Telemetry Page on Devo 10 with FrSky G-RX8
- pulpfiction15
01 Jun 2018 07:34 #69495
by pulpfiction15
Replied by pulpfiction15 on topic Telemetry Page on Devo 10 with FrSky G-RX8
@moeder,
In the 'telemetry configuration' screen, it is possible to set alarms to '1s@xxx', '2s@xxx', '3s@xxx', ...
I suppose it is to get the telemetry alarms every 1s, 2s, 3s ...
But in that case, I have no alarms at all.
Sorry to extend your 'to-do' list.
- Gerry
- Bbrad
01 Jun 2018 08:15 - 01 Jun 2018 08:30 #69496
by Gerry
FFS (Forever Fixing Stuff)
Replied by Gerry on topic Telemetry Page on Devo 10 with FrSky G-RX8
1s 2s etc are delay conditional time before alarm is sounded, eg. battery LV will not sound until it has been low for more than 1s, 2s,etc. if value to trigger alarm goes back to non-alarm state before x seconds alarm will be cancelled.
Last edit: 01 Jun 2018 08:30 by Gerry. Reason: clarification
- pulpfiction15
01 Jun 2018 09:11 #69497
by pulpfiction15
Thanks, Gery for the explanation.
Is there no way to get a more frequent telemetry alarm? Or continuous vario alarms possible ?
- Moeder
01 Jun 2018 10:36 #69499
by Moeder
Replied by Moeder on topic Telemetry Page on Devo 10 with FrSky G-RX8
Check your setting for telemetry alert interval in transmitter config menu.
- pulpfiction15
02 Jun 2018 10:49 #69519
by pulpfiction15
Thank, well understood the difference now, would be nice to have both options (duration of the alarm and repetition time) for each telemetry alarm .
- Moeder
03 Jun 2018 09:57 #69527
by Moeder
What do you mean by that? Alarm duration should only be dependent on the length of the voice file or the buzzer music in sound.ini
- pulpfiction15
03 Jun 2018 10:06 #69528
by pulpfiction15
No, what I mean is, in this case with G-RX8, that it would be possible to get telemetry of the variometer every second (buzzer) and for the altitude every 30 seconds and RSSI if lower than x during 5 sec.
- Moeder
03 Jun 2018 10:55 #69529
by Moeder
OK, you mean an alert specific interval time. Would be easy to do, unfortunately it requires some work on the monochrome screen transmitters to make the new options fit the tight screen. Telemetry settings page is already full, for fitting the conditional time(xs@yyy) I already opted for a solution which is not quite in line with the general interface usage of deviation.
- Morlacus
04 Jun 2018 16:13 #69532
by Morlacus
Replied by Morlacus on topic Telemetry Page on Devo 10 with FrSky G-RX8
Hello
I am very interested in this topic. I have received my Frsky G-RX8 and am waiting for my 4in1 Banggood module.
Moeder, is there a version for the devo 12s of the build you posted page 1 ?
About Vario sound, I am dreaming of a "true" vario sound, with a frequency and tone of the sound varying in function of the vertical speed...active or not with a switch...
I am not used to the Mymedia use. I suppose that if I use it for voice.ini I must make a lib.dfu without it. If no, what would be taken in count ?
Regards
Morlacus
Regards
Morlacus
- Moeder
05 Jun 2018 14:57 #69557
by Moeder
Hi Morlacus,
please find attached the devo12s with the fix for device=xxx settings in sound.ini. If you also feel it works fine I will go ahead and submit a pull request for nightlies. It'll be probably a few more weeks before the new voice menu is ready for testing.
Moeder
Moeder
- Morlacus
05 Jun 2018 15:46 #69558
by Morlacus
Thanks a lot Moeder.
I just received my 4in1 module today and installed it.I have linked it for te c2500 and my G-RX8 is binded.
I will test now your build.
I want also to test the mymedia file which seems very simple. Is it necessary to take my sound, voice, toggle out of the lib when I put them in the mymedia file ?
Regards
Morlacus
Regards
Morlacus
- Moeder
05 Jun 2018 16:21 #69559
by Moeder
No, you don't need to. mymedia contents will override the library files.
- Morlacus
06 Jun 2018 16:11 #69569
by Morlacus
I have installed the new build.
The "device=buzzer" works.
I put an alarm for the vario for which the alarm is constant (> -1) when the rx is on a table. The box blinks red rapidly on the telemetry screen, but I have only got a sound every 15 seconds.
That is far too slow.
If I had got a sound every second I would try to have 5 sounds for 1 second in the sound.ini. But 15 seconds is too much
Regards.
Morlacus
Regards.
Morlacus
- Moeder
06 Jun 2018 17:06 #69570
by Moeder
Same advice for you: check the telemetry alert interval in transmitter config menu.
- Morlacus
06 Jun 2018 17:55 #69572
by Morlacus
Thanks for the advice. It works !
I should have read all the post with more attention...
That makes an operable vario sound.
And for other alarms use the xs@xxx feature.
The next step would be more individualisation of the alerts intervals and if possible at the model level
and a true vario sound....
Good job anyway !
Regards
Morlacus
Good job anyway !
Regards
Morlacus
- Morlacus
12 Jun 2018 11:46 #69619
by Morlacus
Another question about using Frsky G-RX8 receiver with the Frsky x protocol on my devo 12s
All seems good but I cannot reset the telemetry altitude. Each time I bind the rx the altitude is 15 m or so.
Is it a way to reset this value to zero ?
Thanks for help.
Morlacus
Thanks for help.
Morlacus
- Morlacus
25 Aug 2018 10:00 #70446
by Morlacus
Hello
Has this modification been included in the nightlies build ?
Regards
Moeder wrote: Hi Morlacus,
Moeder
Hello
Regards
- Morlacus
13 Sep 2018 15:18 #70883
by Morlacus
Hello
I have noticed that when the device=buzzer is used, once the buzzer works some voice messages are cut. For chrono messages, the chrono message is there but the time is not announced.
I have noticed that with the Telemetry one message on buzzer.
All simple message work as usual.
Regards
Morlacus
Regards
Morlacus
Time to create page: 0.511 seconds
Custom Skins
- Telemetry Page on Devo 10 with FrSky G-RX8
