Walkera
- Tom Z
01 Dec 2012 02:16 - 13 Jan 2014 23:35 #3479
by Tom Z
Walkera was created by Tom Z
Due to all the confusion here I have deleted the file and remade it.
This time I didn't use any virtual channels as I found out they we not need.
It was OK to have and use them but I got rid of them anyway.
I also corrected the gyro gain value when I found out there was a special way to convert the walkera gyro gain to deviation gyro gain. I was close before but now it is exact.
I have posted the new model in a new thread.
Look for Walkera CP Helicopters - Beginner or Standard settings.
This model will work on the following helicopters.
1. Walkera V120D02S
2. Walkera V120D02S V2
3. Walkera Mini CP
4. Walkera Super CP
5. Walkera Genius CP V1/V2
6. Walkera V100D08
7. Walkera Master CP
1. Walkera V120D02S
3. Walkera Mini CP
4. Walkera Super CP
6. Walkera V100D08
Last edit: 13 Jan 2014 23:35 by Tom Z.
- pshkong
05 Dec 2012 12:12 #3652
by pshkong
Replied by pshkong on topic Walkera V120D02S/Mini CP/Genius CP/Master CP
Hello, I tried to use this config file on Devo 10 with Mini CP, but somehow the behavior is quite weird. I'm new to deViation, can you please let me know which part should I twist in make it work on Devo 10?
- Tom Z
05 Dec 2012 23:55 #3688
by Tom Z
Replied by Tom Z on topic Walkera V120D02S/Mini CP/Genius CP/Master CP
Hi, can you explain what behavior is quite weird?
I'll see if I can help you out.
You should be able to import the model and fly it.
- gigrichj
21 Jan 2013 00:21 #5290
by gigrichj
Replied by gigrichj on topic Walkera V120D02S/Mini CP/Genius CP/Master CP
Hi, what program are you using in the youtube video. I assume it allows you to save the .ini file for the model. Thanks
- Pixel166
21 Jan 2013 11:12 #5302
by Pixel166
Replied by Pixel166 on topic Walkera V120D02S/Mini CP/Genius CP/Master CP
The program used in the video is the emulator. And yes, it allows to save .ini files.
- ferreret
21 Jan 2013 12:00 #5303
by ferreret
Replied by ferreret on topic Walkera V120D02S/Mini CP/Genius CP/Master CP
I used the configuration for my Genius, and is running perfect. Thank you very much!
- maxjos
24 Jan 2013 16:34 #5470
by maxjos
Replied by maxjos on topic Walkera V120D02S/Mini CP/Genius CP/Master CP
Hi - thanks for sharing your config. I've been trying to use this for my V120D02S and DEVO8S, however when setting up servos, head and linkage I have problems with one of my servos not being level. How can I sub trim *one* servo?
M
M
- sbstnp
24 Jan 2013 17:13 #5472
by sbstnp
You can find this in the respective servo's channel (AIL, ELE). I haven't checked but there may be some mixing done by the FBL unit and leveling *one* servo might not be possible. But do check this please, I'm not near my heli atm.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Walkera V120D02S/Mini CP/Genius CP/Master CP
maxjos wrote: Hi - thanks for sharing your config. I've been trying to use this for my V120D02S and DEVO8S, however when setting up servos, head and linkage I have problems with one of my servos not being level. How can I sub trim *one* servo?
M
Devo 10 + 4in1
- maxjos
24 Jan 2013 17:20 #5473
by maxjos
Thanks, yes I have checked this. When I sub trim ELE or AIL it affects the virtual channel, not the individual servo.
- sbstnp
24 Jan 2013 18:27 #5474
by sbstnp
You should not have any virtual channel with the Mini or V120d02s (or any FBL heli), they have FBL units that mix the swash internally.
Read this please, by Hexperience:
www.deviationtx.com/forum/how-to/1226-ho...s-on-custom-firmware
I recommend a tour of the How To forum while at it as well.
Devo 10 + 4in1
Spektrum Dx9
maxjos wrote: Thanks, yes I have checked this. When I sub trim ELE or AIL it affects the virtual channel, not the individual servo.
Devo 10 + 4in1
- maxjos
24 Jan 2013 21:12 #5480
by maxjos
Hm, so I'm using the template at the top of this thread....
- sbstnp
25 Jan 2013 05:19 #5494
by sbstnp
Read that sticky please, it will clear things up.
Devo 10 + 4in1
Spektrum Dx9
maxjos wrote: Hm, so I'm using the template at the top of this thread....
Devo 10 + 4in1
- gapi
08 Feb 2013 02:39 #6143
by gapi
Replied by gapi on topic Walkera V120D02S/Mini CP/Genius CP/Master CP
Where are the Gyro settings located? I just want to look. I tried to find them but failed.
I had it setup in the MIX switch the Devo 10 Walkera FW for POS 0 & 1 @ 75% and POS2 to 50 for setup and such.
Will this be the same but for 85% in the Deviation FW?
- Hexperience
08 Feb 2013 02:52 - 08 Feb 2013 02:55 #6144
by Hexperience
Replied by Hexperience on topic Walkera V120D02S/Mini CP/Genius CP/Master CP
Walkera FW uses 0% to 100% values, where deViation uses -100 to +100 values. (spektrum also use the 0% to 100% values)
If your heli manual says to set something at 75%, then you double it, and subtract 100.
75x2=150-100=+50
30x2=60-100=-40
etc
To be honest, I never looked at the walkera fw for more than a few minutes, so I need someone to confirm that walkera fw is 0%-100%. (Seems like some settings are, and some are not...?)
The Gyro settings for Walkera are on channel 7.
75x2=150-100=+50
30x2=60-100=-40
etc
Last edit: 08 Feb 2013 02:55 by Hexperience.
08 Feb 2013 05:15 #6145
Replied by FDR on topic Walkera V120D02S/Mini CP/Genius CP/Master CP
The original fw used 0..100% for the throttle and probably for the gyro too.
All the other values were -100..+100%
- gapi
08 Feb 2013 23:49 #6154
by gapi
Thanks Guys, I have the Master CP & Devo 10 w/2.1.1.
I'm really new with this so have patience please?
Thanks for telling us where the Gyro settings are. I am interested in this because as you may know, Walkera's Gyro setting of or below 50% in Walkera numbering terms disables it so you can do adjustments with no Gyro interference.
I like the three options of the this models FMOD switch and wonder if I can setup the Mix Switch POS2 for a 50 or less Gyro gain setting or would that be in Deviation terns 50 x 2 = 100 - 100 = 0%?
This is what the Master CP user manual says to do in the Gyro menu on all Devos but for the 7e. Walkera uses the Mix Switch for their Gyro stuff.
So.......... if I can't have a separate switch to kill the gyro for a fast setup observation & adjustment mode I guess I would just have to be not lazy and go into Ch7 and lower it/save/ and make my observations and/or adjustments and then change it back.
Or if it is possible to move all the Gyro settings to the Mix switch?
09 Feb 2013 08:04 #6160
Replied by rbe2012 on topic Walkera V120D02S/Mini CP/Genius CP/Master CP
DeViation uses values between -100% and +100% for the sticks and switches. So you have two formulas to recalculate the values (as Hexperience has wtitten above):
- Value(Devo) = (Value(Deviation) + 100) / 2
- Value(deViation) = 2 * Value(Devo) - 100
- gapi
17 Feb 2013 18:50 #6484
by gapi
Thanks, Sorry for the delayed response, I didn't hit the subscribe box. I am used to having it auto on other forums.
I am still struggling with this whole thing and why the interface has to be so different but I know its like it or leave it eh?
I see the nightlies are including a Standard mode and that's going to be more like it if it flies in a release.
I read the Deviation manual and have to flush one train of thought to get another and its a disaster.
Living and learning, but at a snails pace.
rbe2012 wrote: DeViation uses values between -100% and +100% for the sticks and switches. So you have two formulas to recalculate the values (as Hexperience has wtitten above):
And you can use the MIX switch instead quite easy: go to model menu, mixer, down to channel 7, down do switch1 and change it with some times left to MIX1, further down until switch2, change to MIX2, up until "save" and back to main page an you're done.
- JJ1984
28 Mar 2013 08:45 #8185
by JJ1984
Replied by JJ1984 on topic Walkera V120D02S/Mini CP/Genius CP/Master CP
Anyone got these config files, since they have been deleted off here.
Id like to use these ones and make the adjustments myself.
thank you.
thank you.
- Scream
28 Mar 2013 16:26 #8201
by Scream
Cheers!
-=S=-
Replied by Scream on topic Deleted
Hiya!
I think those files might have been deleted because they were causing a bit of confusion...
TomZ explained the concepts on a thread on the internet somewhere else about scale flying and his theories are spot on!
Here's the version(s) I've been using for my MiniCP, its loosely based on the originals but I can confirm they are both tame and indoor safe for newer pilots!
Setup for toggle Icons for low-Rez Tx's like Devo10, you "fancypants-color-screeners" may have to redo your main page if you choose to use this! I use 400mAh batteries and the timer is set accordingly.
Assignments:
Gear = TH
MIX = D/R
FMOD = TH/flight mode (takeoff = 0, cruise =1, holy @#$% = 2)
RUD D/R = stops timer if you are testing larger batteries
ELEV D/R = gyro from 80%(default) to 65%
Aile D/R = gyro from X to 50%
expo = none -add as required
Model # 3 = outdoor use suggested
model # 6 = indoor & noob friendly
Hope this helps!
Cheers,
-=S=-
Assignments:
Gear = TH
MIX = D/R
Hope this helps!
Cheers,
-=S=-
Cheers!
-=S=-
Time to create page: 0.229 seconds
