Frsky protocol select problem on Devo 7e
29 May 2014 14:05 #23745 by jpsue
Hello.
I'm using deviation 4.0.1 (latest Nightlybuild) on Devo7e which is installed cc2500 module.
I'm in trouble because I cannot use frsky protocol.
If I select frsky protocol in model definition, only "Re-Init" is selectable in Bind-type, and the following message is displayed.
"Bad/missing protocol modules"
I want advice, please.
30 May 2014 02:26 #23757 by PhracturedBlue
Replied by PhracturedBlue on topic Frsky protocol select problem on Devo 7e
I forgot to enable building the modules for the devo7e.
I have fixed that now.
Grab the latest nightly: e2ae2cc
30 May 2014 02:31 #23758 by jpsue
Replied by jpsue on topic Frsky protocol select problem on Devo 7e
Thank you,PhracturedBlue.
I will try it.
30 May 2014 03:10 #23759 by jpsue
I have tried latest Nightly now, and it is OK.
My Devo7e can bind the Frsky receiver and the Frsky-V8 receiver.
The problem was solved. Thank you.
30 May 2014 03:36 - 30 May 2014 03:37 #23760 by vlad_vy
Replied by vlad_vy on topic Frsky protocol select problem on Devo 7e
But all language files as before are very short (5 lines only), except Devo7e of course.
bitbucket.org/PhracturedBlue/deviation/i...problem#comment-None
Last edit: 30 May 2014 03:37 by vlad_vy.
08 Apr 2018 06:59 #68549 by darkmachine123
Replied by darkmachine123 on topic Frsky protocol select problem on Devo 7e
Hi can someone help me, i need to activate all FrySky in Devo 7e, they all have an * so i cant use them
08 Apr 2018 08:51 #68553 by Fernandez
Replied by Fernandez on topic Frsky protocol select problem on Devo 7e
Check your hardware.ini are modules on the correct pins?
Or maybe easier follow the instruction on the web and do a fresh firmware upgrade and and full copy of the file system and check that first.
09 Apr 2018 05:49 #68568 by darkmachine123
But i cant do that i dont have the tools for upgrading and salding :s
09 Apr 2018 05:52 #68569 by darkmachine123
Can i make an upgrade from the other chip of the drone? cause the receiver is salded to it and the other chip has a USB port
09 Apr 2018 06:51 #68570 by Fernandez
Ah a stock devo, yes then you need to solder cc2500 module inside costs 5 bucks and some handworks....
Otherwise for not so handy people, you can buy irange X radio or the jumper (plus) which come full deviated, with full protocol multimodules.
09 Apr 2018 07:43 #68572 by darkmachine123
So i cant just add protocols in the software of deviation ?
09 Apr 2018 07:43 #68573 by darkmachine123
you need to add the cip that supports the protocols ? am i getting this right, trying to learn :)
Time to create page: 0.477 seconds
