Add two switches to the Devo 7e
21 Aug 2013 09:14 #13071 by vlad_vy
Replied by vlad_vy on topic Add two switches to the Devo 7e
To get 8 channels from satellite, you need bind satellite with 8+ ch Rx.
  • rbe2012
  • rbe2012's Avatar
21 Aug 2013 09:32 #13074 by rbe2012
Replied by rbe2012 on topic Add two switches to the Devo 7e
Deviation enables 12 channels for every supported tx - no need to add any switches.
Devo7e has a reduced number of control elements to set values to all 12 channels, but with the trim buttons you should be good.
Check the channel test page to see if channel8 changes its output when you push the trims...
  • rbe2012
  • rbe2012's Avatar
21 Aug 2013 09:35 #13075 by rbe2012
Forgot to mention: you have to set the number of channels for the model (on the model config page where the bind button is located).
21 Aug 2013 09:40 - 21 Aug 2013 09:42 #13076 by sllewji
Replied by sllewji on topic Add two switches to the Devo 7e
Thanks Vlad,
I don't have a full sized DSM2 Rx, so have been using a small Arduino sketch that was posted on the RCGroups Pocket Quad forums to put the satellite into bind mode (see attached file).
I don't suppose you could make any suggestion on how I could change this sketch to increase the number of channels?
I'll ask in the Pocket Quad forums too.
Ian
File Attachment:
File Name: Pocket_Qua....ino.zip
File Size:1 KB
Last edit: 21 Aug 2013 09:42 by sllewji.
21 Aug 2013 09:42 #13079 by cmpang
Replied by cmpang on topic Add two switches to the Devo 7e
rbe2012 wrote: Deviation enables 12 channels for every supported tx - no need to add any switches.
It is true that Deviation 7e is 12 channels capable. However, with only two switches as input, they cannot be implemented in full. Using control stick trim as input switches makes the stick itself useless as trimming is one of the major function of any stick.
The logic is, 7e without doing the diode mod is really useless and dangereous. Then, if someone can do the diode mod, why not also do the switch mod as it is really more simple and easy to do than the didoe mod.
cmPang
21 Aug 2013 09:52 - 21 Aug 2013 10:58 #13080 by sllewji
Hi rbe \ cmPang,
Thanks for the input, and the confirmation.
I've updated the model for 8 channels, and the channel monitor and emulator do show CH8 switching when using the trim - I've just not yet been able to see this when using my actual Tx / Rx combination.
I'm hopeful that the Bind_Code Arduino sketch I mentioned above can be modified so that my DSM2 Satellite will recognise the additional channels - I really don't fancy having to buy a main DSM2 RX with 12 channels!
As I said, I don't currently have any use for the Throttle trim - so this is an ideal way of adding two extra switches for "Free".
Once I actually see that I can control the extra channels, I'll be more than happy to go ahead with the diode removal and switch mods (or more likely get someone who knows what they are doing to do it for me :) )
Actually, I don't understand why more people are not clamouring for the switch mod to be fully supported in the Deviation release code - the Devo 7e, with Deviation powering it, is awesome!
Perhaps, as PB mentioned in another post, it will be more likely to happen when / if virtual switches are implemented.
Ian
Last edit: 21 Aug 2013 10:58 by sllewji.
21 Aug 2013 11:58 - 21 Aug 2013 12:00 #13093 by vlad_vy
You havn't need to modify Bind_Code Arduino sketch, set in Tx number of channel 8+ and bind with sketch. Deviation support for DSM2 protocol 1024/22ms only.
Last edit: 21 Aug 2013 12:00 by vlad_vy.
21 Aug 2013 12:46 #13100 by sllewji
Doh! - why didn't I think of that!
It worked perfectly - thanks vlad!
02 Jan 2014 18:03 #17758 by pfriedel
Replied by pfriedel on topic Add two switches to the Devo 7e
I ask because the pic isn't the clearest - I see what the yellow and orange wires are connected to (ENT and EXT buttons), but what's red connected to? VCC generally, or specifically the topmost (from this perspective) pin of the ELEV-V header?
02 Jan 2014 18:26 #17760 by kreidler
Replied by kreidler on topic Add two switches to the Devo 7e
I do have some pics for a three position showing the red one a bit more clear.
02 Jan 2014 18:56 #17763 by pfriedel
Ah, that makes it very clear, thanks! Aside from discovering that my Radio Shack SPDT (275-0613) switches didn't have quite a long enough shaft to clear the front panel without cutting out some of the internal molding structures, but what the hell, I was committed.
05 Feb 2014 17:43 #19882 by cassini75
Replied by cassini75 on topic Add two switches to the Devo 7e
ok i have installed the switches, but with all the different info, do i need to patch 4.0.1 or do i just modify a file? im on windows 7 or osx
thanks
05 Feb 2014 17:49 #19884 by PhracturedBlue
Replied by PhracturedBlue on topic Add two switches to the Devo 7e
The easiest solution is to either use the nightly builds or Harry's build and modify the hardware.ini file. Alternatievly, harry has a pre-patched 4.0.1 build (which does not need the ini file change, but you need the right build for your specific setup, and the model setup is different due to the switches having different names)
There haven't been any complaints with the nightlies, so I'd probably recommend that route.
11 Feb 2014 23:05 - 11 Feb 2014 23:19 #20149 by pesadilla
Replied by pesadilla on topic Add two switches to the Devo 7e
Hi all,
I'm new to all this and could use a little help.
Yesterday I added a A7105 module and did this 2 switches mod.
The added A7105 module is working great but I don't seem to get the extra 2 switches working.
Checked and doubled-checked all soldering and connection points, changed the hardware.ini and did a calibration.
But the extra switches don't appear as switches in the mixer page)
Forgot to mention that I did everything as discribed above (with 2 diodes).
What am I doing wrong?
Thanks for any suggestion and keep up the great work!
Greetings,
Pesadilla
Last edit: 11 Feb 2014 23:19 by pesadilla.
  • rbe2012
  • rbe2012's Avatar
12 Feb 2014 06:56 #20166 by rbe2012
You have to use a very new version of deviation (newer than 4.0.1, use the nightlies) where this is supported. This version will bring a new config file "hardware.ini" where the type of switches you added must be enabled.
12 Feb 2014 09:27 - 12 Feb 2014 09:28 #20174 by pesadilla
Thanks for the quick reply.
I'm using a new version that has a hardware.ini config file.
In that file I removed the ';' and added 2X2 at the extra-switches line.
But I can't find the switches in the mixer setup.
I suppose that the extra switches (ail-dr, ele-dr) should be there even if there was a problem with my soldering.
What am I forgetting or doing wrong?
You can find my hardware.ini in attachment.
Thank you for your help!!
Last edit: 12 Feb 2014 09:28 by pesadilla.
  • rbe2012
  • rbe2012's Avatar
12 Feb 2014 09:45 - 12 Feb 2014 09:46 #20176 by rbe2012
Short question: you have powered down and up your tx after modifying the hardware.ini? It is only read at system start.
You should have two new sources to select (SWA and SWB). Have you taken a look at the input monitor page? You might have to scroll down but somewhere SWA0, SWA1, SWB0 and SWB1 should occur (this will be independent from the hardware mod; controlled just by the hardware.ini).
Last edit: 12 Feb 2014 09:46 by rbe2012.
12 Feb 2014 10:13 #20179 by pesadilla
Powered up and down, reinstalled several times.
Just tried the latest build also...
I can't find those new switches (SWA & SWB).
I have no problem finding HOLD01, HOLD02,FMODE0,FMODE1,....
Also no SWA or SWB on the monitor page (scrolling down only shows the HOLD and FMODE switches.
12 Feb 2014 10:22 #20181 by pesadilla
Another strange thing is that I'm getting an error when using the protocol map from tha lastest buil: bad or missing protocols.
I don' have this error when using the protocol folder from an older version
So I'm using the latest build but with an older protocols folder, don't know if this could have something to do with my switch problem.
12 Feb 2014 11:25 #20182 by pesadilla
ok, I have it working!!
Didn't install a new DFU on TX, only copied the folders from the new build.
I knew I was doing something wrong... lol
Switches are working now and no more error "missing/bad protocols".
Thanks for the help and keep up the good work!!
Pesadilla
Time to create page: 0.387 seconds
