iRangeX iRX-IR8M builds no more?!
- maxx
14 May 2018 04:41 - 29 May 2018 04:25 #69207
Replied by vlad_vy on topic iRangeX iRX-IR8M builds
Since iRangeX iRX-IR8M (t8sg-v5.x.x-2017-09-19) is somewhat different from Jumper T8SG I will place here the builds for iRangeX iRX-IR8M.
Changes:
* Don't identify as USBHID mouse (fixes USBHID on Mac OSX), from netmute
(2018-05-14)
iRangeX iRX-IR8M based on Nightly Builds:
Files deleted, see Nightly builds...
Previous changes:
* RUD and AIL reversed to comply with common direction for Deviation.
* AUX4 and AUX5 reversed to comply with common direction for Deviation.
* All switches reversed to comply with common direction for Deviation.
* batt_critical set to 3900 since iRX-IR8M can use 4xAA battery.
* LCD Internal Resistor Rate (Rb/Ra) set to 4 (0x24).
* Add support for 6 independent trims set.
* Add protocol for Corona V1/V2 and Flydream V3, from hexfet
* Support 16 channels for FrskyX and 14 for AFHDS-2A, from hexfet
* Fix Corona protocol, from hexfet
* More reliable and beep only once "beep" mux
* More reliable and sound only once "voice" muxChanges:
(2018-05-14)
Last edit: 29 May 2018 04:25 by vlad_vy.
- LOL789
17 May 2018 11:05 #69273
by LOL789
Replied by LOL789 on topic iRangeX iRX-IR8M builds
The development of an emulator for ir8m (deviation-emu-ir8m-v5.xx...) planned?
thanks
thanks
17 May 2018 11:17 #69275
I think you can use devo7e-256 emulator, but replace "hardware.ini" with "hardware.ini" from IR8M. The only thing that will not work correctly - import model files from other Deviation transmitters.
- michelpa
19 May 2018 15:21 #69322
by michelpa
Replied by michelpa on topic iRangeX iRX-IR8M builds
I try to use deviation-uploader cause I don't have a windows pc here...
I've try to run 0.9.0 from git and ... I can't flash...
is it absolutly impossible or with some hack...
thx
thx
- michelpa
19 May 2018 17:13 - 19 May 2018 17:15 #69324
by michelpa
oups ok as root...
sorry for noise
github version is ok
thx a lot!
sorry for noise
thx a lot!
Last edit: 19 May 2018 17:15 by michelpa.
22 May 2018 03:39 #69362
DeviationUploader-0.9.0
www.deviationtx.com/downloads-new/category/161-dfu-usb-tool#
- argha
25 May 2018 20:14 #69408
by argha
Replied by argha on topic iRangeX iRX-IR8M builds
Hello Need Help !! I am getting an error with iRangeX IRX IR8M missing modules CYRF6936 .. I have flushed "deviation-ir8m-v5.x.x-2018-05-14.dfu"
Now I cannot recover !! can some one help with the default firmware I have not taken a backup...
- maxx
26 May 2018 08:30 #69416
by maxx
Replied by maxx on topic iRangeX iRX-IR8M builds
Salut avec les mis à jours sa part
- Stefan_UK
26 May 2018 17:42 - 26 May 2018 18:29 #69420
by Stefan_UK
Replied by Stefan_UK on topic iRangeX iRX-IR8M builds
ARGHA, I have attached the build from 25th March 2018 which is a good build in my opinion. I was testing VLAD_VY various builds for him at this time regarding this missing module issue. Anyway, I have uploaded this better build for you to try. Please let me know how you get on?
Regards, Stefan
Regards, Stefan
Last edit: 26 May 2018 18:29 by Stefan_UK. Reason: Typing Error
- argha
27 May 2018 20:04 #69439
by argha
Hello Stefan,
Thanks for the help I tried the updated firmware "deviation-ir8m-v5.x.x-2018-03-25.zip" still no luck getting the same error as before "missing Modules CRYF6936 ,,,, " Now I doubt that might be its a faulty transmitter but its new just got this few days back from banggood.
Thanks for the help anyways, can some one suggest any troubleshooting ?
Thanks.
Argha
Thanks.
Argha
- Stefan_UK
27 May 2018 22:56 - 27 May 2018 23:09 #69440
by Stefan_UK
Hi argha, I have the version one of the iRX-IR8M, but I still have a backup of the original firmware, that it was shipped with. I'm not sure what version tool you are using, as the updater? I am therefore attaching the shipped default firmware and giving you a link to my dropbox, for the updater that I use. I can't attach the updater here, because of the 2 MB attachment limitation and the updater zip slightly exceeds.
Dfuse USB Upgrade Tools 2.31
www.dropbox.com/s/pvjz67wdvoon63f/Dfuse%...ools%202.31.zip?dl=0
Regards, Stefan
PS Please ignore the Zip file date, this is because I repackaged the original tool, which was compressed as a RAR and thought it might be more convenient for you in Zip format.
Regards, Stefan
Last edit: 27 May 2018 23:09 by Stefan_UK. Reason: To help Clarify my Posting
29 May 2018 04:24 #69454
Now you can download iRangeX iRX-IR8M builds from Nightly builds section.
- LOL789
08 Jun 2018 16:33 #69583
by LOL789
I received my IR8m V2 this week and I installed the new firmware (ir8m-v5.0.0-f31c081) but I get the error message "Missing Modules CYRF6936"... Finally it's a software or hardware problem ?
Thanks,
Thanks,
09 Jun 2018 03:41 #69588
Most likely it is hardware problem. But we don't know it exactly, since nobody with problem can't provide factory (original) filesystem, in particular original "hardware.ini". Most users havn't this problem after firmware upgrade.
- LOL789
09 Jun 2018 07:27 - 09 Jun 2018 07:27 #69589
by LOL789
It's the same result with the original firmware (deviation-t8sg-v5.x.x-2017-09-19) and the new firmware. So I'll contact banggood customer service...
Last edit: 09 Jun 2018 07:27 by LOL789.
- FlipSide
25 Jun 2018 17:28 #69713
by FlipSide
Replied by FlipSide on topic iRangeX iRX-IR8M builds
Can someone please provide a link to where I can download the newest firmware for the IR8M?
When I use the nightly builds it shows up as 2017 on my radio.
- Doofer
29 Jun 2018 08:24 #69735
by Doofer
Replied by Doofer on topic iRangeX iRX-IR8M builds
Anyone having range problems with the V.2 iR8M? I just got one from Banggood.
Using my ImmersionRC power meter, into 50 ohms I get:
- FRSky JR transmitter module: 65mW (rated as 100mW)
- Modded Devo 7E (cc2500): When set to 100mW, outputs 55mW.
Conclusion: if not 100% accurate, the meter is within a factor of 2
With my new V2 IR8M, from the IPEX connector on the main PCB, I get:
(Chip - Pwr into 50 ohms/DeviationTX set power, in mW)
A7105: 25/150, 25/100, 25/30, 25/10
CC2500: 2.5/150, 1.3/100, 1.2/30, 1.2/10
CYRF6936: 1/150, 0.4/100, 0.1/30, 0.02/10
NRF24L0H: 0.4/150, 0.4/100, 0.2/30, 0.2/10
So the DeviationTx 'Power' setting is at least changing something with some chips, but not all and not accurate. Okay, these are all different chips with different maxmimum power outputs. It looks like output isn't obviously being hobbled by some universal botch on the board, since the A7105 can kick out 25mW. And sure, this is a cheap Tx mainly for close-in micro-copter pilots, so perhaps it is simply caveat emptor.
My main concern is the CC2500 lack of power - I mainly fly planes on FRSky receivers, so this lamentable output needs addressing before I use this 'Full range' (it says on the box) transmitter . The CC2500 in my modded Devo 7E can manage 55mW.
Am I missing something? Has this been addressed by firmware builds? Or is there an alternative module people are fitting to get 'full range' power i.e. closer to 100mW?
- AlxG
29 Jun 2018 09:56 #69736
by AlxG
Replied by AlxG on topic iRangeX iRX-IR8M builds
Join, I have the same problem.
I do not have a power meter. but with the FrSky receiver L9R, I got a distance of 120 meters, at the maximum TX power!
Your measurements explain the reason!
Can this be fixed by FW update?
- Doofer
30 Jun 2018 07:17 #69740
by Doofer
Yes, data above consistent with firmware, or at least module control problem: A7105 max output rating 1mW, so looks like a PA (power amp) is on the board, but throttled by a LNA (must be on board because other chips power is varying), and for the other chips the PA is disabled?
Time to create page: 0.218 seconds
Builds
- iRangeX iRX-IR8M builds no more?!
