Ultimate Devo F12E (devof12e-XMS) builds
22 Feb 2018 06:42 - 22 Feb 2018 07:05 #67677 by vlad_vy
Replied by vlad_vy on topic Ultimate Devo F12E (devof12e-XMS) builds
FDR wrote: Nice!
Probably we should play with a drawn background, or at least use a one pixel wide image and stretch that...
Example with a drawn background:
We need to do it configurable -> background color and header color. Now it has fixed colors:
void _gui_draw_background(int x, int y, int w, int h)
#ifdef _DEVO12_XMS_TARGET_H_
    if(y + h < 32) {
        LCD_FillRect(x, y, w, h, RGB888_to_RGB565(0x80, 0x80, 0x80));
    } else if(y >= 32) {
        LCD_FillRect(x, y, w, h, RGB888_to_RGB565(0x90, 0xc0, 0xe0));
    } else {
        LCD_FillRect(x, y, w, 32 - y, RGB888_to_RGB565(0x80, 0x80, 0x80));
#else
    LCD_DrawWindowedImageFromFile(x, y, "media/backgrnd" IMG_EXT, w, h, x, y);
#endif
Last edit: 22 Feb 2018 07:05 by vlad_vy.
22 Feb 2018 07:16 #67679 by FDR
Fine.
Is it remarkably faster that way?
22 Feb 2018 07:19 #67680 by FDR
Actually I feel this slow refresh even on my DEVO 8, so it might be a generic solution for all color transmitters, but it would be great if it was a configurable option...
22 Feb 2018 07:41 #67681 by vlad_vy
FDR wrote: Fine.
I will test it today.
22 Feb 2018 09:55 - 22 Feb 2018 09:57 #67683 by vlad_vy
Now with v5.0.0 build I can select and configure the display background (image or drawn background):
With some code changes and "config.ini" values:
[background]
  drawn_background=1
  bg_color=90C0E0
  hd_color=808080
Last edit: 22 Feb 2018 09:57 by vlad_vy.
22 Feb 2018 10:10 #67684 by FDR
Cool!
Could you test the speed difference?
22 Feb 2018 10:25 - 22 Feb 2018 10:32 #67686 by vlad_vy
Now I can do it for Nightly Builds.
I will test speed difference when I return to home. 3-4 hours later.
Devo8 with a drawn background:
Last edit: 22 Feb 2018 10:32 by vlad_vy.
22 Feb 2018 10:40 #67688 by FDR
Actually it's hard to measure. Probably the best way would be counting video frames from the beginning of the refresh till the end, but I'm more interested in the "feel"
22 Feb 2018 10:41 #67689 by FDR
...or with some code change you could log the time spent...
22 Feb 2018 13:13 #67691 by vlad_vy
About GUI speed with drawn background:
1. devo12-XMS - background draw much faster than normal devo12, I think it even slightly faster or equal to devo8 with image background. At least, now the background draw faster than all GUI objects on a page. It's only brief fraction of a second.
2. devo8 - background draw almost instantly, I can't see this moment. The whole GUI works instantly.
22 Feb 2018 13:42 #67692 by FDR
22 Feb 2018 14:44 - 23 Feb 2018 11:04 #67694 by vlad_vy
* Add selectable and configurable drawn background.
You can select to draw background instead a background image for color GUI. This will greatly speed up the drawing of the pages. You can set header color and background color. The settings are in "config.ini" file. By default used background image.
[background]
  drawn_background=0
  bg_color=50A0D8
  hd_color=707070
"devo12-XMS" based on nightly builds:
(22-02-2018)
File deleted, see below...
Last edit: 23 Feb 2018 11:04 by vlad_vy.
22 Feb 2018 15:55 - 22 Feb 2018 15:56 #67696 by vlad_vy
Optimized draw background. It work slightly faster and page update looks more smooth.
"devo12-XMS" build updated.
Last edit: 22 Feb 2018 15:56 by vlad_vy.
23 Feb 2018 11:04 - 24 Feb 2018 07:59 #67706 by vlad_vy
* Fix devo12 "Input monitor" page
(23-02-2018)
Last edit: 24 Feb 2018 07:59 by vlad_vy.
23 Feb 2018 15:21 #67712 by Bisky
Replied by Bisky on topic Ultimate Devo F12E (devof12e-XMS) builds
I heave mode1 setings, when i Switch on my F7 it says throtle not idile position and I heave to move the left, not the right stick wich is allrady ideile. After I move the left stick down the massage goes away and my right stick is throttle channel...
Devo F7 XMS + 4in1 module
24 Feb 2018 08:01 - 26 Feb 2018 07:24 #67731 by vlad_vy
* Fix color GUI "Voice config" page
* Set drawn background as default for devo12-XMS
(24-02-2018)
Last edit: 26 Feb 2018 07:24 by vlad_vy.
24 Feb 2018 08:06 - 24 Feb 2018 08:07 #67732 by M8A4X
Replied by M8A4X on topic Ultimate Devo F12E (devof12e-XMS) builds
Hi Bisky!
Have you selected "Mode 1" in Transmitter menu-->Transmitter config-->Stick mode-->Mode 1 ?
Last edit: 24 Feb 2018 08:07 by M8A4X.
24 Feb 2018 08:25 #67733 by Bisky
M8A4X wrote: Hi Bisky!
Yes...
24 Feb 2018 08:34 - 24 Feb 2018 08:36 #67734 by vlad_vy
Remove at model config "Auto=min" if you don't like throttle safety warning, or change to: "none", "min", "zero", "max"
[safety]
Auto=min
Last edit: 24 Feb 2018 08:36 by vlad_vy.
24 Feb 2018 11:00 - 24 Feb 2018 11:01 #67735 by M8A4X
@Bisky: The only way I can reproduce the behaviour of your F7 is to change the channel mapping in the mixers menu, but on my F12E/12S (Mode 2, but tested Mode 1,3,4) it is always CH3 which is shown in the alert screen, not channel 1.
BTW: the names of the channels in the remapping-screen do not represent the current selected mapping. You have to remember your current setting and shift them "blind". E.g. if 1. is RUD and you want to move it down, you have to select "1.Ail" and move it down.
Or maybe I am missing the logic behind it...
@Vlad_vy: I flashed your latest FW but my 12S seems still to be loading the background.img. The grey menu "headline" has this "fading" from dark to light grey. Do we have to enable the drawn background somewhere?
Last edit: 24 Feb 2018 11:01 by M8A4X.
Time to create page: 0.494 seconds
