High contrast BW skin
06 Dec 2012 10:19 - 07 Apr 2013 18:40 #3700
High contrast BW skin was created by FDR
Last edit: 07 Apr 2013 18:40 by FDR.
- deewee8
06 Dec 2012 14:50 #3705
by deewee8
Replied by deewee8 on topic High contrast BW skin
I like that one
- Fredyp
10 Dec 2012 03:44 #3837
by Fredyp
Replied by Fredyp on topic High contrast BW skin
Great!! Really Great!!
- -=Hubi-Dirk=-
06 Apr 2013 14:38 #8644
by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic High contrast BW skin
Hi FDR,
today I installed the new Emulator 3.0 and want to use your B&W skin. But the Emu crashed while loading. Could you please have a look on it?
Thanks in advance,
Dirk
Thanks in advance,
Dirk
07 Apr 2013 18:41 #8701
Replied by FDR on topic High contrast BW skin
OK, I've corrected it for the v3.0.0
- -=Hubi-Dirk=-
07 Apr 2013 20:10 #8714
by -=Hubi-Dirk=-
Now it´s working. Thanks a lot
- Gerhard_H
22 Apr 2013 11:31 #9121
by Gerhard_H
Replied by Gerhard_H on topic High contrast BW skin
Have had my Devo8S outside my flat for the first time and had been shocked - nearly unreadable.
So I hopefully swapped to the BW skin. At a first glance - yes, it's better.
But it's far away from a 2801 . . .
Anyway, thanks a lot, You did what You could (under given circumstances).
thx
Gerhard
thx
Gerhard
22 Apr 2013 13:40 - 23 Apr 2013 07:38 #9124
Yep, that's all I could do.
...and I have yet to make the standard UI icons...
Last edit: 23 Apr 2013 07:38 by FDR.
- Gerhard_H
23 Apr 2013 06:03 #9139
by Gerhard_H
. . . and we are all happy You did . . . !!
BTW : Trimmer markers
They change their colour if out of center (blue / red).
Would it be possible to make them triangle shaped (when not centered) pointing with the tip towards center position (instead of the rectangles)?
23 Apr 2013 06:44 - 23 Apr 2013 06:49 #9140
Replied by rbe2012 on topic High contrast BW skin
The idea is good, but the space is very limited. The bars are very tiny (10 pixels wide) and an arrow would have to be drawn over the lines to be recognizable.
Maybe we could have another indicator to show in which direction the trim is moved; e.g. coloring one tip of the trim the one the trim moves to) as long as the trim is near the center and a center line when the trim has moved further:
original - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - small arrows
small arrows and colored tip - - - - - - - - - - - - - - - - - - wider arrows
Looking at this I think the lower right might work. Will this be better recognizable?
EDIT: Pointing to the center? I think in this case the zero position should be drawn as two triangles pointing to each other, but pointing away from the center seems more natural for me.
Last edit: 23 Apr 2013 06:49 by rbe2012.
- Gerhard_H
25 Apr 2013 05:19 #9189
by Gerhard_H
@rbe2012
Hi !
The lower right one is what I meant. But we discuss a b/w skin version, I think there's no need to give the arrows (different) colours, because the tip of the arrows give proper information.
Pointing to the center : Hm, maybe a matter of taste - for me the arrows give me the direction where I have to go to the center. You see it quite opposite.
Anyway - thx for your work !
Hi !
25 Apr 2013 05:48 - 25 Apr 2013 05:49 #9190
It was only made with a paint program - no code change so far.
The colors are the original ones. For the b/w skin the colors defined there are used.
I will look into the code (as I remember the trims and the bars are drawn by the same method so I don't know how much effort it would take to change the simple colored rectangles to triangles) and post the result later...
EDIT: Pointing in the direction they move seems more natural for me.
Last edit: 25 Apr 2013 05:49 by rbe2012.
25 Apr 2013 15:48 #9203
Hi Gerhard,
I have done some programming. Here is the new src/gui/320x240x16/_bargraph.c:If you are able to build your own deviation you can test this, otherwise tell me and I will place the emulator somewhere. If it is good, you could make an enhancement ticket on bitbucket (or I can do this for you).
This project is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
Deviation is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with Deviation. If not, see <http://www.gnu.org/licenses/>.
#define TRANSPARENT_BARGRAPH
#define TRIM_THICKNESS 10
#define TRIM_MARGIN 1
u32 _bargraph_get_color(s32 val, struct guiBarGraph *graph, struct disp_bargraph *disp)
s32 center = (graph->max + graph->min) / 2;
return val > center
? disp->fg_color_pos
: val < center
? disp->fg_color_neg
: disp->fg_color_zero;
void _bargraph_trim_horizontal(int x, int y, int width, int height, s32 val, u32 color,
struct guiBarGraph *graph, struct disp_bargraph *disp, struct guiBox *box)
(void)box;
if (Display.flags & TRIM_TRANSPARENT) {
GUI_DrawBackground(x, y, width, height);
} else {
LCD_FillRect(x, y, width, height, disp->bg_color);
LCD_DrawFastVLine(x + width / 2, y, height, disp->outline_color); //Center
if (val == 0) {
// rectangle
val = (TRIM_THICKNESS / 2) + (width - TRIM_THICKNESS) * (val - graph->min) / (graph->max - graph->min);
s16 xpos = graph->direction == TRIM_HORIZONTAL ? x + val : x + width - val;
LCD_FillRect(xpos - TRIM_THICKNESS / 2,
y + TRIM_MARGIN,
TRIM_THICKNESS, height - TRIM_MARGIN * 2, color);
} else {
// arrow
s16 newval = val * (width - 2* TRIM_THICKNESS) / (graph->max - graph->min);
int i, t;
for (i=0; i<TRIM_THICKNESS; i++) {
t = ((TRIM_THICKNESS - i) * height) / TRIM_THICKNESS;
LCD_DrawFastVLine(x + width/2 - newval + ( val<0 ? i : -i), y + (height - t)/2, t, color);
void _bargraph_trim_vertical(int x, int y, int width, int height, s32 val, u32 color,
(void)box;
} else {
LCD_DrawFastHLine(x, y + height / 2, width, disp->outline_color); //Center
if (val == 0) {
// rectangle
s16 ypos = (TRIM_THICKNESS / 2) + (height - TRIM_THICKNESS) * (val - graph->min) / (graph->max - graph->min);
LCD_FillRect(x + TRIM_MARGIN,
y + (height - ypos) - TRIM_THICKNESS / 2,
width - TRIM_MARGIN * 2, TRIM_THICKNESS, color);
} else {
// arrow
s16 newval = val * (height - 2* TRIM_THICKNESS) / (graph->max - graph->min);
int i, t;
t = ((TRIM_THICKNESS - i) * width) / TRIM_THICKNESS;
LCD_DrawFastHLine(x + (width - t)/2, y + height/2 - newval + ( val<0 ? i : -i), t, color);
}- Gerhard_H
28 Apr 2013 11:06 #9302
by Gerhard_H
Hi !
I have tried out the 8S theses days under sunnny conditions - think about selling the radio . . .
No matter which skin (normal or high contrast) or battery (NiMh or LiPo), in the end I'm not satsfied.
It's simply the principle which isn't appropriate. Imho it's only indoor suitable.
Anyway, thanks a lot for response.
Kind regards
Gerhard
Kind regards
Gerhard
- Gerhard_H
02 May 2013 15:16 #9483
by Gerhard_H
As described
here
I tried out a anti glare foil with satisfying result.
- Hexperience
02 May 2013 15:37 #9484
by Hexperience
Replied by Hexperience on topic High contrast BW skin
The link in your post just brings me back here for some reason...
- ChrisLevo
09 Oct 2013 05:50 #14373
by ChrisLevo
I already have files in there.
Do I just put the new ones there, or do I have to remove the existing ones?
Thanks - Chris
Replied by ChrisLevo on topic High contrast BW skin
FDR wrote: You need to extract it into the media directory.
Thanks - Chris
09 Oct 2013 05:52 #14374
Yep, you need to replace them...
- ChrisLevo
09 Oct 2013 05:58 #14375
by ChrisLevo
Thanks for that - I love your work
- EduardS
09 Oct 2013 19:39 #14392
by EduardS
Replied by EduardS on topic High contrast BW skin
Allthough I like the skin and have installed right now I wonder if a reverse BW skin wouldn't be more effective?
Time to create page: 0.240 seconds
Custom Skins
- High contrast BW skin
