T8SG v2 plus carbon updating help
13 Jan 2020 03:51 #75696 by txinsuranceguy
T8SG v2 plus carbon updating help was created by txinsuranceguy
I have Firmware v5.0.0-abc5dcf i'm guessing this is pretty old?
Should i be using the latest nightly as there is no other version on the downloads section. What would i gain?
i have windows 10 pro
when i copy from the "usb drive from the computer model10 is always corrupt"
i have downloaded the deviationsupload-0.9.9.jar file but not sure what to look for inside it.
i have downloaded and clicked all the application files on the DFU USBdrv Installer-1.1
i have downloaded the STM32 and unzipped that
i downloaded the emulator and it ran but i can't do anything with that.
what i'm curious is all the update videos and documents say to use a program to upload the DFU i cannot find that "walkera" program. its not in the location in the video.
thoughts?
just leave it as is since its working great?
13 Jan 2020 14:06 #75701 by eried
Replied by eried on topic T8SG v2 plus carbon updating help
txinsuranceguy wrote: I have Firmware v5.0.0-abc5dcf i'm guessing this is pretty old?
Few improvements, for example hold to turn off. But if you do not miss anything then I guess it is better to keep that firmware for now.
txinsuranceguy wrote: i have windows 10 pro
Remove the USB drive safely from Windows, click the traybar icon, remove and wait until a message says "It is safe to remove". Then disable USB in the remote.
txinsuranceguy wrote: i have downloaded the deviationsupload-0.9.9.jar file but not sure what to look for inside it.
thoughts?
I do not know what those programs do, for upgrading the firmware I just use www.walkera.com/en/upload/upgrade/DevoDfuSe%20V2.0.zip read the instructions here:
www.deviationtx.com/manuals/html-devo10-en/ch_install.html
14 Jan 2020 04:20 #75709 by txinsuranceguy
Replied by txinsuranceguy on topic T8SG v2 plus carbon updating help
thanks! i guess i should have bought a Devo instead of the jumper. why did the firmware install tool get removed from the downloads?
14 Jan 2020 05:23 #75711 by vlad_vy
Replied by vlad_vy on topic T8SG v2 plus carbon updating help
See "Tools" folder:
walkera-fans.de/downloads/
15 Jan 2020 13:37 #75728 by eried
You probably need to read how to update a Devo too.
16 Jan 2020 06:28 #75735 by txinsuranceguy
is the devo and the t8sg the same? i'm sure i can update it, but its working and i'm not sure i need any update on it for what i'm using it for.
16 Jan 2020 23:34 #75739 by eried
They are not the same but the update procedure is the same
Time to create page: 0.072 seconds
