Ultimate7e tutorial: Four 3-way + two 2-way switch
- Fernandez
20 Jun 2016 11:59 #50856
by Fernandez
Replied by Fernandez on topic Ultimate7e tutorial: Four 3-way + two 2-way switch
Hey Silpstream, I was wondering is there still progress on the possibility for adding the extra switches combination, such as:
2x 3way and 6x 2way
4x 3Way and 4x 2way
I still have room for two more switches and actually therefore I did not yet wired up yet the extra switches
If not anymore in the pipe, no problem and then will hook up 4x 3 2x 2 as per instruction of thios topic.
Anyway I do not mind to use an extra GPIO pin.
2x 3way and 6x 2way
4x 3Way and 4x 2way
- silpstream
20 Jun 2016 15:35 #50862
by silpstream
Replied by silpstream on topic Ultimate7e tutorial: Four 3-way + two 2-way switch
@fernandez, I just finished the new code but got some compile warnings to work out. I also need to put a bit of documentation together so that you can wire it up. Give me a few more hours then get ready to test. Thanks!
- Fernandez
20 Jun 2016 17:06 #50864
by Fernandez
No rush, take your time.
Was just wondering if this idea was still in the pipe, or that it was decided to stop.
Anyway good to hear
Anyway good to hear
- silpstream
20 Jun 2016 18:27 - 22 Jun 2016 16:28 #50865
by silpstream
Hi guys, I just uploaded a new build that will enable different combinations of switches:
deviation-devo7e-256-v5.0.0-swcfg-0bf38cc
We can now have a maximum of 8 switches (A - H). Possible switch combinations are:
Only the above combinations are supported. Naming convention is number of switch positions x number of switches. Example: 3x2 = 3-way x 2 switches, 2x5 = 2-way x 5 switches.
Configuration for the above is from hardware.ini. The option "extra-switches=nostock" now needs to be added if this mod is used to tell the firmware that the stock HOLD/FMOD switches have been removed. If you are using the previous (original 3x2/3x1/2x2) devo7e switch mod, then do not add the "nostock" option.
My config (new u7e switch mod with 3x4, 2x2, potx2):
Example (original devo7e switch mod with 3x2):
Given that we now have switches A - H, the 2-way switches have been shifted to ease the conditional logic used. As such, take note that you'll need to update your model.ini files for the new switch names. Basically:3-way switches start from A and move forwards to D. 2-way switches start from H and go backwards to A. Thus 3x4, 2x2 would give us: SWA, SWB, SWC, SWD, SWG, and SWH.
Here's how the wiring should go.
Basically just wire based on the switch config that you want. For example if you are doing 3x4, 2x2, then wire based on 3x1, 3x2, 3x3, 3x4, 2x1, 2x2. If you are doing 3x2, 2x6, then wire based on 3x1, 3x2, 2x1, 2x2, 2x3, 2x4, 2x5, 2x6. Don't forget the diodes as shown.
Please help me test it on both the original switch mod and the u7e switch mod. Thanks guys!
extra-switches = nostock
extra-switches = 3x4
extra-switches = 2x2
extra-switches = potx2Example (original devo7e switch mod with 3x2):
extra-switches = 3x2Given that we now have switches A - H, the 2-way switches have been shifted to ease the conditional logic used. As such, take note that you'll need to update your model.ini files for the new switch names. Basically:
3x4: SWA, SWB, SWC, SWD
3x3: SWA, SWB, SWC
3x2: SWA, SWB
3x1: SWA
2x1: SWH
2x2: SWH, SWG
2x3: SWH, SWG, SWF
2x4: SWH, SWG, SWF, SWE
2x5: SWH, SWG, SWF, SWE, SWD
2x6: SWH, SWG, SWF, SWE, SWD, SWC
2x7: SWH, SWG, SWF, SWE, SWD, SWC, SWB
2x8: SWH, SWG, SWF, SWE, SWD, SWC, SWB, SWAHere's how the wiring should go.
Last edit: 22 Jun 2016 16:28 by silpstream.
- Fernandez
20 Jun 2016 20:24 #50867
by Fernandez
It looks very promising but can you please explain, the switches naming as I found confusing what means what.
I always thought.
2x2, means 2pcs a 2 position switch.
2x3, means 2pcs a 3 position switch.
In my ideal case I like to put 3pcs 3way and 3 pcs 2way.
I always thought.
- silpstream
20 Jun 2016 20:28 #50868
by silpstream
Actually the naming convention in deviationtx has been:
3x2 = 3-way x 2
2x1 = 2-way x 1
In your case you will want 3x3, 2x3.
3x2 = 3-way x 2
2x1 = 2-way x 1
- Fernandez
20 Jun 2016 20:58 #50870
by Fernandez
Ahh ok clear, actually btw I meant 4 2way and 4 3way, so I am planning to follow your color coding and wire up my u7e like this;
4x3 - SWA, SWB, SWC, SWD
4x2 - SWE, SWF, SWG, SWH
Potx2
Take some time, but certainly will do and revert back
Potx2
- silpstream
20 Jun 2016 21:03 - 20 Jun 2016 21:24 #50871
by silpstream
You can't do 3x4 with 2x4. Check the combinations i posted above for possible combinations. I just edited it to make it clearer.
Could you also test first with your existing switch mod? I'd like to know if it works for the original switch mod. Thanks!
Last edit: 20 Jun 2016 21:24 by silpstream.
- Fernandez
21 Jun 2016 13:02 - 21 Jun 2016 13:14 #50905
by Fernandez
Just to confirm I have just loaded firmware post #50865, deviation-devo7e-256-v5.0.0-swcfg-0bf38cc, into my U7E.
It detects pefectly fine my original devo 7e, 4 switches configuration 2x3 and 2x2.
Only thing, it is missing the Frsky X-protocol, which was in previous U7E build.
Last edit: 21 Jun 2016 13:14 by Fernandez.
- silpstream
21 Jun 2016 16:50 #50912
by silpstream
Thanks for testing! I'm building these based on BRANCH_5.0. After everything works, I'll then merge it to the nightly build.
- Fernandez
21 Jun 2016 18:39 #50916
by Fernandez
I have build the 3x2 2x6, I basically used some flat cable and wired the lines from the back of 7e pcb
in following order:
Left to right: PB6 blue-PB5 light blue-PC10 Pink-PC11 Red -PB7 Green -PC6 Yellow -PB8 Orange
The switch layout seen from back of the Tx, see the image sketch attached.
My hardware.ini looks like this:
;enable-haptic=1
;switch_types: 3x4, 3x3, 3x2, 3x1, 2x2, 2x1, potx2, potx1
extra-switches = 2x4
;extra-buttons=
;Unique TxId, With tx same id and model bind Id, the rx can be controlled by multiple Tx
;txid = 78968765
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
enable-cc2500 = A13
has_pa-cc2500 = 1
enable-a7105 = A14
has_pa-a7105 = 1
enable-nrf24l01 = A15
has_pa-nrf24l01 = 1
; enable-multimod = A13
Anyway there is some response from switches but all is weird I cant put the finger on it, there is something wrong, switches interact sometimes change label depending on other switches etc, sometimes don't work.
I thought I have wired all pretty securely, according your colour drawing, see also photo, but now will first double check it, currently it is not ok.
in following order:
;enable-haptic=1
;extra-buttons=
;txid = 78968765
[modules]
enable-cc2500 = A13
has_pa-cc2500 = 1
enable-a7105 = A14
has_pa-a7105 = 1
has_pa-nrf24l01 = 1
- silpstream
21 Jun 2016 19:13 - 21 Jun 2016 19:22 #50917
by silpstream
@Fernandez, I must apologise. After reading your post, I rechecked my wiring diagram and realised that there was an error for 2x5 and 2x6. I confused PB6 and PC6. I've corrected it and uploaded the new diagram above.
Also, your hardware.ini should be 2x6 not 2x4.
Hopefully this sorts it out. Again, I'm really sorry for the error.
Last edit: 21 Jun 2016 19:22 by silpstream.
- Fernandez
21 Jun 2016 19:14 - 21 Jun 2016 19:15 #50918
by Fernandez
I double checked the wiring according your diagrams I double checked the diodes polarity.
But it seem all is wired correct.
It seem there is some bug in the matrix or software?
Ah ok 2x6, but basically the 2 stock switches must be included?
will try check your update.
Last edit: 21 Jun 2016 19:15 by Fernandez.
- silpstream
21 Jun 2016 19:21 #50919
by silpstream
You basically want the following in your hardware.ini:
"nostock" removes the stock switches, so 2x6 defines all the newly wired in switches.
The updated wiring diagram is in post #50865 .
extra-switches = 2x6
extra-switches = potx2"nostock" removes the stock switches, so 2x6 defines all the newly wired in switches.
- Fernandez
21 Jun 2016 19:58 #50921
by Fernandez
There is some progress, changed ini and changed yello to blue as suggested.
It is better but there still are problems somewere.
the way I tested it just to flip a switch and check how it is being detected in the display.
2x1 - no detection
2x2 - no detection
2x3 - F0-F1
2x4 - D1-E1
2x5 - C1-D1
2x6 - C0-C1 ok
3x1 - no detection
3x2 - B0-B1-B2 ok
so still some errors in software or matrix
2x1 - no detection
2x2 - no detection
2x3 - F0-F1
2x4 - D1-E1
2x5 - C1-D1
2x6 - C0-C1 ok
3x1 - no detection
3x2 - B0-B1-B2 ok
- silpstream
22 Jun 2016 16:51 - 22 Jun 2016 16:53 #50948
by silpstream
@Fernandez, I got home after work today and tore apart my 7E to test the switch mod and check my wiring diagram.
To my horror the diagram I gave you was WRONG a second time. I'm feeling really dumb now, really sorry AGAIN.
I've updated it AGAIN and updated post #50865. Hopefully this is the last time, cause I really checked and rechecked with my TX open and wired for 3x2, 2x6. Here's a video of the result.
Last edit: 22 Jun 2016 16:53 by silpstream.
- Fernandez
22 Jun 2016 17:26 #50950
by Fernandez
No problem Silp, I appreciated your work, I have been volunteer to test it
Anyway I can recommend anyone to put a piece of flat cable to the mid of tx, from there you have all connection points from left to right and can easy and neat wire to all switches. It is also relatively simple to change, just shift some wires here length stay same, I did not yet shrink the sleeves.
Will test and let you know.
- Fernandez
22 Jun 2016 19:47 #50959
by Fernandez
Almost working but still there seem to be an issue......
I'll check a bit different, just toggle a switch, and then read the swith label in the settings field in a channel.
The current status is:
3x1 - A0-A1-A2
3x2 - B0-B1-B2
2x1 - H0-H1
2x2 - G0-G1
2x3 - E1-D1
2x4 - F0-F1
2x5 - C0-C1
2x6 - D1-C1
The 2x3 and 2x6 are incorrect, switch labels on toggle.
The labels itself seem not correct, would expect 2x1 to be C and 2x2 to be D etc etc.
3x1 - A0-A1-A2
3x2 - B0-B1-B2
2x1 - H0-H1
2x2 - G0-G1
2x3 - E1-D1
2x4 - F0-F1
2x5 - C0-C1
2x6 - D1-C1
- silpstream
23 Jun 2016 06:26 #50968
by silpstream
I think I fixed it. Try
deviation-devo7e-256-v5.0.0-swcfg-990acaa
The 2-way switches go backwards starting from SWH (2x1) anding in SWA(2x8). The 3-way switches go forward from SWA (3x1) to SWD (3x4). They meet in the middle depending on switches configured.
Your 2x3 and 2x4 as well as 2x5 and 2x6 wires for red and pink are reversed so you see them flipped. Don't need to re-solder, just move the switches in the housing.
- Fernandez
23 Jun 2016 08:39 #50974
by Fernandez
Bang it works after the update, all 8 switches are fine now.
I'll make some pictures and short description later, for others want to copy the build 2x3 + 2x6 + 2 pots.
Still I believe might make sence, just to change the labels of switches, so that lower switch label also have the lower letters.
such 3x1 A
3x2 B
2x1 C
2x2 D
2x3 E
etc....
such 3x1 A
3x2 B
2x1 C
2x2 D
2x3 E
etc....
Time to create page: 0.233 seconds
