4 in 1 module technical data
- Bracame
19 Apr 2017 15:36 #61587
by Bracame
4 in 1 module technical data was created by Bracame
I've just ordered this module : us.banggood.com/Wholesale-Warehouse-CC25...7.html?rmmds=myorder .
My goal is to drive it with a DIY transmitter based on a MEGA2560.
Frsky & Skyartec work well at this time with a (alone) CC2500.
My question is about voltage : Is this module (4 in 1) 5V tolerant or just 3.3V on pin miso, mosi, etc ... ?
Is there any schematic ? (would help
Thanks in advance.
Thanks in advance.
- Fernandez
20 Apr 2017 17:23 #61617
by Fernandez
Replied by Fernandez on topic 4 in 1 module technical data
You are much better off ditching your mega2560 and go for deviation......
As I see you are a real modder, possibly you can help the community; There are few topics on porting deviation onto a standard ARM development board + display.
www.deviationtx.com/forum/7-development/...itter-board?start=80
- aMax
20 Apr 2017 18:40 - 20 Apr 2017 18:41 #61620
by aMax
Replied by aMax on topic 4 in 1 module technical data
@Bracame
These pins are for max 3.3 V input only! Be careful.
Last edit: 20 Apr 2017 18:41 by aMax.
- Bracame
20 Apr 2017 19:36 #61622
by Bracame
Thanks aMax, it works with STM32 : 3.3V ... I'll use a level converter. (I'm in test with a TXS0108E and a CC2500
@Fernandez : Thank for the link and... I keep the M2560. Development is harder with all other options actives (Telemetry, SDCard, Voice, rot encoder, ...) but I like that
Replied by Bracame on topic 4 in 1 module technical data
aMax wrote: @Bracame
- Bracame
07 May 2017 08:56 - 08 May 2017 20:19 #62092
by Bracame
4 in 1 just arrived here, It's a V1.1 ...
There a place for an other regulator on this new revision, I don't see other difference.
Do you know changes between V1.0 & V1.1 ?
Regards
Edit : Found I think (Thanks Mentero ) -> www.deviationtx.com/forum/7-development/...ule?start=1200#59614
Regards
Last edit: 08 May 2017 20:19 by Bracame.
Time to create page: 0.053 seconds
Builds
- 4 in 1 module technical data
