iRangeX iRX-IR8M builds no more?!
21 Mar 2018 14:59 #68243 by Stefan_UK
Replied by Stefan_UK on topic iRangeX iRX-IR8M builds
Hi vlad_vy,
I took my time over this didn't rush anything below are the results of the testing:
deviation-ir8m-v5.x.x-2018-03-21_delay_100 failed CRF6936
deviation-ir8m-v5.x.x-2018-03-21_delay_200 failed CRF6936
deviation-ir8m-v5.x.x-2018-03-21_delay_400 failed CRF6936
If you have any other angles or ideas you would like to try I would be more than happy to assist.
Regards, Stefan
21 Mar 2018 15:15 #68244 by vlad_vy
Replied by vlad_vy on topic iRangeX iRX-IR8M builds
Thank you. I havn't ideas. Now I sure IR8M use 4IN1_FLASH for managing 4in1 module.
21 Mar 2018 16:06 #68245 by Stefan_UK
Hi vlad_vy,
I'm generally available most days so if I can help resolve any other issues I'm always glad to help out.
Regards, Stefan
21 Mar 2018 20:19 #68248 by škrat14
Replied by škrat14 on topic iRangeX iRX-IR8M builds
Hi Biwoj,It happened to me transmitter locked in usb mode I tried everything replaced the ent switch.No better I wrote to banggood service and now I am waiting to mercy
22 Mar 2018 00:25 #68254 by Stefan_UK
HI škrat14, was your TX working without the USB problem straight out of the box. If so can you remember what you did prior to the USB problem occurring?
Regards Stefan
22 Mar 2018 18:26 #68289 by škrat14
Hi Stefan my tx from the box worked a prfect for two days and then locked. Before locking I was editing channel settings for qudrocopter iachine e011 then switched off tx and went to lunch when I returned turned on tx was locked in usb mode. I tried everything from updates nothing happened replaced ent.button still locked.
I'll take photos of the base plate and upload photos to see if there's anything wrong with contacts
Regards Bojan
22 Mar 2018 20:02 #68290 by maxx
Replied by maxx on topic iRangeX iRX-IR8M builds
Petite question la mis à jours et validé
22 Mar 2018 20:26 #68293 by Stefan_UK
Please advise as to what version build prior to the malfunction that you were running? i.e. or was it using the original build from straight out of the box?
22 Mar 2018 20:40 #68294 by škrat14
She was original build from straight out of the box
22 Mar 2018 20:46 #68295 by škrat14
dfu mode works normally in usb mode the computer detects usb but i can not open file.
22 Mar 2018 20:49 #68296 by Stefan_UK
This is a long shot but I'm going to try and contact the manufacturer directly to see if there is a way to perhaps force this TX into "DFU mode" or reset this TX completely. I think this is likely to be a long drawn out process so no promises, but I will try hard to get some answers.
23 Mar 2018 00:01 - 23 Mar 2018 00:17 #68299 by aMax
Replied by aMax on topic iRangeX iRX-IR8M builds
Wrong usb file driver and/or no valid MSDos flag at the file space....
I had the same issue some weeks ago on my 7e.
He should try to access the file area with a Linux live system (CD/DVD/USB stick), just for a test.
There is nothing to reset.
Last edit: 23 Mar 2018 00:17 by aMax. Reason: typo
23 Mar 2018 01:09 #68300 by Stefan_UK
Hi aMax, In both reported cases here where the TX is loading in USB mode there would be access to the storage area as a drive. This drive can be formatted as many times as you like with no effect so I guess you must be referring to the file area where this TX boots from? If you can please detail how you fixed this problem so as to help speed up a fix for these guys. Regards, Stefan
23 Mar 2018 02:56 - 23 Mar 2018 03:04 #68301 by aMax
There are more than two cases where this is reported, e.g. iR8M , Jumper and Devo7e, too much for my liking.
Not so easy to explain, you switch the transmitter off and the boot time its shows only the USB sign....my own
experience. ( firmware version was 2018-24-01)
The PC found the Devo in file mode but did not show anything and formating the drive ended up with an error
Under Linux the drive was found, but no access.....
Gparted showed two 1MB section for the 2MB file space, and only the last one could be accessed.
... so no avail.
With the Walkera defusetool I uprade a 1.87MB backupfile which I had saved on 2014 and the Walkera Devention firmware worked and all model files were ok.
This led my to the conclusion that the serial flash was ok. I tested this several times with no errors.
In the end I managed to rebuild & format the drive with Linux (mkdosfs) and thereafter it was accepted on Windows again.
In addition I reinstalled the genuine Windows USB driver.
Deviation was back.
Last edit: 23 Mar 2018 03:04 by aMax.
23 Mar 2018 19:03 #68313 by škrat14
Hi pictures of my base
24 Mar 2018 09:30 - 24 Mar 2018 09:33 #68322 by Stefan_UK
Hi aMax, Firstly thank you for all the information the Time and the effort which is very much appreciated. This looks likely to help those that have this problem. Regards, Stefan
Last edit: 24 Mar 2018 09:33 by Stefan_UK.
24 Mar 2018 10:01 - 24 Mar 2018 10:07 #68323 by Stefan_UK
Hi skrat14, Thanks for the board image, please take a read through what aMax has explained in a previous post as this problem has occurred across a number of TX brands. You can think of the Devo7e very much the same as the iR8M and his fix could work with your TX. I'm unavailable for a couple of days working on technical issues prior to a video shoot for a new documentary. I am also waiting for feedback through Banggood from the TX manufacturer. Regards, Stefan
I may have an easy method that might negate the need for Linux (mkdosfs) to achieve the same fix. I can't say for definite until I check it out under windows. However, the film crew I'm working with are heading out to the US on Monday so my weekend is a busy one.
Last edit: 24 Mar 2018 10:07 by Stefan_UK.
25 Mar 2018 05:10 - 08 May 2018 06:09 #68341 by vlad_vy
Since iRangeX iRX-IR8M (t8sg-v5.x.x-2017-09-19) is somewhat different from Jumper T8SG I will place here the builds for iRangeX iRX-IR8M.
Previous changes:
* RUD and AIL reversed to comply with common direction for Deviation.
* AUX4 and AUX5 reversed to comply with common direction for Deviation.
* All switches reversed to comply with common direction for Deviation.
* batt_critical set to 3900 since iRX-IR8M can use 4xAA battery.
* LCD Internal Resistor Rate (Rb/Ra) set to 4 (0x24).
* Add support for 6 independent trims set.
* Add protocol for Corona V1/V2 and Flydream V3, from hexfet
* Support 16 channels for FrskyX and 14 for AFHDS-2A, from hexfet
Changes:
* Fix Corona protocol, from hexfet
(2018-03-25)
iRangeX iRX-IR8M based on Nightly Builds:
File deleted, see below...
Last edit: 08 May 2018 06:09 by vlad_vy.
03 Apr 2018 04:10 #68468 by vlad_vy
See previous message with IR8M build.
03 Apr 2018 09:10 #68475 by mchaves
Replied by mchaves on topic iRangeX iRX-IR8M builds
tks
Time to create page: 0.394 seconds
