iRangeX iRX-IR8M builds no more?!
25 Jan 2018 19:13 - 31 Jan 2018 04:49 #67156
iRangeX iRX-IR8M builds was created by vlad_vy
Since iRangeX iRX-IR8M (t8sg-v5.x.x-2017-09-19) is somewhat different from Jumper T8SG I will place here the builds for iRangeX iRX-IR8M.
Changes:
* RUD and AIL reversed to comply with common direction for Deviation.
* AUX4 and AUX5 reversed to comply with common direction for Deviation.
* All switches reversed to comply with common direction for Deviation.
* batt_critical set to 3900 since iRX-IR8M can use 4xAA battery.
* LCD Internal Resistor Rate (Rb/Ra) set to 4 (0x24).
(2018-01-26)
iRangeX iRX-IR8M based on Nightly Builds:
File deleted, see below...
Changes:
(2018-01-26)
Last edit: 31 Jan 2018 04:49 by vlad_vy.
- betoinbeta
26 Jan 2018 05:17 - 26 Jan 2018 06:19 #67172
by betoinbeta
Replied by betoinbeta on topic iRangeX iRX-IR8M builds
I attempted to update my iRange Transmitter using the latest build but the start screen does not show the latest build number which I assume means it did not update.
Also, The Transmitter freezes up when I try to change the icon.
Have I done something wrong?
Last edit: 26 Jan 2018 06:19 by betoinbeta.
26 Jan 2018 06:43 #67175
Replied by vlad_vy on topic iRangeX iRX-IR8M builds
At "About" page you have to see "ir8m-v5.x.x-2018-01-25".
Try to slow format USB drive and write filesystem from archive. Use "Safely Remove Hardware" after writing filesystem.
- SeByDocKy
26 Jan 2018 07:33 #67179
by SeByDocKy
Replied by SeByDocKy on topic iRangeX iRX-IR8M builds
You attached the x25.zip file note the x24 ?
26 Jan 2018 07:40 #67180
You have a problems? It should be "24" version, but built 2018-01-25.
- SeByDocKy
26 Jan 2018 07:43 #67181
by SeByDocKy
Ha no
sorry I was confused with the date no problem so
vlad_vy wrote: You have a problems? It should be "24" version, but built 2018-01-25.
Ha no
26 Jan 2018 11:04 #67192
Just for sure I replaced IR8M build with fresh "24" version - 2018-01-26.
- Stefan_UK
28 Jan 2018 02:43 #67224
by Stefan_UK
Replied by Stefan_UK on topic iRangeX iRX-IR8M builds
Thank you very much, I updated my iRangeX iRX-IRM8 without any issues. I did have to recalibrate my sticks but I guess this is to be expected. The gimbals aren't very good on this TX.
31 Jan 2018 04:49 - 14 Feb 2018 06:00 #67301
Changes:
* Add support for 6 independent trims set.
You can use 4-6 contiguous virtual channels to setup 4-6 pos switch, then assign to trims "Switch" the first used virtual channel and you will have 4-6 independent trims set. The virtual channels switch at any state should have only single channel with +100% value, all others -100%. It's intended for for 4-6 flight modes with independent trims settings.
(2018-01-31)
Previous changes:
* LCD Internal Resistor Rate (Rb/Ra) set to 4 (0x24).Changes:
(2018-01-31)
Last edit: 14 Feb 2018 06:00 by vlad_vy.
- JLo66
02 Feb 2018 11:32 #67361
by JLo66
Replied by JLo66 on topic iRangeX iRX-IR8M builds
Hi guys,
I flashed the firmware and now I get a "Missing Modules: A7105 ..." error on startup.
Is there a way to fix this error?
02 Feb 2018 11:54 - 02 Feb 2018 11:57 #67362
Is it works "OK" before flashing firmware? Do you rewrite filesystem? If yes, try format USB drive, write filesystem from archive and use "Safely Remove Hardware".
Last edit: 02 Feb 2018 11:57 by vlad_vy.
- JLo66
02 Feb 2018 22:24 #67370
by JLo66
It worked fine before flashing the firmware. Have formatted, reflashed, ejected USB safely again. Still same problem.
03 Feb 2018 06:14 - 03 Feb 2018 06:14 #67373
I don't know what may be wrong. Have you backup of original filesystem? Can you provide original "hardware.ini"? If it equal to current "hardware.ini" probably you have hardware problem.
As last resort, can you try different iRangeX iRX-IR8M build, based on v5.0.0 release core?
www.deviationtx.com/forum/builds/6407-de...cols?start=300#67350
Last edit: 03 Feb 2018 06:14 by vlad_vy.
- Stefan_UK
03 Feb 2018 06:43 - 03 Feb 2018 07:31 #67374
by Stefan_UK
Hi vlad_vy,
I guess this isn't going to help JLo66 but the new firmware 2018-01-31 worked fine for me so this might be a user-specific device problem. Another thought sprung to mind JLo66 is to revert back to the original firmware (vlad_vy suggested) to see if the problem persists and if this works try the latest update again. People really need to understand that they need to Safely Remove USB media storage devices because not only the data can be lost/corrupted but on very rare occasions the storage device can be permanently damaged. JLo66 did you use the correct version of the DFU upgrade tool you should be using Walkera Dfuse USB Upgrade Tools 2.31. If I can think of anything else that might help I will post here in the meantime waiting for feedback from JLo66.
Regards, Stefan
PS What if any models was the model that was configured prior to the upgrade failure and which protocol was being used? Switch the TX on when you get the error hit the exit button to see if you can continue and then proceed with the model setup. In the model setup load a new model from scratch and configure it using a different protocol save then switch off TX wait 30 secs and power TX back on to see if the problem persists. If the problem goes away edit the model setup selecting your required protocol to see what happens.
Regards, Stefan
Last edit: 03 Feb 2018 07:31 by Stefan_UK. Reason: Added aditional content
- mbelazrag
06 Feb 2018 08:22 #67413
by mbelazrag
Replied by mbelazrag on topic iRangeX iRX-IR8M builds
can any1 plz tell me how to delet a model?
06 Feb 2018 09:39 - 06 Feb 2018 09:41 #67414
You can "reset" any model to default state. At Model setup page, select "File: Load..." and scroll to "Reset", press ENT.
Last edit: 06 Feb 2018 09:41 by vlad_vy.
- Rec0iL
07 Feb 2018 08:32 #67426
by Rec0iL
Replied by Rec0iL on topic iRangeX iRX-IR8M builds
Me and my friend have really trouble using FrSky Recievers with this remote.
(We both own one)
Other recievers work fine (AFHDS 2A).
We bind the recievers and go in to the fine freq tuning on 10mW, we find the upper limit, and the lower limit,we take the average and set it to it.
When testflying this we cant get any decent range even with 150mW. (Remote was restarted after switching TX strength)
My micro dropped out of the air after 15 meters in a garage..
in an open space environment 50-100m is all we get using a FrSky R-XSR Ultra then it goes failsafe.
The Flysky X6B doesnt drop below 60 RSSI in the same environment.
Is it some bug or are we doing something wrong? Is it the internal Antenna or the TX module that is the cause of the problem?
Please Help.
(We both own one)
Please Help.
07 Feb 2018 08:56 - 07 Feb 2018 09:05 #67427
I think you have the problem RF module. There are many range and other problems with RF module. It looks like iRangeX have a quality problems with RF module.
Jumper T8SG use different version 4in1 RF module with shield and almost no complaints.
Last edit: 07 Feb 2018 09:05 by vlad_vy.
- steezcrust
07 Feb 2018 15:10 #67429
by steezcrust
Replied by steezcrust on topic iRangeX iRX-IR8M builds
having the exact same problem
- mbelazrag
07 Feb 2018 19:46 #67435
by mbelazrag
Thanks man appreciate it, is there a manual or guide on how to use this thing? I am a futaba user and this is way different for me. I couldn't even figure out how to setup dual rates.
vlad_vy wrote: You can "reset" any model to default state. At Model setup page, select "File: Load..." and scroll to "Reset", press ENT.
Time to create page: 0.212 seconds
Builds
- iRangeX iRX-IR8M builds no more?!
