iRangeX iRX-IR8M builds no more?!
- mchaves
09 Aug 2018 10:45 #70177
by mchaves
No more iRX-IR8M builds?
tks
Replied by mchaves on topic iRangeX iRX-IR8M builds no more?!
tks
09 Aug 2018 15:46 #70184
Replied by vlad_vy on topic iRangeX iRX-IR8M builds no more?!
See Nightly builds.
- mchaves
10 Aug 2018 09:50 #70197
by mchaves
Where I get it? tks
- mchaves
11 Aug 2018 01:19 #70211
by mchaves
tks
- GabrielRB
30 Sep 2018 13:45 #71103
by GabrielRB
Replied by GabrielRB on topic iRangeX iRX-IR8M builds
Yesterday I updated my IR8M from original firmware to last build.
Using my Tiny Whoop I started to experience some lose control issues. So I make a range test:
Radio - 100uW
Receiver - Tiny Whoop FrSky D8 protocol
Latest nightly build - about 6m
Original build - much more than 10m (impossible to check inside my apartment)
Its possible that last build have range issues on D8 protocol?
Radio - 100uW
01 Oct 2018 06:59 #71115
I suspect iRangeX has some specific code change for 4IN1_FLASH, with "4in1" RF module output power lines (PE1 and PE2) management. We have not any contacts with iRangeX, so I don't know how to fix it.
- suzygs1000
01 Oct 2018 09:34 - 01 Oct 2018 10:18 #71120
by suzygs1000
Replied by suzygs1000 on topic iRangeX iRX-IR8M builds
I just upgraded my Irangex with the latest firmware, and the screen is black, and the power is connected as soon as I connect the battery. I can still get into dfu mode, by holding the ext button while plugging the batteryu in. How can I fix this?
Ok, I have now upgraded with Devo 8 - v5.0.0., which someone on the forum provided as the original fw for v1 . Power switch now works ok, but still have blank screen.
thanks Dave.
thanks Dave.
Last edit: 01 Oct 2018 10:18 by suzygs1000.
- mchaves
01 Oct 2018 10:32 #71122
by mchaves
Hi suzygs1000, I solved it by returning some versions, it follows that I keep as an emergency recovery
- GabrielRB
01 Oct 2018 23:04 #71131
by GabrielRB
I'm starting to wonder if some of range complains are no related to firmware update...
In any case my recommendation is to keep original .dfu saved somewhere as a backup just in case.
Just to highlight I was able to reach 2km with FrSky receivers using this radio+external antenna. So unless the module have the bad welding/shorts pins showed by some users this radio should work fine (even though everybody say that is totally garbage).
vlad_vy wrote: I suspect iRangeX has some specific code change for 4IN1_FLASH, with "4in1" RF module output power lines (PE1 and PE2) management. We have not any contacts with iRangeX, so I don't know how to fix it.
- suzygs1000
04 Oct 2018 03:47 #71170
by suzygs1000
Thanks, mate ... I had backed up my original files, so I have reflashed with the original firmware, and back to original now. My problem is that I can't use it with Walkera RX601 receivers, otherwise all good.
Davd.
Davd.
- QuadRacer39
08 Dec 2018 01:02 #72009
by QuadRacer39
Replied by QuadRacer39 on topic iRangeX iRX-IR8M builds
Hi there, I am new here but have been into racing RC cars for over 20 years now. 2 years ago I built my first FPV quad, a Martian 2, 5" frame. Now I have more quads than I can count.
Anyway, I gave this TX a try cause it was so cheap. When I got it, it would only give 2 missing module errors. After many tries re-flashing, and attempting to return it for a refund, I decided to try to repair it. So I took a 4 in 1 I had with the ARM chip from BANGGOOD, that was built for a Flysky tx, and removed the 4in1 module from both the iRange and the add on assembly, then installed the BGmodule into the iRange and....Voila! Now it works.
I'd bet that there are a LOT more faulty modules out there than mine. Could be the range issue I keep reading about.
Now I have figured out how to bind it and store my models in memory, but still cannot figure out how to program all my Aux switches. I want SW-B to be ch 5, A is ch 6, D-7, C-8, and the right top switch to be ch 9. I use this setup for all my quads.
CAN SOMEONE PLEASE FILL ME IN OR POINT ME TO THE PAGE I NEED TO READ TO FIGURE IT OUT PLEASE??
I am lucky to get any flight time these days. I spent my last 2 chances fiddling with this transmitter, trying to get it to work. I'd really like to fly using it now that I have it working.
Thanks,
QuadRacer39
Thanks,
QuadRacer39
- sfjuocekr
08 Dec 2018 02:31 #72011
by sfjuocekr
Replied by sfjuocekr on topic iRangeX iRX-IR8M builds
Make a complex mixer, use two or three pages and set each page to replace with a fixed value.
10 Dec 2018 12:20 #72039
Replied by FDR on topic iRangeX iRX-IR8M builds
Actually if you want to assign a two state switch to a channel, it is as simple as select one of the switch states as the source of a simple mixer. This way it will give you -100% or +100% depending on the switch state...
For the 3 way switches I prefer to use the DR&Expo template with "fixed" function, and use three values for each state, usually -100%, 0%, and +100%.
- Medhy11700
11 Dec 2018 18:03 #72051
by Medhy11700
Replied by Medhy11700 on topic iRangeX iRX-IR8M builds
Hello, I am new user of the irangex i8x, my problem is that I still can not assign AUX channels on switch 3 positions -100 / 0 / + 100! radio version t8sg-v5.x.x-2017-09-19. which compatible firmware? thank you for your help!
ps: I use a translator to communicate. cordially
- backman8571
02 Feb 2019 21:08 #72675
by backman8571
Replied by backman8571 on topic iRangeX iRX-IR8M builds no more?!
Do you have a build for Devo 12S
- Medhy11700
02 Feb 2019 21:28 #72678
by Medhy11700
Replied by Medhy11700 on topic iRangeX iRX-IR8M builds no more?!
bonjour , pas de devo 12s ! la 7e.
quelle mise a jour faudrait ?
- backman8571
02 Feb 2019 21:37 #72679
by backman8571
I would use a multi mode RF module 4 in 1
- backman8571
02 Feb 2019 21:37 #72680
by backman8571
And i would need help with where do you solder the leads for 12s and also for F12E
- dheku
28 Feb 2019 10:55 #73064
by dheku
Replied by dheku on topic iRangeX iRX-IR8M builds
Hi.I use i8x-ir8m.
Today, I updated firmware to deviation-ir8m-v5.0.0-2455ad1.
Problem has occurred so it indicated alert as missing modules A7105.
I confirmed hadrware.ini but it was not incorrect that enable A7105.
I want to fix this problem.
The problem was solved after changing firmware to deviation-ir8m-v5.0.0-b08efa8.
Is this bug?
Is this bug?
Time to create page: 0.132 seconds
Builds
- iRangeX iRX-IR8M builds no more?!
