Please help to edit menu screen (photo inside)
02 Aug 2014 13:44 - 03 Aug 2014 05:04 #24969 by saitek
Have anyone know the folder path to edit this screen. i want to move model word (red circle in picture) from center to left side.
Last edit: 03 Aug 2014 05:04 by saitek.
02 Aug 2014 15:06 #24972 by D_an_W
Attach the ini file you are using (Model1.ini maybe?) and I will see if I can help, I am still learning Deviation but I think I can do that if it's the same as the 7E
02 Aug 2014 16:19 #24976 by sbstnp
I think you want media/config.ini
Find the entry for [font-modelname] and change:
box_type=left
The change will be system wide.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
02 Aug 2014 17:55 #24979 by saitek
This is a problem when more text.
I want to move to a position according to the picture.
02 Aug 2014 18:27 #24980 by FDR
sbstnp wrote: I think you want media/config.ini
box_type=left
This won't move the box to the far left, just arrange the model name to the left in it's box...
@saitek:
Why do you need that many "q" in your model name? ;)
Rather clear that devention DEVO 12 text from the background image, and you will have plenty of place for the model name...
02 Aug 2014 18:37 #24982 by sbstnp
@fdr yes, aware of that. incomplete instructions :) he needs to redo the layout as well.
@saitek use shorter names.
Devo 10 + 4in1
Spektrum Dx9
02 Aug 2014 20:00 #24984 by saitek
It's just a sample. Normally it is not named this long. Just think it is pretty good for me.
Time to create page: 0.114 seconds
