HobbyZone Champ
02 Dec 2012 04:25 - 18 Dec 2012 06:59 #3516 by N4JC
HobbyZone Champ was created by N4JC
The HobbyZone Champ is a 3 channel lightweight tail dragger, flying weight of 1.3 oz (39g) comes with a transmitter using only 4 AA batteries. I have experienced in-flight control drop outs maybe using the Devo 10 will help.
Since I want to use the Devo 10 for my entire airborne fleet, plus the power output options with Deviation this was an obvious path.
Aileron stick controls the rudder, flight controls on this Champ is rudder, elevator and power only.
Protocol=DSM2
Throttle, elevator, rudder are all set to simple, all other settings are template defaults.
/Edit: Fixed rudder trim, did not work, removed 'usetrim=0' in [channel2] of .ini file.
File Attachment:
File Name: ChampHZ.ini
File Size:4 KB
Last edit: 18 Dec 2012 06:59 by N4JC. Reason: Fixed rudder trim
Time to create page: 0.039 seconds
