- Model Icons
- Color icons for DEVO 6, 8, 12
- E-flite UMX Hyper Taxi
- rototophe
30 Sep 2012 01:58 #1884
Replied by PhracturedBlue on topic E-flite UMX Hyper Taxi
Thanks for all your icons. I'd recommend making the background transparent instead, or using a solid color, as these look odd when a different background image is used.
- rototophe
30 Sep 2012 20:27 - 30 Sep 2012 20:29 #1893
by rototophe
Replied by rototophe on topic E-flite UMX Hyper Taxi
Well I first tried to make them transparent so they can be used on any background. The thing is if I use ARGB155 with photoshop the icons will simply not display in Deviation. See attached SP125 transparent icon as example.
I did not want to make the background solid as I wanted the model to "fly" over the GUI. So since transparency did not work I went for "transparency illusion" to achieve my goal.
It will indeed look odd on a custom background (different from stock Deviation background), icon solid background would not improve much in that case.
If the transparency issue is solved I can quickly re-save the icons without the background layer and re-upload them so they could be used on any system background.
Last edit: 30 Sep 2012 20:29 by rototophe.
30 Sep 2012 20:39 #1894
Replied by FDR on topic E-flite UMX Hyper Taxi
Yep, because your alpha (transparency) channel is all black.
It should be black only on the transparent parts, but this way the whole content is transparent...
- rototophe
30 Sep 2012 22:18 #1897
by rototophe
Alright I can do fine with the basic model shape and export as BMP with transparency. Things become more complicated if want to apply a drop shadow effect to the basic shape and export the whole thing with transparency ----> shadow appeard on white background ---> bad bad bad. Any idea?
FDR wrote: Yep, because your alpha (transparency) channel is all black.
01 Oct 2012 04:18 #1898
This file format doesn't support semitransparency, so you have to draw the shadows with sharp contours, or drop them...
- rototophe
01 Oct 2012 18:01 #1918
by rototophe
There you go...
This actually how I came to make the icons the way they are using "fake transparency" ....
- Model Icons
Time to create page: 0.290 seconds
Model Icons
