How to upgrade Devo TX to Deviation Firmware
29 Nov 2012 21:00 - 06 Jan 2014 01:22 #3436
How to upgrade Devo TX to Deviation Firmware was created by FDR
Videos made by: Tom Z
How to upgrade Devo Tx Firmware to Deviation Firmware V4
Older versions:
How to upgrade Devo Tx Firmware to Deviation Firmware V2.1 and V3
Older versions:
Last edit: 06 Jan 2014 01:22 by PhracturedBlue.
- CamDLux
29 Nov 2012 22:27 #3438
by CamDLux
Replied by CamDLux on topic How to upgrade Devo TX to Deviation Firmware
I just received a brand new Devo 8S. I followed the users manual and viewed this video. SUPER EASY AND SUCCESSFUL 2.0 UPGRADE COMPLETE! Thanks!
- RugWarrior
30 Nov 2012 06:19 #3444
by RugWarrior
Replied by RugWarrior on topic How to upgrade Devo TX to Deviation Firmware
Thank you for the great video!
- Tom Z
01 Dec 2012 00:13 - 02 Dec 2012 17:45 #3476
by Tom Z
Replied by Tom Z on topic How to upgrade Devo TX to Deviation Firmware
Your welcome.
I am working on some more "How to" videos.
Last edit: 02 Dec 2012 17:45 by Tom Z.
- dajogejr
04 Dec 2012 00:41 #3596
by dajogejr
Replied by dajogejr on topic How to upgrade Devo TX to Deviation Firmware
TomZ, thanks a bunch for easy to follow video.
Any chance of a How to revert back to factory, just in case.
Having issues with my setup, I'd like to rule deviation firmware out.
TIA
TIA
- Tom Z
04 Dec 2012 02:29 - 25 Apr 2013 22:01 #3597
by Tom Z
Your welcome.
To revert back to the factory firmware you can use my video
on "How to Update the firmware on Devo Transmitters".
Just approach this as you don't have the deviation firmware in your TX
and you want to update the factory firmware.
Once you go through the steps in the video you will have the factory firmware
back again and all your models will be there.
Tom
How to Update Firmware for Devo TX w/USB Port - For the Devo 6/8/10
Tom
Last edit: 25 Apr 2013 22:01 by Tom Z.
- dajogejr
04 Dec 2012 03:03 #3599
by dajogejr
Tom,
Simple mistake on my part with the Library.
I was using Upload option, instead of update and verify option.
Your vid may have saved hair count, I knew I wasn't too far off.
Thanks again!!!
Thanks again!!!
- Scott45044
26 Feb 2013 12:58 #7078
by Scott45044
Replied by Scott45044 on topic How to upgrade Devo TX to Deviation Firmware
Thank you for the video. My new Devo 8S was waiting for me when I got home from work. I watched the video and updated to the 2.1 firmware with no problems. It was a piece of cake!! Played with the settings and bound to a new Devo802 receiver. This video made it super easy!! Thanks
- hillsmaverick
01 Mar 2013 23:19 - 01 Mar 2013 23:33 #7208
by hillsmaverick
Replied by hillsmaverick on topic How to upgrade Devo TX to Deviation Firmware
I'm having a problem updating my DEVO 10. First I have registered with Wakera but can't log on (I know not your problem). I can access the site and download DEVO-10 Fw v0.6A.dfu and the lib file, but apparently they are useless without the dfue? file. so I'm stuck there. Any suggestions?
Last edit: 01 Mar 2013 23:33 by hillsmaverick. Reason: typo
- Mullson
02 Mar 2013 00:08 #7209
by Mullson
Replied by Mullson on topic How to upgrade Devo TX to Deviation Firmware
This is against my nature but dowload "DfuSe"its a "exe" program, get it from devention Upgrade Tools. Install and read the how to their or her and you will hopefully succeede.
But you should really try Deviation instead. If you ever want or will be a master of the skies this is something that you have to learn. And if not it will get your brain to bloom.
- Tom Z
02 Mar 2013 01:17 - 02 Mar 2013 01:36 #7210
by Tom Z
Scott45044, your welcome. I'm glad the video helped you out.
hillsmaverick,sent you a PM.
Last edit: 02 Mar 2013 01:36 by Tom Z.
- hillsmaverick
02 Mar 2013 01:47 #7211
by hillsmaverick
I'm sorry but I'm a little new at this forum stuff, except reading, and gleaning info. I don't know how to retrieve a or send a PM.
02 Mar 2013 06:39 #7214
Replied by rbe2012 on topic How to upgrade Devo TX to Deviation Firmware
- Lasercopter
02 Mar 2013 15:49 #7218
by Lasercopter
Replied by Lasercopter on topic How to upgrade Devo TX to Deviation Firmware
does anybody know how to put a Devo 12s in DFU mode, mine wont do it pressing the EXT button.
02 Mar 2013 21:42 #7229
Hold the trainer switch up.
- Tom Z
03 Mar 2013 03:30 - 03 Mar 2013 03:31 #7256
by Tom Z
Thanks rbe2012. hillsmaverick was able to get my PM. I didn't want to post a big reply with links here so I sent a PM instead.
Last edit: 03 Mar 2013 03:31 by Tom Z.
- EVERNIN
05 Mar 2013 07:16 #7374
by EVERNIN
Replied by EVERNIN on topic How to upgrade Devo TX to Deviation Firmware
Hi, I am trying to upgrade my devo 8s to Deviation firmware, with no success, when while pressing EXT and power on tx, it appears program update on tx display, ok, but the dfuse tool on the pc does not recognize the tx. can you help?? Thank you. by the way please forgive my poor english, I am Mexican.
05 Mar 2013 07:25 - 05 Mar 2013 07:28 #7375
Replied by vlad_vy on topic How to upgrade Devo TX to Deviation Firmware
If you use Windows 7 (x64), possible DeFuse v1.4 can help. Or you may have USB conflict, at that case you need disconnect all other USB devices, one by one.
www.deviationtx.com/forum/6-general-disc...er-1-5-with-win7-x64
Last edit: 05 Mar 2013 07:28 by vlad_vy.
- EVERNIN
05 Mar 2013 07:39 #7376
by EVERNIN
where can i download Defuse v1.4?? Thank you.
- EVERNIN
05 Mar 2013 07:45 #7377
by EVERNIN
it is ok I followed the link, thank you. I will try v1.4
Time to create page: 0.216 seconds
