Ultimate Devo F12E (devof12e-XMS) builds
22 Feb 2018 06:42 - 22 Feb 2018 07:05 #67677
Example with a drawn background:
We need to do it configurable -> background color and header color. Now it has fixed colors:
Replied by vlad_vy on topic Ultimate Devo F12E (devof12e-XMS) builds
FDR wrote: Nice!
Probably we should play with a drawn background, or at least use a one pixel wide image and stretch that...
void _gui_draw_background(int x, int y, int w, int h)
#ifdef _DEVO12_XMS_TARGET_H_
if(y + h < 32) {
LCD_FillRect(x, y, w, h, RGB888_to_RGB565(0x80, 0x80, 0x80));
} else if(y >= 32) {
LCD_FillRect(x, y, w, h, RGB888_to_RGB565(0x90, 0xc0, 0xe0));
} else {
LCD_FillRect(x, y, w, 32 - y, RGB888_to_RGB565(0x80, 0x80, 0x80));
#else
LCD_DrawWindowedImageFromFile(x, y, "media/backgrnd" IMG_EXT, w, h, x, y);
#endif
Last edit: 22 Feb 2018 07:05 by vlad_vy.
22 Feb 2018 07:16 #67679
Replied by FDR on topic Ultimate Devo F12E (devof12e-XMS) builds
Fine.
Is it remarkably faster that way?
22 Feb 2018 07:19 #67680
Actually I feel this slow refresh even on my DEVO 8, so it might be a generic solution for all color transmitters, but it would be great if it was a configurable option...
22 Feb 2018 07:41 #67681
I will test it today.
FDR wrote: Fine.
22 Feb 2018 09:55 - 22 Feb 2018 09:57 #67683
Now with v5.0.0 build I can select and configure the display background (image or drawn background):
With some code changes and "config.ini" values:
[background]
drawn_background=1
bg_color=90C0E0
hd_color=808080
Last edit: 22 Feb 2018 09:57 by vlad_vy.
22 Feb 2018 10:10 #67684
Cool!
Could you test the speed difference?
22 Feb 2018 10:25 - 22 Feb 2018 10:32 #67686
Last edit: 22 Feb 2018 10:32 by vlad_vy.
22 Feb 2018 10:40 #67688
Actually it's hard to measure. Probably the best way would be counting video frames from the beginning of the refresh till the end, but I'm more interested in the "feel"
22 Feb 2018 10:41 #67689
...or with some code change you could log the time spent...
22 Feb 2018 13:13 #67691
About GUI speed with drawn background:
1. devo12-XMS - background draw much faster than normal devo12, I think it even slightly faster or equal to devo8 with image background. At least, now the background draw faster than all GUI objects on a page. It's only brief fraction of a second.
2. devo8 - background draw almost instantly, I can't see this moment. The whole GUI works instantly.
22 Feb 2018 14:44 - 23 Feb 2018 11:04 #67694
* Add selectable and configurable drawn background.
"devo12-XMS" based on nightly builds:
(22-02-2018)
File deleted, see below...
You can select to draw background instead a background image for color GUI. This will greatly speed up the drawing of the pages. You can set header color and background color. The settings are in "config.ini" file. By default used background image.
[background]
drawn_background=0
bg_color=50A0D8
hd_color=707070"devo12-XMS" based on nightly builds:
(22-02-2018)
Last edit: 23 Feb 2018 11:04 by vlad_vy.
22 Feb 2018 15:55 - 22 Feb 2018 15:56 #67696
Optimized draw background. It work slightly faster and page update looks more smooth.
"devo12-XMS" build updated.
Last edit: 22 Feb 2018 15:56 by vlad_vy.
23 Feb 2018 11:04 - 24 Feb 2018 07:59 #67706
Last edit: 24 Feb 2018 07:59 by vlad_vy.
- Bisky
23 Feb 2018 15:21 #67712
by Bisky
Devo F7 XMS + 4in1 module
Replied by Bisky on topic Ultimate Devo F12E (devof12e-XMS) builds
I heave mode1 setings, when i Switch on my F7 it says throtle not idile position and I heave to move the left, not the right stick wich is allrady ideile. After I move the left stick down the massage goes away and my right stick is throttle channel...
24 Feb 2018 08:01 - 26 Feb 2018 07:24 #67731
* Fix color GUI "Voice config" page
* Set drawn background as default for devo12-XMS
(24-02-2018)
(24-02-2018)
Last edit: 26 Feb 2018 07:24 by vlad_vy.
- M8A4X
- M8A4X
24 Feb 2018 08:06 - 24 Feb 2018 08:07 #67732
by M8A4X
Replied by M8A4X on topic Ultimate Devo F12E (devof12e-XMS) builds
Hi Bisky!
Have you selected "Mode 1" in Transmitter menu-->Transmitter config-->Stick mode-->Mode 1 ?
Last edit: 24 Feb 2018 08:07 by M8A4X.
- Bisky
24 Feb 2018 08:25 #67733
by Bisky
Yes...
M8A4X wrote: Hi Bisky!
Yes...
24 Feb 2018 08:34 - 24 Feb 2018 08:36 #67734
Remove at model config "Auto=min" if you don't like throttle safety warning, or change to: "none", "min", "zero", "max"
[safety]
Auto=min
[safety]
Auto=min
Last edit: 24 Feb 2018 08:36 by vlad_vy.
- M8A4X
- M8A4X
24 Feb 2018 11:00 - 24 Feb 2018 11:01 #67735
by M8A4X
@Bisky: The only way I can reproduce the behaviour of your F7 is to change the channel mapping in the mixers menu, but on my F12E/12S (Mode 2, but tested Mode 1,3,4) it is always CH3 which is shown in the alert screen, not channel 1.
BTW: the names of the channels in the remapping-screen do not represent the current selected mapping. You have to remember your current setting and shift them "blind". E.g. if 1. is RUD and you want to move it down, you have to select "1.Ail" and move it down.
Or maybe I am missing the logic behind it...
@Vlad_vy: I flashed your latest FW but my 12S seems still to be loading the background.img. The grey menu "headline" has this "fading" from dark to light grey. Do we have to enable the drawn background somewhere?
Last edit: 24 Feb 2018 11:01 by M8A4X.
Time to create page: 0.308 seconds
Builds
- Ultimate Devo F12E (devof12e-XMS) builds
