Devo F7 - Backlight and P/B Light Dimmer Funktion
  • Schiefy01
  • Schiefy01's Avatar Topic Author
  • Devo10 / Devo F7 / Devo F7DS
29 Nov 2017 23:50 - 29 Nov 2017 23:52 #66272 by Schiefy01
on My Devo F7 and Devo F7DS i use the FW -> Devof7-v5.0.0-be57e84
For me the Dimming is not Working well.
On my Devo10 the Dimming is working very well, after the Adjusted Time the Diplay goes to dark,
but on the F7 there is nearly no differnce between Dimming and Normal. In Dimming Mod is mostly more bright as in normal mod.
The Pushbutton is shining all the Time.
Transmitter Menu
1. Transmitter Config
-> Backlight: 1 bright - 9 slightly darker -> 10 is off
-> Dimmer time: steps in 5 seconds is Okay
-> Dimmer target: off -> 1-10 not Working, it´s make more brightly shine LCD backlight.
In Summery:
Backlight steps must be more efficent to reduce more light (bright to dark, Scale 1-10 must be Adjusted)
Dimmer Target shoud reduce the brightness to the new Adjusted scale 1-10
The Blue Shining Ring (around the Pushbutton) must be switched off in accordance to the Dimmer Time Value.
Hopefully somebody can fix it and provide me a working dfu.
THX
Sven
Last edit: 29 Nov 2017 23:52 by Schiefy01.
11 Dec 2017 13:49 #66442 by xuyuan
Hi, I have fixed this issue: github.com/xuyuan/deviation/commit/07d5b...f5d5f6ed99bf65f79a79
If you have 4M memory installed, I can provide mine binary.
  • Schiefy01
11 Dec 2017 14:59 #66446 by Schiefy01
Thanks for the reply...
4M ? means the memory?
I have the Standard Out the Box and only Put Deviation on it. (and Puted an external Port for the 5.8ghz Antenna)
For me i need the FW with this Fix included.
Sven
11 Dec 2017 15:06 - 12 Dec 2017 04:34 #66447 by vlad_vy
Try this build with fix, based on latest nightly.
File deleted...
Last edit: 12 Dec 2017 04:34 by vlad_vy.
  • Schiefy01
11 Dec 2017 16:50 #66449 by Schiefy01
Thanks for the build an the Fix.
No it´s Working on a good track :-)
The Backlightvalue and the Dimmer Function Working Fine :-)
Another Request:
1)
Is it possible to add Dimmer target "0"
(means iff you putt Backlight to "0" the Display Light is complitly Off, add this Value also for Dimmer target, for some Modells do not need Display during the RC Controll, Sticks are not effecting the Dimmer Function)
2)
The blue Shining Rings aroud the PB are allways shining, could this also be turned Off in Dimming Mode ???
.... programming is not my World.
many thx to all for the very Good Support ;-)
BR
Sven
12 Dec 2017 04:49 - 13 Dec 2017 04:40 #66458 by vlad_vy
Can you test next version? I think you will get lower brightness with low backlight values. Dimmer target "Off" equal to "0". I don't see any MCU pin that control the blue Shining Rings around the PB, probably it is "Power ON" indicator.
File deleted...
Last edit: 13 Dec 2017 04:40 by vlad_vy.
  • Schiefy01
12 Dec 2017 23:25 #66468 by Schiefy01
Test Performed, Working very Well.
Now you see Big diferences During Dimming !!!
Perfekt... Big Thanks !!!!
With the 12.12.2017 Build:
On my Devo F7DS -> Dim Off = LCD Off
-> Dim 1 = lightly shining
On my Devo F7 -> Dim Off = Display is on, eaqual to Dim1 of my F7DS
Maybe Therefore musst be more Hardware diferences not only the Videosystem....
The P/B LED seams to be hardwired to the Power BUS.
I will Check next time when i'll Open it.
BR
Sven
13 Dec 2017 03:35 #66471 by vlad_vy
Other user tested his Devo F7 and with Dimmer target = off, LCD is Off. So, it can be difference with specific Devo F7.
Time to create page: 0.192 seconds
