Jumper T8SG builds
29 Oct 2017 06:36 #65339
Replied by vlad_vy on topic Jumper T8SG builds
I don't see any FlySky changes at main branch. So, fix is not integrated.
- SeByDocKy
29 Oct 2017 07:17 #65340
by SeByDocKy
From here: www.deviationtx.com/forum/6-general-disc...tency?start=20#65048
I guess it need more testing .... but should be integrated
Replied by SeByDocKy on topic Jumper T8SG builds
vlad_vy wrote: I don't see any FlySky changes at main branch. So, fix is not integrated.
29 Oct 2017 20:38 #65349
Replied by FDR on topic Jumper T8SG builds
@Vlad!
Where is the source of this target?
Is it only on your computer? I couldn't find it in your repo...
30 Oct 2017 03:46 #65360
Since we not decided what to use, devo7e-256 or specific T8SG build, I use local build only. Send me your e-mail and I will send current T8SG souce.
- fneuf
31 Oct 2017 18:41 #65385
by fneuf
Replied by fneuf on topic Jumper T8SG builds
I received my TX and it is already running the specific T8SG build dated from the 05/10. Should I update it first thing?
- TJ63
31 Oct 2017 19:27 #65386
by TJ63
Replied by TJ63 on topic Jumper T8SG builds
I would. There's been quite a few changes since the 5th. I updated mine (received yesterday) to the firmware dated 27th October.
01 Nov 2017 03:48 - 01 Nov 2017 03:51 #65391
Will be better to update to recent build. 17/10 was fixed switch mapping, see:
www.deviationtx.com/forum/builds/7346-jumper-t8sg-builds#64964
You can flash firmware file (*.dfu) only.
Last edit: 01 Nov 2017 03:51 by vlad_vy.
- rsh78ph
01 Nov 2017 07:03 #65396
by rsh78ph
Replied by rsh78ph on topic Jumper T8SG builds
Just go my Jumper yesterday and upgraded it to 10-27 build from 10-07 stock firmware.
Checking the channel mixers and found that aux 4 & 5 knobs aren't being read.
Is this a current issue?
Thank you
Thank you
01 Nov 2017 09:25 #65400
Most likely you need calibrate knobs along with sticks.
- drjpwaldo`
04 Nov 2017 17:25 #65508
by drjpwaldo`
Replied by drjpwaldo` on topic Jumper T8SG builds
New T8SG arrived 11-3-2017. Updated firmware to 10-27 build. Will not hold bind to E010. Binds temporarily, then unbinds. Used setup from online video for T8SG and e010. MJXq portocol with e010 selected. Multi model type. PPM none. Thoughts or known problem?? Maybe binding procedure more complicated than I know?? Using this radio with my tiny whoop was one of the main reasons I purchased.
Can I go back to an older build that works well?? Where would I find the archived files??
04 Nov 2017 18:46 - 09 Nov 2017 05:30 #65514
All last builds change nothing for MJXq protocol.
Probably your T8SG had 2017-10-5 firmware, filesystem is not changed.
File deleted...
File deleted...
Last edit: 09 Nov 2017 05:30 by vlad_vy.
- Iroquois
04 Nov 2017 19:31 #65515
by Iroquois
Replied by Iroquois on topic Jumper T8SG builds
All of this is fascinating gentlemen, but can ANYBODY tell me what that green LED indicates?
- horrigan
05 Nov 2017 00:13 #65525
by horrigan
Replied by horrigan on topic Jumper T8SG builds
lads am I going mad, where do I get the latest tsg8 builds, switches reversed ect...??
05 Nov 2017 06:03 - 05 Nov 2017 09:01 #65528
Green LED indicate proper work of switching for four RF chips and output power. It has to be continually green.
Last edit: 05 Nov 2017 09:01 by vlad_vy.
05 Nov 2017 08:45 - 07 Nov 2017 07:13 #65535
Summary of changes from stock T8SG:
* RUD and AIL reversed to comply with common direction for Deviation.
* Rotary knobs (AUX4 and AUX5) direction reversed to comply with common direction for Deviation.
* All four switches SWA, SWB, SWC and SWD reversed to comply with common direction for Deviation.
* Fix switch mapping for foreign model files.
Current changes:
* Prevent mux voice from triggering sound before welcome has played, from TheRealMoeder
T8SG based on devo7e-256 Nightly Builds:
File deleted, see below...
Current changes:
Last edit: 07 Nov 2017 07:13 by vlad_vy.
05 Nov 2017 08:52 - 05 Nov 2017 08:55 #65536
If you like you can use T8SG build based on stable v5.0.0 - at the end of topic "Deviation v5.0.0 build with latest protocols":
www.deviationtx.com/forum/builds/6407-de...ith-latest-protocols
Don't forget to change filesystem, it different from Nightly Builds.
Last edit: 05 Nov 2017 08:55 by vlad_vy.
- horrigan
05 Nov 2017 09:02 #65537
by horrigan
cheers Vald, I was looking late last night, with a few alcoholic beverages on board. Hope I didn't mess anything up
Time to create page: 1.300 seconds
Builds
- Jumper T8SG builds
