- Model Icons
- BW icons for DEVO 7E, 10, 12E
- Can someone help make these into 7E icons?
- 30secs
20 Apr 2015 02:38 #31393
by 30secs
Can someone help make these into 7E icons? was created by 30secs
I tried using the app on the tutorial but to no avail.. can someone please help? Thanks!
- cfl246tho
26 Apr 2015 20:04 #31662
by cfl246tho
Quads: Syma X5, X11, X12; LishiToys L6052; NiHui U207, CG023; H7/SpaceTrek M9912; BayangToys X7; UDI U839/939; WLtoys V676; Cheerson CX205
Replied by cfl246tho on topic Can someone help make these into 7E icons?
I use GIMP and set color level to 24 bit (full color), but manually make all pixels either white or black only. The device does not display anything else, even tho the color depth is ultimately more than just two colors (16 bit). When I save a 24 bit image as a BMP file, GIMP offer options which can be the RGB565 or ARGB1555 the manual describes. It's gotta be 52x36 also. I pad the image as need to have the 52:36 aspect ratio before I scale it down to 52X36.
I named each image as h8c, tho that might be wrong, so rename as needed. File name is constrained to 8.3 characters (old MS-DOS convention), so you can't make the filename too long.
All available model icons (must be 52x36 pixels). Model icons must be saved as 16-bit BMP files in either RGB565 (non-transparent) or ARGB1555 (transparent) format.
- TomPeer
26 Apr 2015 20:22 #31665
by TomPeer
Replied by TomPeer on topic Can someone help make these into 7E icons?
- 30secs
26 Apr 2015 20:27 #31668
by 30secs
Replied by 30secs on topic Can someone help make these into 7E icons?
Thank you guys!
- TomPeer
26 Apr 2015 20:33 #31671
by TomPeer
sorry, i didn't see that cfl246tho posted the right images allready.
- cfl246tho
26 Apr 2015 22:53 #31681
by cfl246tho
this should be under the "BW icons for DEVO 7E, 10" branch, since two separate branches were setup for that purpose. There are two kinds of icons used on these Devos
- Model Icons
Time to create page: 0.191 seconds
Model Icons
