Config for Blade mSRx & mSR needed.
30 Nov 2012 01:02 #3439 by Alexander
Config for Blade mSRx & mSR needed. was created by Alexander
Hi Guys,
I found the model icon for the mSRx, but no config. Can anybody please provide the config for the Blade mSRx and/or Blade mSR? I tried normal 6 CH Heli template, but I was not able to get the correct controls :-(
Thx a lot,
Alexander
05 Dec 2012 16:35 #3666 by Rain4LA
Replied by Rain4LA on topic Config for Blade mSRx & mSR needed.
I'm having the same problem binding the mSRX. The right stick works, but the left stick doesn't. Any help would be appreciated.
(By the way Alexander, the mSRX is a 4 channel helicopter)
05 Dec 2012 17:06 - 05 Dec 2012 17:10 #3669 by Hexperience
Replied by Hexperience on topic Config for Blade mSRx & mSR needed.
Couple of things to watch for.
- When you select DSM2 as the protocol the order of the channel output automatically changes to TAER, BUT in the mixes them selves, the INPUT on the channel doesn't (as of version 2.0.x, it may change). So you'll need to go through the channel 1 mix (the button that says simple) then change the input from ELE to THR. Do the reverse on channel 3.
- The MSRX settings from blade say it's a 90 degree single servo heli, which means that NO ccpm mixing is needed in the TX.
- For my DSM heli's I always use the fixed ID, just seemed to work better. (I have had to rebind from time to time)
So, this should get you in the air;
Go to a new model, select DMS2 as the protocol, leave it at 7 channel (it's telling deViation to act like a Dx7, it's got nothing to do with the number of channels on the RX. (not 100% true, but it's a good way to think about it)).
Go back to the mixer, hit the Simple button next to the top channel, select THR as the input.
Go back, hit the Simple button next to the third channel, select ELE as the input.
GOOD idea; Hit the Channel output button (1-THR). Turn on the safety switch, most of us are using the RUD DR switch, the one on the top left side. Set Safe Value to -100. Get into trouble, flip that switch and you cut the motor.
That easy... that should get you in the air. However you may want to lower the rates on the ELE and AIL. Just go back into mix, and set the scale to 70% or what ever you like.
Please let me know how this works out for you, I don't have an MSRx to try it on.
Last edit: 05 Dec 2012 17:10 by Hexperience.
05 Dec 2012 21:32 #3682 by Alexander
Replied by Alexander on topic Config for Blade mSRx & mSR needed.
I tried 6 CH Heli template and a different swash plate setup and finally got the mSRx working with my Devo 8 :-)
See the attached the config-file for details. Mix switch is for dual rates.
Nevertheless, I cannot get the Blade mSR to work... the servos are moving as I move the sticks, but not the correct servo/directions.
@Hexperience: Thx for the tips! :-)
Regards,
Alexander
09 Jan 2013 19:24 #4864 by SamtheMan
Replied by SamtheMan on topic Config for Blade mSRx & mSR needed.
Did anyone get the MSR working with Deviation?
09 Jan 2013 19:48 #4868 by Joshua
Replied by Joshua on topic Config for Blade mSRx & mSR needed.
Blade mSR works fine for me with Blade 120SR config.
ciao, Bernd
10 Jan 2013 00:44 - 10 Jan 2013 01:07 #4873 by SamtheMan
Ok I am using the setup for the 120SR, however the ele won't work unless gear switch is flipped to 1. Any ideas why?
Last edit: 10 Jan 2013 01:07 by SamtheMan.
10 Jan 2013 09:19 - 10 Jan 2013 09:23 #4886 by Joshua
SamtheMan wrote: Ok I am using the setup for the 120SR, however the ele won't work unless gear switch is flipped to 1. Any ideas why?
ELE? Are you sure?
For security THR is off when gear is 0.
You can chance this under Mixer/1-THR/Safety if you want.
ciao, Bernd
Last edit: 10 Jan 2013 09:23 by Joshua.
  • rbe2012
  • rbe2012's Avatar
10 Jan 2013 09:25 #4888 by rbe2012
Replied by rbe2012 on topic Config for Blade mSRx & mSR needed.
Bernd,
wouldn't it be sufficient to have a safety switch for throttle? This is the way I configure my helis usually. Can you explain the advantage of switching off elevator? Waht could it help?
Rainer
10 Jan 2013 09:34 #4889 by Joshua
rbe2012 wrote: Bernd,
Rainer
I think you post, before i was ready with eding my post?
Safety for elevator make no sense.
I use Safety only for THR.
ciao, Bernd
  • rbe2012
  • rbe2012's Avatar
10 Jan 2013 10:02 #4891 by rbe2012
Yes, read the old version...
04 Jul 2013 05:48 #11851 by EVERNIN
Replied by EVERNIN on topic Config for Blade mSRx & mSR needed.
Can someone experienced enough, transalate this spektrum DX6i settings for msrx to apply to Devo 8s/deviation???
or maybe a .ini file would be great.
ganninger.de/DX6i-mSRX.pdf
thank you.
source:http://www.helifreak.com/showthread.php?t=439796
19 Aug 2013 05:27 #13033 by Dawiev
Replied by Dawiev on topic Config for Blade mSRx & mSR needed.
Bump (plse !)
Struggling to get some sort of beginner setting for the MSRX working, that keeps the head-hold mode.
02 Nov 2013 13:46 #15238 by greywall
Replied by greywall on topic Config for Blade mSRx & mSR needed.
EVERNIN wrote: Can someone experienced enough, transalate this spektrum DX6i settings for msrx to apply to Devo 8s/deviation???
thank you.
+1
Please, can someone help me configure these settings for Devo10? ;)
THX
09 Jan 2014 12:43 - 09 Jan 2014 12:44 #18275 by .Joker.
Replied by .Joker. on topic Config for Blade mSRx & mSR needed.
thank you.
+1
THX
+1
Would it be possible to use the Model intend for Devo8 for Devo10 also ?
Look here :
www.deviationtx.com/forum/model-configs/...for-devo8-v4-0#17731
www.deviationtx.com/forum/builds/2528-up...g-model-failer#17732
I could not try it because i'm still waiting for deliver of Devo 10 / Blade msrX.
Regards
Last edit: 09 Jan 2014 12:44 by .Joker..
09 Jan 2014 14:13 #18279 by FDR
Replied by FDR on topic Config for Blade mSRx & mSR needed.
They should work fine...
Time to create page: 0.311 seconds
