7E custom layout's
- Cereal_Killer
09 Sep 2015 19:24 #37600
by Cereal_Killer
7E custom layout's was created by Cereal_Killer
Hey guy's, I've seen some pictures of some really cool looking main screen layouts. I'd never bothered before cause I didnt look at the display when flying but now that I have DSMX telemetry I find myself wanting to get it setup to read it easier in a glance. I was wondering if some of you guy's would post a pic of your setup and the files to copy it.
I would start but I'm just using the stock layout and I dont know how to edit it.
09 Sep 2015 19:48 #37601
Replied by FDR on topic 7E custom layout's
Just make the layout in the devo10 emulator, and copy the layout section into your mode.ini file...
- Cereal_Killer
09 Sep 2015 20:50 - 09 Sep 2015 20:54 #37602
by Cereal_Killer
Replied by Cereal_Killer on topic 7E custom layout's
That sounds easy enough, I've never used the emulator before. I downloaded it and got it running but I dont see how to edit the layout. Is it in the manual? I'll search now but can you point me to how to do this, what are the input's?
edit:
deviationtx.com/manuals/html-devo10/ch_emulator.html
edit:
Last edit: 09 Sep 2015 20:54 by Cereal_Killer.
- Cereal_Killer
09 Sep 2015 21:27 - 09 Sep 2015 21:28 #37603
by Cereal_Killer
Well that was pretty easy to figure out. Still, I've seen some way better ones but atleast this gets me the info I need for now.
I'd still like to see anyone's who has a custom one!
Last edit: 09 Sep 2015 21:28 by Cereal_Killer.
09 Sep 2015 23:00 #37606
Since the emulator doesn't have any space issues, I've created a test build of the 7E emulator that has the layout editor enabled. That way, you can use the model files directly, without having to move parts of the data between it and the 10 emulator.
deviationtx.com/downloads-new/category/2...=1231:emu-devo7e-zip
Replied by mwm on topic 7E custom layout's
FDR wrote: Just make the layout in the devo10 emulator, and copy the layout section into your mode.ini file...
- Epyon
- Cereal_Killer
10 Sep 2015 12:00 #37628
by Cereal_Killer
Thanks for the pic but much more import, is that a real AUG or an MSAR?
- Epyon
10 Sep 2015 16:20 #37633
by Epyon
Airsoft. Old hobby.
Replied by Epyon on topic 7E custom layout's
Cereal_Killer wrote: Thanks for the pic but much more import, is that a real AUG or an MSAR?
Airsoft. Old hobby.
- ursus69
29 May 2016 09:28 #49479
by ursus69
Replied by ursus69 on topic 7E custom layout's
Hi!! and sorry for restart the topic!
Cereal_Killer, can you share your layout?? You added DSMX telemetry? how??
Thanks a lot!
Thanks a lot!
- rjmcewen63
- I know how to fly, I'm learning not to crash...
16 Aug 2016 00:23 #52793
by rjmcewen63
_
/_/ _ _
/ \/_/_\_\
Replied by rjmcewen63 on topic 7E custom layout's
Cool layouts Bro! Thanx!
_
/_/ _ _
/ \/_/_\_\
- 92zb
16 Aug 2016 09:33 #52800
by 92zb
How do you download the file "Messag: You have no rights to access file in this category"
Replied by 92zb on topic 7E custom layout's
16 Aug 2016 10:27 #52804
It was in the test builds (
www.deviationtx.com/downloads-new/category/32-test-builds
), but it seems that MWM has removed it...
May be it is already included in the official build, or at least the nightly builds?
My solution can work anyway...
16 Aug 2016 22:10 #52828
Yes, the layout editor was incorporated into the mainline code a while back, and should be in both the 5.0.0 release and the latest nightly. I deleted the test builds then, since cluttering the downloads up with things you shouldn't be using any more just seems like a bad idea.
Custom Layouts
- 7E custom layout's
