Ultimate Devo F12E (devof12e-XMS) builds
24 Feb 2018 11:44 - 24 Feb 2018 11:47 #67736
Replied by vlad_vy on topic Ultimate Devo F12E (devof12e-XMS) builds
Yes, you need enable draw background at "config.ini": drawn_background=1
New "config.ini" has it disabled by default:
[background]
drawn_background=1
bg_color=50A0D8
hd_color=707070New "config.ini" has it disabled by default:
[background]
drawn_background=0
bg_color=50A0D8
hd_color=707070
Last edit: 24 Feb 2018 11:47 by vlad_vy.
- M8A4X
- M8A4X
24 Feb 2018 12:43 - 25 Feb 2018 05:35 #67737
by M8A4X
Replied by M8A4X on topic Ultimate Devo F12E (devof12e-XMS) builds
Thank you vald_vy! The re-draw is really much faster.
Just in my opinion in comparison the loading of the background image is not to bad.
But I am also not that fast anymore
Edit:
@vlad_vy: I wanted to change the config.ini back to loading the background image but the config.ini on the 12S is now "empty".
The only way to get it back to load the backgound image is to put a "fresh" copy of the config.ini onto the TX. Also, I can´t just transfer the new config.ini over to the TX and replace the existing "empty" one, an error message is displayed stating "file or directory is damaged 0x80070570". A reformat of the TX drive is necesary. This behavior is not supposed to be so, right?
For your information: The tx is booted with ENT+PowerOn into USB mode. With the "empty" config.ini the background is still drawn as it was configured before. The config.ini was only opened by notepad++, never with windows editor.
Edit:
Last edit: 25 Feb 2018 05:35 by M8A4X.
25 Feb 2018 09:40 #67759
It looks like your filesystem is damaged. You need format transmitter USB drive and rewrite filesystem. Use "Safely remove Hardware" after writing filesystem.
- M8A4X
- M8A4X
25 Feb 2018 10:25 #67760
by M8A4X
Thank you again!
Reformating, putting everything in it´s place and use the "usb safe remove" does the trick.
26 Feb 2018 07:29 - 05 Mar 2018 05:53 #67777
* Timer-based PPM protocol
"devo12-XMS" based on nightly builds:
(26-02-2018)
File deleted, see below...
(26-02-2018)
Last edit: 05 Mar 2018 05:53 by vlad_vy.
- Artus
01 Mar 2018 12:06 #67841
by Artus
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
Replied by Artus on topic Ultimate Devo F12E (devof12e-XMS) builds
Hello Vald,
I am just doing a litte more with my F12E. In the moment i try to make the MainPage for me more useful.
I have deleted a filed - and i am not able to insert a new one. I read in the document there is a menue point "ADD" - but i dont find this - scrolling down - the last entry is "Load" but i dont find the function "ADD".
My DEVO10 has such a menue point.
I have looked in the emulator - there is the same - no possibly to add a field to MainPage.
Do i something wrong?
Thanks a lot for you help
01 Mar 2018 13:48 #67843
Text GUI has fixed Main page layout. You can't add new element, you can't change any element position. You can delete/restore existing elements only.
- Artus
01 Mar 2018 17:37 #67845
by Artus
Thank you for your help Vlad,
I have tried now to edit the model-file - and there it's possible to do some changes, as i can see in the emulator.
The next question is about the TX-output power. After changing the TX-modul to a 4in1 the selected values of the output power starts with 100mü-watt- up to 150mW. Before the was a Value of 300mW ..
I always use the minimal output power in my house - cause my privat WLAN has some tubble when i am flying, and i dont want to have angry neighbours cause i my one has problems i think the rest will have some problems too, if i use a higher output power.
But if i use the lowest value 100uW (ore are this ultra-watt ??) i have seen that my WLAN has problems - more than using 1mW. I know that this values are "relativ exact", but can you tell me which is the lowest value and the highest Value i can choose ?
Thanks again Vlad
Thanks again Vlad
05 Mar 2018 05:54 - 23 Mar 2018 07:21 #67905
* Fix startup sound volume with drawn background
* Temporary fix for toggle icon position reset
(05-03-2018)
(05-03-2018)
Last edit: 23 Mar 2018 07:21 by vlad_vy.
- Stavross118
05 Mar 2018 20:14 #67918
by Stavross118
Replied by Stavross118 on topic Ultimate Devo F12E (devof12e-XMS) builds
Hi vlad_vy
F7 support for flash sst26vf032b is this not for the F12e as well?
As wrote to flash but not recognising drive?
Any help appreciated
Many thanks
Stavross
Many thanks
Stavross
06 Mar 2018 03:59 #67921
All XMS supported transmitters can use all listed flash memory chips.
I don't understand what is your problem?
- Stavross118
06 Mar 2018 06:37 #67923
by Stavross118
Ok sorry
for some reason it flashes ok but says drive not accessible in windows 10 to load over files ...thought it might be the security in the flash?
Many thanks again
Stavross
Many thanks again
Stavross
- Stavross118
06 Mar 2018 06:41 #67924
by Stavross118
this is the flash memory I have installed in my F12e sst26vf032bStavross118 wrote: Ok sorry
Many thanks again
Stavross
06 Mar 2018 07:33 - 06 Mar 2018 08:20 #67925
Flashing the firmware is not related to flash memory chip, you flash firmware to MCU flash memory. So you have problem with the flash memory chip. Check chip for solder splashes, proper pins soldering and so on.
Last edit: 06 Mar 2018 08:20 by vlad_vy.
- Stavross118
06 Mar 2018 08:05 #67926
by Stavross118
You are great
Totally right 2 of the legs not connecting to the solder added a bit more solder and voila all working and formatting and loading up correctly
Thank you so much vlad_vy
No more fs files yeah
23 Mar 2018 07:28 - 25 Mar 2018 05:06 #68304
* Proper fix for issue #297 and introduced bug
* Fix "ENTRIES_BY_SCREENSIZE" for 480x272x16 GUI
* Fix 128x64x1 "Channel monitor->Stick input" page
* Add protocol for Corona V1/V2 and Flydream V3
* Support 16 channels for FrskyX and 14 for AFHDS
* Fix Corona protocol modular build
(23-03-2018)
(23-03-2018)
Last edit: 25 Mar 2018 05:06 by vlad_vy.
25 Mar 2018 05:07 - 11 May 2018 05:01 #68340
* Fix Corona protocol, from hexfet
(25-03-2018)
(25-03-2018)
Last edit: 11 May 2018 05:01 by vlad_vy.
- KnzHz
15 Apr 2018 07:56 #68658
by KnzHz
Replied by KnzHz on topic Ultimate Devo F12E (devof12e-XMS) builds
I've tried to read the entire thread and even search on the forums a bit, I'm sure this has been answered before so my apologies, just couldn't find it.
I see that XMS builds are for modded extra memory, but I can't seem to find out what the benefits are?
I mean, it has more space, so for future development but am I missing out without the mod right now?
- YARIMbe
15 Apr 2018 07:59 #68659
by YARIMbe
Replied by YARIMbe on topic Ultimate Devo F12E (devof12e-XMS) builds
without the mod there is no way to run deviationtx firmware which allows you to add more protocols and modules.. also it enable you to get more out of your remote control in a sense that it allows more modifications to be made
- KnzHz
15 Apr 2018 08:19 #68660
by KnzHz
Well, I flashed the "non-XMS" build last night and everything seems to be working? So what has been "left out"?
Time to create page: 1.405 seconds
Builds
- Ultimate Devo F12E (devof12e-XMS) builds
