Config for Mini/Genius CP for Devo6s
- Sonnno
29 Nov 2012 14:53 #3416
by Sonnno
Config for Mini/Genius CP for Devo6s was created by Sonnno
Hi all,
I just buyed the devo6s, because i´m fastinated by the deviation project. Unfortunately the Firmware overwhelmed me. So I search a good config for the Genius CP (WK Receiver) and for the Mini CP (Devo), or can i installed the Configs for the Devo8s?
Thank you by answering my questions!
29 Nov 2012 15:02 #3418
Replied by FDR on topic Config for Mini/Genius CP for Devo6s
You can use the DEVO 8 configs, just check what switches it uses, because you have less switches available.
The fw converts the unavailable switches to the exising ones, but it may result that the same switch is used for two (possibly contradictional) functions...
- Sonnno
29 Nov 2012 15:11 #3419
by Sonnno
Replied by Sonnno on topic Config for Mini/Genius CP for Devo6s
Thank you. Then i will download the config for Devo8s
Time to create page: 0.669 seconds
Model Configs
- Config for Mini/Genius CP for Devo6s
