Devo 12
- Hexperience
28 Jun 2013 15:56 - 28 Jun 2013 15:57 #11516
by Hexperience
Replied by Hexperience on topic Devo 12
Thanks Vlad. I've been using your ini from the other thread.
What we need now is for someone to build that java gui so we can edit templates on our PC's. (I only drink java..)
Last edit: 28 Jun 2013 15:57 by Hexperience.
- RandMental
29 Jun 2013 12:02 - 29 Jun 2013 12:03 #11553
by RandMental
Replied by RandMental on topic Devo 12
I propose we use this config file from Vlad for the standard Devo12 TX ini template
www.deviationtx.com/media/kunena/attachm...o12-6_2013-06-28.ini
It's from this post: www.deviationtx.com/forum/custom-layouts/1934-devo-12#11499
Last edit: 29 Jun 2013 12:03 by RandMental.
- RandMental
29 Jun 2013 21:54 #11595
Replied by PhracturedBlue on topic Devo 12
I will include Vlad's template in the template library, but not as the default. I need to figure out how I want to handle the devo12 specific stuff 1st though.
The default needs to be a 4/6 channel display. If someone wants to put one together, I'll switch the current one over.
I moved Kdean's template to a new thread. please one design per thread to keep the forum searchable.
29 Jun 2013 21:57 #11596
You can edit them on the emulator which is 'on the pc'. I've mentioned the potential for a full-featured gui for the PC, but it isn't even on my radar at the moment.Hexperience wrote: Thanks Vlad. I've been using your ini from the other thread.
30 Jun 2013 07:06 - 30 Jun 2013 07:43 #11623
Replied by vlad_vy on topic Devo 12
I'm not sure that 4/6 channels display will be the best solution. It's much easy to reassign objects or delete unneeded objects, than to add and place additional objects. Possible will be the best to hide(None) unneeded objects at default layout template, it allows to reuse object when it required.
Last edit: 30 Jun 2013 07:43 by vlad_vy.
30 Jun 2013 13:51 #11631
That is fine, but the default still needs to be configured for 4/6 channels. Meaning sources start disabled.vlad_vy wrote: I'm not sure that 4/6 channels display will be the best solution. It's much easy to reassign objects or delete unneeded objects, than to add and place additional objects. Possible will be the best to hide(None) unneeded objects at default layout template, it allows to reuse object when it required.
Time to create page: 0.779 seconds
