Jumper T8SG builds
29 Oct 2017 06:36 #65339 by vlad_vy
Replied by vlad_vy on topic Jumper T8SG builds
I don't see any FlySky changes at main branch. So, fix is not integrated.
29 Oct 2017 07:17 #65340 by SeByDocKy
Replied by SeByDocKy on topic Jumper T8SG builds
vlad_vy wrote: I don't see any FlySky changes at main branch. So, fix is not integrated.
From here: www.deviationtx.com/forum/6-general-disc...tency?start=20#65048
I guess it need more testing .... but should be integrated :)
29 Oct 2017 20:38 #65349 by FDR
Replied by FDR on topic Jumper T8SG builds
@Vlad!
Where is the source of this target?
Is it only on your computer? I couldn't find it in your repo...
30 Oct 2017 03:46 #65360 by vlad_vy
Since we not decided what to use, devo7e-256 or specific T8SG build, I use local build only. Send me your e-mail and I will send current T8SG souce.
30 Oct 2017 05:11 #65362 by FDR
PM sent...
30 Oct 2017 05:19 #65363 by vlad_vy
Check your mail.
30 Oct 2017 06:03 #65364 by FDR
31 Oct 2017 18:41 #65385 by fneuf
Replied by fneuf on topic Jumper T8SG builds
I received my TX and it is already running the specific T8SG build dated from the 05/10. Should I update it first thing?
31 Oct 2017 19:27 #65386 by TJ63
Replied by TJ63 on topic Jumper T8SG builds
I would. There's been quite a few changes since the 5th. I updated mine (received yesterday) to the firmware dated 27th October.
01 Nov 2017 03:48 - 01 Nov 2017 03:51 #65391 by vlad_vy
Will be better to update to recent build. 17/10 was fixed switch mapping, see:
www.deviationtx.com/forum/builds/7346-jumper-t8sg-builds#64964
You can flash firmware file (*.dfu) only.
Last edit: 01 Nov 2017 03:51 by vlad_vy.
01 Nov 2017 07:03 #65396 by rsh78ph
Replied by rsh78ph on topic Jumper T8SG builds
Just go my Jumper yesterday and upgraded it to 10-27 build from 10-07 stock firmware.
Checking the channel mixers and found that aux 4 & 5 knobs aren't being read.
Is this a current issue?
Thank you
01 Nov 2017 09:25 #65400 by vlad_vy
Most likely you need calibrate knobs along with sticks.
04 Nov 2017 17:25 #65508 by drjpwaldo`
Replied by drjpwaldo` on topic Jumper T8SG builds
New T8SG arrived 11-3-2017. Updated firmware to 10-27 build. Will not hold bind to E010. Binds temporarily, then unbinds. Used setup from online video for T8SG and e010. MJXq portocol with e010 selected. Multi model type. PPM none. Thoughts or known problem?? Maybe binding procedure more complicated than I know?? Using this radio with my tiny whoop was one of the main reasons I purchased.
Can I go back to an older build that works well?? Where would I find the archived files??
04 Nov 2017 18:46 - 09 Nov 2017 05:30 #65514 by vlad_vy
All last builds change nothing for MJXq protocol.
Probably your T8SG had 2017-10-5 firmware, filesystem is not changed.
File deleted...
Last edit: 09 Nov 2017 05:30 by vlad_vy.
04 Nov 2017 19:31 #65515 by Iroquois
Replied by Iroquois on topic Jumper T8SG builds
All of this is fascinating gentlemen, but can ANYBODY tell me what that green LED indicates?
05 Nov 2017 00:13 #65525 by horrigan
Replied by horrigan on topic Jumper T8SG builds
lads am I going mad, where do I get the latest tsg8 builds, switches reversed ect...??
05 Nov 2017 06:03 - 05 Nov 2017 09:01 #65528 by vlad_vy
Green LED indicate proper work of switching for four RF chips and output power. It has to be continually green.
Last edit: 05 Nov 2017 09:01 by vlad_vy.
05 Nov 2017 08:45 - 07 Nov 2017 07:13 #65535 by vlad_vy
Summary of changes from stock T8SG:
* RUD and AIL reversed to comply with common direction for Deviation.
* Rotary knobs (AUX4 and AUX5) direction reversed to comply with common direction for Deviation.
* All four switches SWA, SWB, SWC and SWD reversed to comply with common direction for Deviation.
* Fix switch mapping for foreign model files.
Current changes:
* Prevent mux voice from triggering sound before welcome has played, from TheRealMoeder
T8SG based on devo7e-256 Nightly Builds:
File deleted, see below...
Last edit: 07 Nov 2017 07:13 by vlad_vy.
05 Nov 2017 08:52 - 05 Nov 2017 08:55 #65536 by vlad_vy
If you like you can use T8SG build based on stable v5.0.0 - at the end of topic "Deviation v5.0.0 build with latest protocols":
www.deviationtx.com/forum/builds/6407-de...ith-latest-protocols
Don't forget to change filesystem, it different from Nightly Builds.
Last edit: 05 Nov 2017 08:55 by vlad_vy.
05 Nov 2017 09:02 #65537 by horrigan
cheers Vald, I was looking late last night, with a few alcoholic beverages on board. Hope I didn't mess anything up :blink: :S
Time to create page: 0.622 seconds
