Ultimate7e tutorial: Four 3-way + two 2-way switch
- silpstream
23 Jun 2016 13:52 #50988
by silpstream
Replied by silpstream on topic Ultimate7e tutorial: Four 3-way + two 2-way switch
Good to know it's working. Now I need to rewire my u7e for the original 3x4, 2x2 that I had to test that I haven't broken that part of the code.
Actually the 2x1 -> SWH naming is there because if I don't do that the code get very complex (not that it isn't already). By having them both come from different directions over the available switches, I can save on code as 3-way switches will never be using SWE -> SWH, thus I only need to check the first 4 with conditions. In your case if you just reposition the switches physically you'll have everything in order.
- silpstream
23 Jun 2016 17:06 - 23 Jun 2016 17:07 #50997
by silpstream
Just tested with my 3x4, 2x2 setup. All working. Does anyone else have another switch configuration to test before I submit a pull request to the main branch?
@HappyHarry, are you still running your 3x3, 2x1 configuration? If you are could you test? It just occurred to me that you might need to change the wiring for the 2x1 cause IIRC your current 2x1 switch would be using the 2x2 wiring position in the new setup.
Thanks guys!
Thanks guys!
Last edit: 23 Jun 2016 17:07 by silpstream.
- Fernandez
24 Jun 2016 15:03 - 24 Jun 2016 15:07 #51036
by Fernandez
Replied by Fernandez on topic Ultimate7e tutorial: Four 3-way + two 2-way switch
Just for others to get some inspiration, of how to build two pots and 8 switches, all mounted in the top cover.
I would recommend to use wire from the pcb to mid of the tx under the buzzzer pannel, from there you can split distribute and solder wires to both sides of the switches.
The 1n4148diodes, I solderd as close as possible to the switch, almost all wires removed, then covered by heatshrink.
Attached some images.
Last edit: 24 Jun 2016 15:07 by Fernandez.
- HappyHarry
24 Jun 2016 15:56 #51038
by HappyHarry
sorry but I've only got 4x3,2x2,2xP and stock u7e's now bud, and I'm sitting in the airport away to head off for 2 weeks so I can't do any testing at the minute either
Replied by HappyHarry on topic Ultimate7e tutorial: Four 3-way + two 2-way switch
silpstream wrote: @HappyHarry, are you still running your 3x3, 2x1 configuration? If you are could you test? It just occurred to me that you might need to change the wiring for the 2x1 cause IIRC your current 2x1 switch would be using the 2x2 wiring position in the new setup.
Thanks guys!
- D_an_W
24 Jun 2016 16:03 #51039
by D_an_W
Replied by D_an_W on topic Ultimate7e tutorial: Four 3-way + two 2-way switch
HappyHolidaysHarry (if it is a Holiday that is!).
- HappyHarry
24 Jun 2016 16:48 #51040
by HappyHarry
thanks bud, it is indeed a holiday and we're off to a great start, flight is delayed 90mins :/ was supposed to take off at 17:30, now it's scheduled for 19:00, going to be at least midnight before I reach the hotel!
- compman2
23 Mar 2018 20:17 #68314
by compman2
Replied by compman2 on topic Ultimate7e tutorial: Four 3-way + two 2-way switch
I am assuming that this switch mod has been incorporated into the regular builds. I want to install 3x3, 2x5 and 2 pots on my Ultimate 7e .
- Fernandez
24 Mar 2018 06:53 #68320
by Fernandez
Yes the switch mod is part of the std nightly build and working well, multiple configuration possible.
As myself I use 2x pots and 6x 1way 2x 3way switch.
You just need to include the switch / pot setup lines in hardware.ini
Time to create page: 1.314 seconds
