How to install Deviation with linux
- aperseghin
15 May 2015 22:57 #32635
by aperseghin
How to install Deviation with linux was created by aperseghin
OK so you only use linux but you want to install deviation firmware. Well you can.
Install Virtualbox (its free)
download your VM here
dev.modern.ie/tools/vms/#downloads (its free and 100% legal)
unzip and open the VM file
in ubuntu you need to follow the troubleshooting steps here to get USB devices to recognize
askubuntu.com/questions/365850/virtualbo...usb-filters-settings
all i had to do was
sudo usermod -G vboxusers -a <your_username>
and then just follow the steps for a normal install inside the VM
Worked for me
all i had to do was
Worked for me
- vmsda
18 Jan 2016 13:07 #41904
by vmsda
Replied by vmsda on topic How to install Deviation with linux
I followed this path, the VM 'sees' the 7e, but does not find a device driver for it ...aperseghin wrote: OK so you only use linux but you want to install deviation firmware. Well you can.
all i had to do was
Worked for me
18 Jan 2016 14:20 #41905
Replied by hexfet on topic How to install Deviation with linux
Try the driver installer from the
Downloads area
- vmsda
19 Jan 2016 15:41 #41947
by vmsda
Ok, thanks. Now Win7 under VirtualBox accepts the device.
But I have hit another wall. Found that the Walkera Dfuse USB firmware upgrade package was also needed. Only found the V2.3. Installed it but it does not 'see' my 7e. Is there a special version for the 7e? Any hints?
19 Jan 2016 15:54 #41948
Try the deviation uploader on the same download page. It's java so it might work directly on linux, but don't know if anyone's tried.
- vmsda
19 Jan 2016 16:15 - 19 Jan 2016 18:50 #41950
by vmsda
I cannot try on Ubuntu because 1. It does not give me a path to the device and 2. Have no driver for it.
So I have to go on with Win7 under VirtualBox as up to now (not that I relish it, believe me).
Addenda 1: in fact, after unziping it and transferring all the files to Win7, I do not even know which prog/command to invoke!
Addenda 2: GOT IT GOT IT GOT IT! Decided to risk it: installed Java in the VirtualBox Win7, invoked the Java Deviation Uploader 0.8.0, and it worked like a charm.
Thank you for your support, hexfet.
Now, the next hurdle.
Last edit: 19 Jan 2016 18:50 by vmsda.
20 Jan 2016 09:02 #41967
Replied by mwm on topic How to install Deviation with linux
The deviation uploaded does work on Linux (at least it does in a VM on my Unix boxes). I don't use it regularly, as it doesn't avoid these need for a vm.
You don't need a device driver for it. At least, I didn't. Like the Mac, Linux comes with the appropriate driver installed.
You don't need a path to the device, either - it should scan the USB devices until it finds your Devo.
Still can't sit at a desk, but I'll be willing to try it again once I can it you would like to support this out.
- Richard96816
20 Jan 2016 10:26 #41971
by Richard96816
Replied by Richard96816 on topic How to install Deviation with linux
- aperseghin
06 Feb 2016 14:07 #42668
by aperseghin
This is also an option, I was already running a VM system so thats the route i went. More than one way to skin a cay (who are all these people skinning cats?)
Replied by aperseghin on topic How to install Deviation with linux
Richard96816 wrote: Windows is unnecessary. This works:
www.rcgroups.com/forums/showpost.php?p=27124295&postcount=444
Time to create page: 0.082 seconds
