Ultimate Devo F12E (devof12e-XMS) builds
11 Dec 2017 22:16 #66457 by dc59
Replied by dc59 on topic Ultimate Devo F12E (devof12e-4MB) builds
It's fixed and working good! thanks vlad_vy & RubenRC!!
12 Dec 2017 06:14 - 13 Dec 2017 04:40 #66459 by vlad_vy
Replied by vlad_vy on topic Ultimate Devo F12E (devof12e-4MB) builds
dc59,
Can you test devof7-XMS build with brightness fix, and dimmer function, for all backlight values?
File deleted...
Last edit: 13 Dec 2017 04:40 by vlad_vy.
12 Dec 2017 06:20 #66461 by dc59
vlad_vy wrote: dc59,
Ok, I will test after work.
12 Dec 2017 12:56 #66462 by dc59
Dimmer function works fine! dimmer target value must be lower than backlight value!
12 Dec 2017 13:17 - 12 Dec 2017 13:20 #66463 by vlad_vy
Are all backlight values appropriate, not too dark, not too bright?
Can you turn off backlight with dimmer target = off?
Last edit: 12 Dec 2017 13:20 by vlad_vy.
13 Dec 2017 00:02 #66469 by dc59
vlad_vy wrote: Are all backlight values appropriate, not too dark, not too bright?
Yes, all backlight values act perfect,not too dark at value 1 and not too bright at value 10!
It's turned off with dimmer target = off, act as it should be!
14 Dec 2017 00:04 #66491 by dc59
Hi vlad_vy,
I got a problem about my F7 trainer switch(momentary SW) , it can not be detected by FW , I have checked SW connection OK,
would you please check code for me , Thanks!
14 Dec 2017 03:53 - 14 Dec 2017 03:55 #66494 by vlad_vy
I havn't Devo F7 and don't understand how the switches connected. The code has TRN and HOLD switches, TRN connected to PC15 (MCU pin 4) and HOLD connected to PC12 (MCU pin 53). Is it 3-pos switch with self return to middle position?
Last edit: 14 Dec 2017 03:55 by vlad_vy.
14 Dec 2017 04:54 #66495 by dc59
vlad_vy wrote: I havn't Devo F7 and don't understand how the switches connected. The code has TRN and HOLD switches, TRN connected to PC15 (MCU pin 4) and HOLD connected to PC12 (MCU pin 53). Is it 3-pos switch with self return to middle position?
Yes, it's 3-pos SW self return for TRN and the other side is NOT self return for HOLD, HOLD SW works fine , but TRN has no response.
Thanks any way!!
04 Jan 2018 11:55 #66707 by YARIMbe
Replied by YARIMbe on topic Ultimate Devo F12E (devof12e-XMS) builds
Thank you for the good work on this project!!, I ordered the extended memory for my F7 and installed the XMS build,
just throwing my 2 cent here:
we all know that the OSD on the screen of the F7 does not support some of the symbols of the firmware and we can't use logos,
so I thought maybe it is possible to turn off the integrated OSD and "hijack" the clean video signal of the using minim-osd that way we can show whatever we would like!
sound plausible?
09 Jan 2018 22:28 #66790 by Artus
Replied by Artus on topic Ultimate Devo F12E (devof12e-XMS) builds
Hello Vald_vy,
About changing colour of .... in former times there was a config file .. i have played a little bit but no effect. If colour is hard coded its not really possible for me to change anything.
But another question i have - maybe you can help me again:
FMODE SWITCH...
I need the the functionality of a 3 point switch to set 3 different flight modes - without any other functions .. or mixes - .. only -100 0 + 100
I am in Modelmenu -> mixer - CHANNEL 5 - simple - source FMODE - courve 1 to 1 .. save
But why is this switch jumping form -100 to + 100 ?
Can you tell me where i can read a little more about programming this 3 point switch ?
I dont need any mixed behind - only FMODE 0 100, FMODE 1 0 and FMODE 2 -100
Thank you a lot for you help
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
09 Jan 2018 23:57 #66791 by dc59
Replied by dc59 on topic Ultimate Devo F12E (devof12e-XMS) builds
It's another approach:
Modelmenu -> mixer - CHANNEL 5 - Expo&DR - Scr FMODE0(or None) - High-Rate Fixed - Scale 100
Switch1 FMODE1 - High-Rate Linked - Scale 0
Switch2 FMODE2 - High-Rate Linked - Scale -100
or you can do the same thing by using "Complex" instead.
10 Jan 2018 01:51 #66792 by Artus
Thank you a lot for your help dc59
I was on this way - but the Scale Value was not to change - anyhow locked.
After i change "High-Rate" value to anything other - and than back to "linked". I was able to change the the Scale Value to 0 or -100
Thank you a for your help.
10 Feb 2018 07:24 #67454 by vlad_vy
Replied by vlad_vy on topic Ultimate Devo F12E (devof12e-XMS) builds
If anybody have possibility to test "Microchip SST26VF032B" I can provide test build.
12 Feb 2018 06:06 - 14 Feb 2018 05:12 #67469 by vlad_vy
Also, easily can be added Macronix MX25Lxxxxx, they are completely the same as ISSI IS25CQ032 except Electronic Manufacturer ID & Device ID (0xC2 0x20).
Last edit: 14 Feb 2018 05:12 by vlad_vy.
13 Feb 2018 14:27 #67488 by Bisky
Replied by Bisky on topic Ultimate Devo F12E (devof12e-XMS) builds
vlad_vy wrote: If anybody have possibility to test "Microchip SST26VF032B" I can provide test build.
With a little luck my will arrive on Friday.
Devo F7 XMS + 4in1 module
13 Feb 2018 15:37 #67489 by vlad_vy
By the way Microchip flash memory has very fast erase time, at least 30 times faster than others.
13 Feb 2018 15:45 #67490 by vlad_vy
If you're ready to take a chance, I can not guarantee that this will work.
16 Feb 2018 07:05 #67528 by vlad_vy
Now I have for testing Winbond W25Q16BV, Macronix MX25L3205D and Adesto AT25DF321A.
I need assemble testing board from Jumper T8SG with SOIC8 to DIP8 adapter.
16 Feb 2018 16:48 - 16 Feb 2018 18:13 #67539 by Bisky
I'm almost ready...
Last edit: 16 Feb 2018 18:13 by Bisky.
Time to create page: 2.194 seconds
