Toggle Icons, a way to add more?
- jvulte
09 Apr 2013 08:35 - 09 Apr 2013 08:36 #8775
by jvulte
Toggle Icons, a way to add more? was created by jvulte
Could I add more toggle Icons into the media folder to choose from?
I was wondering, maybe I could extend the current BMP to twice as long, or maybe double width, for double the icons?
Last edit: 09 Apr 2013 08:36 by jvulte.
09 Apr 2013 08:37 #8776
Replied by FDR on topic Toggle Icons, a way to add more?
You can extend the existing, but only in the same direction.
09 Apr 2013 09:12 - 09 Apr 2013 09:14 #8777
Replied by rbe2012 on topic Toggle Icons, a way to add more?
No, the toggles.bmp can have any format as long as it is a multiple of 32 pixels wide and a multiple of 31 pixels high.
Make sure you do not change the first icon (frame with question mark) and for compatibility I would not change the standard icons.
As an example you can use mine:
EDIT: should be the same for the Devo7e/10.
Last edit: 09 Apr 2013 09:14 by rbe2012.
09 Apr 2013 09:19 #8778
Oops, sorry!
Has it changed recently?
09 Apr 2013 09:31 #8779
Yes, with the introduction of the multiple toggle icons.
09 Apr 2013 09:32 #8780
Forgot to mention (as often...): Devo8 can show only the first 32 icons.
- jvulte
- Franck
21 May 2013 18:07 #10209
by Franck
Only 19 icones for my DEVO 8
Replied by Franck on topic Toggle Icons, a way to add more?
rbe2012 wrote: Forgot to mention (as often...): Devo8 can show only the first 32 icons.
22 May 2013 04:34 #10223
Because there are only 19 in the icon file. If there would be more only the first 32 would be shown.
This was true at the moment I wrote the post you mentioned. I believe PB has added a scroll bar so more icons can be displayed, but I can't test actually.
22 May 2013 05:16 #10226
I looked into: he has. The number of icons is limited to 64 icons in every of the four files (only "media/toggle3.bmp" for free use, the others for deviation standard icons).rbe2012 wrote: I believe PB has added a scroll bar so more icons can be displayed, but I can't test actually.
- lcn
17 Apr 2014 22:03 #22531
by lcn
Replied by lcn on topic Toggle Icons, a way to add more?
What resolution must have BMP file to be compatible with Devo12S ?
I've tried to create my ownn toggle3.BMP but is not displayed properly, is it stripped and looks to be green negative on Devo's screen.
What are the settings to save the BMP file in photoshop ?
I've use all BMP settings from 16 bits to 32 bits, it still the same bad result.
- unclecrash
17 Apr 2014 23:38 - 17 Apr 2014 23:39 #22535
by unclecrash
Replied by unclecrash on topic Toggle Icons, a way to add more?
Last edit: 17 Apr 2014 23:39 by unclecrash.
- jvulte
17 Apr 2014 23:55 #22538
by jvulte
Replied by jvulte on topic Toggle Icons, a way to add more?
I removed them cause they didn't make any sense to me,..
- jvulte
18 Apr 2014 00:40 #22541
by jvulte
these are all showing up black since the latest update
- lcn
18 Apr 2014 05:04 #22547
by lcn
I've tried BMP settings from 16 bits to 32 bits, icons are not displayed properly...
- vincentimes
12 Dec 2014 15:44 #26916
by vincentimes
Vince
Replied by vincentimes on topic Toggle Icons, a way to add more?
Hello.
I would like to create icons for switches.
But I do not know how to or find originals to be able to replace it by new.
Thank you for your help(assistant).
Vince
- Morlacus
12 Feb 2016 14:44 - 12 Feb 2016 14:55 #43041
by Morlacus
Replied by Morlacus on topic Toggle Icons, a way to add more?
Hello
I have a devo 8s with deviation 4.01
I am wanted to have a more meaningful icon for my Fmode position so i wanted to write "Normal", "Accro 1" and "Accro 2"( accro is equivalent of stunt in french) for F0 F1 F2. For this i have created double icons just by puting 2 simple icons side by side. This is very easy.
It would be possible to have triple icons also....
I have also drawn 2 icons for landing gear. 2 other for stop go and 2 for mid throttle and full throttle
I enclose my toggle3 file and a snapshot of the screen showing Normal
Morlacus
Morlacus
Last edit: 12 Feb 2016 14:55 by Morlacus.
Time to create page: 0.518 seconds
Custom Skins
- Toggle Icons, a way to add more?
