iRangeX iRX-IR8M builds no more?!
18 Apr 2019 04:27 #73982 by teo-costin
Replied by teo-costin on topic iRangeX iRX-IR8M builds
Thanks MCHAVES but I have tried that one and I get an error message when I power on the radio that says "Missing modules: A7105 ..."
I have tried what it says in this post (If you update the firmware and get error on startup: "Missing modules: A7105 ..." or something similar => Most likely it is filesystem problem. Try to format transmitter USB drive, copy filesystem and use "Safely Remove Hardware".) but the same error
Any recommendation?
18 Apr 2019 10:15 #73988 by mchaves
Replied by mchaves on topic iRangeX iRX-IR8M builds
Hi, see this video.
18 Apr 2019 10:42 #73989 by Pongetti
Replied by Pongetti on topic iRangeX iRX-IR8M builds
Don't change stock firmware.
For V2 is the best.
18 Apr 2019 12:36 #73990 by teo-costin
How do I know if I have V2 or V1?
What is the label (name on the screen at power-on) for original firmware on V2?
18 Apr 2019 13:15 #73991 by Pongetti
My IRANGEX is called I8X-IR8M. I think is V2. I don't know if it is another version.
Only firmware deviation-ir8m-v5.0.0-b08efa8 work.
For me, however, he didn't work well even if he didn't make mistakes (missing modules A7105).
I reassembled the original firmware (deviation-t8sg-v5.x.x-2017-09-19) I had made a backup. I don't know where you can download it.
I hope the firmware update problem will be solved. I doubt.
If you can, return it to the seller.
18 Apr 2019 14:53 #73994 by teo-costin
@Pongetti ..... I backup my original firmware also and installed the deviation-ir8m-v5.0.0-b08efa8
So you are saying that the original firmware works the best?
Any problem with FRSKY receivers?
18 Apr 2019 15:32 #73995 by Pongetti
In the end I bought also a taranis Q x7 .
i8X-IR8M with the original firmware no problem, with firmware deviation-ir8m-v5.0.0-b08efa8 I had to reverse roll and yo.
I'm not an expert there are many videos on Youtube.
I'm beginner.
18 Apr 2019 15:49 #73996 by zinets
Replied by zinets on topic iRangeX iRX-IR8M builds
Hi guys again
Can anybody upload original fw for 1.1 version? I still get error about missing module, I hope original fw can fix this issue (but I don't believe..)
19 Apr 2019 16:43 - 19 Apr 2019 21:40 #74011 by teo-costin
File Attachment:
File Name: Original.zip
File Size:629 KB
This is my original firmware that comes with my radio.
Last edit: 19 Apr 2019 21:40 by teo-costin.
20 Apr 2019 09:48 - 25 Apr 2019 20:12 #74026 by zinets
Thanks a lot, I'll try it tonight
upd: no succ :(
Last edit: 25 Apr 2019 20:12 by zinets.
03 May 2019 15:02 #74210 by k1dodson
Replied by k1dodson on topic iRangeX iRX-IR8M builds
Hey there vlad, sorry to b other ya, but i was looking to update my irx ir8m, mi8m, btw mine are one of the first patch jus fyi, anyways, shortly after i got mine, i found that it was stuck in dfu mode, ive even disconnected the internal batt, but it still didnt go back to factory setting. so i figured id attempt to update the firmare and then go from there. so i have been looking for the firmare u posted , so that i can download it, i cannot seem to loacate the firmware, so please let me know where to find the firmware, thankx fyi i did attempt to return but it actually was lost for approx 4 months and then just showd up outta the blue one day6... anyways take care, and i hope you7 help
26 May 2019 06:59 - 26 May 2019 07:03 #74387 by vegivamp
Replied by vegivamp on topic iRangeX iRX-IR8M builds
why was the firmware file deleted ? is it because the original firmware is the best one so far . if not where can i download the firmware that works the best for ir8m irangex
Last edit: 26 May 2019 07:03 by vegivamp.
09 Jul 2019 12:20 #74721 by 40pints
Replied by 40pints on topic iRangeX iRX-IR8M builds
does anyone have the original V2 firmware that came with the controller. The one that was labelled IRX rather than the one that was labelled T8SG??
08 Jan 2020 21:40 #75682 by GabrielRB
Replied by GabrielRB on topic iRangeX iRX-IR8M builds
vlad_vy wrote: I suspect iRangeX has some specific code change for 4IN1_FLASH, with "4in1" RF module output power lines (PE1 and PE2) management. We have not any contacts with iRangeX, so I don't know how to fix it.
Hi Vlad do you think is possible to fix the power issue on 4IN1 module?
I saw the latest builds of Deviation and now it supports telemetry on PXX protocol. something useful in my case.
I cannot upgrade the firmware now because it has some bugs
1) missing modules A7105 message
2) low power on internal module
Do you think there is a chance to fix it?
Regards
08 May 2020 12:43 #76275 by chrismon0
Replied by chrismon0 on topic iRangeX iRX-IR8M builds
So I've been trying for a full day now but can't seem to make it work. I'm using the FrskyX mode, this one works with my 2,5" but not with my Frsky X4R-SB
I'm using the following settings
FrsykX
Failsafe: Hold
AD2Gain: 100
Freq-Fine: -41
Format: EU
RSSICHan: None
S.Port Out: Enabled
Txpower: 150w
Fixedid: 123456
Channels: 16
MixerGUI: Advanced
25 May 2020 13:21 - 25 May 2020 13:23 #76366 by grabejud2020
Replied by grabejud2020 on topic iRangeX iRX-IR8M builds
Hi, as this transmitter seems to be discontinued in the new builds, i'm bringing in back here my issue. Mine is V2 and it was stuck in USB boot loop. so i flash with deviation-ir8m-v5.0.0-b08efa8 and now i encounter this.
irange issue
can any body point me to which firmware that could fix this? or am i out of luck and the rc is good as parts. thanks in advance
Last edit: 25 May 2020 13:23 by grabejud2020. Reason: edited video link
20 Dec 2020 13:21 #77128 by pure
Replied by pure on topic iRangeX iRX-IR8M builds
bonjour ,ou je peux trouver le build de la iRangeX iRX-IR8M avec un bonne version svp ?
13 Apr 2021 16:59 #77341 by BIllyU
Replied by BIllyU on topic iRangeX iRX-IR8M builds
Hello everybody. I know that this TX is discontinued and support is probably hard to get, however: can anybody help me to add Potensic A20 protocol support? This is possible in standard 4-in-one modules, should be doable here too.
Thanks.
15 Apr 2021 08:05 #77345 by mchaves
No more....I think,,,,
Time to create page: 0.209 seconds
