correctly step ? change SPI flash memory then upgrade Deviation XMS FW or I should upgrade Deviation XMS FW first?
Thank you very much.
edit:
Is there any difference between SST25VF032B-50-4C-S2AF and SST25VF032B-80-4I-S2AF?
Last edit: 26 Nov 2017 00:58 by dc59.
26 Nov 2017 07:19 - 26 Nov 2017 07:23 #66172 by vlad_vy
Replied by vlad_vy on topic Devo F7
1. To return back to Walkera FW you need return back original flash memory chip.
2. Change flash memory chip then upgrade to Deviation XMS. You can do it by any way, XMS support flash memory auto detection, but other way has not sense, you can't write filesystem to small memory chip.
3. They differ by operating frequency 50MHz and 80MHz. I think you can use any of them, but with my case it was 80MHz chip.
Last edit: 26 Nov 2017 07:23 by vlad_vy.
26 Nov 2017 08:19 #66175 by dc59
Thanks vlad_vy! I got it.:cheer:
11 Dec 2017 14:15 #66443 by dc59
Hi vlad_vy,
I destroyed a solder pad of my flash memory as attached picture , is it possible to connect that pin to other solder point? or I have destroyed the TX?
Thank you very much!
11 Dec 2017 14:30 - 20 Feb 2018 08:58 #66444 by vlad_vy
Replied by vlad_vy on topic Ultimate Devo F12E (devof12e-4MB) builds
vlad_vy wrote: Opps, this table is for Devo F12E. I don't know connections for Devo F4. It has to be very similar, but with different MCU pin numbering.
With Devo F4 it can be (pin connections from SST25VF032B to STM32F103RBT6):
1. CE = SPI1_CE (PB2, pin 28)
2. SO = SPI1_MISO (PA6, pin 22)
3. WP = 3.3V (VDD_4, pin 19)
4. VSS = GND (VSS_4, pin 18)
5. SI = SPI1_MOSI (PA7, pin 23)
6. SCK = SPI1_SCK (PA5, pin 21)
7. HOLD = 3.3V (VDD_4, pin 19)
8. VDD = 3.3V (VDD_4, pin 19)
If Devo F7 connections are similar to Devo F4.
Last edit: 20 Feb 2018 08:58 by vlad_vy.
11 Dec 2017 14:48 #66445 by dc59
Replied by dc59 on topic Ultimate Devo F12E (devof12e-4MB) builds
Thanks I will give it a try!
11 Dec 2017 15:12 #66448 by vlad_vy
Why not to use via near destroyed a solder pad (IC4 pin 2), or connect pin 2 to via near IC4 pin 5.
11 Dec 2017 19:28 - 11 Dec 2017 22:15 #66453 by dc59
vlad_vy wrote: Why not to use via near destroyed a solder pad (IC4 pin 2), or connect pin 2 to via near IC4 pin 5.
What do you mean? I don't understand.......
I got it and Thank you very much! :)
Last edit: 11 Dec 2017 22:15 by dc59.
11 Dec 2017 21:01 #66455 by RubenRC
Replied by RubenRC on topic Ultimate Devo F12E (devof12e-4MB) builds
That happened to me. You can use the other end of the lead. That's what I did and my F12E is working with no issues. Just watch your soldier iron to avoid damaging the other components.
DEVO F12E | Devo F7
Time to create page: 2.191 seconds
